Se poate da cu interfata USB (8$) sau fara.
Accept si schimburi in domeniul multicopter, cum ar fi 4 ESC-uri, ne intelegem la pret.
With the same program for the open source compared to KK or ACM, MWC's more stable flight performance, flight skills required for novice lower debugging process more intuitive. Dedicated MWC GUI program can easily observe the PID parameters, flight control signal input / output status, sensor / switch-state, as well as aircraft attitude and heading sensor signal state of each group, sufficient for the initial configuration of the aircraft easier.
MultiWii Lite lightweight version supports the following aircraft models:
GIMBAL -------- PTZ stabilizer independent (non-flight control purposes)
BICOPTER ------ 2-axis aircraft Avatar
Tricopter ----- Y3 (Y-type 3-axis)
QUADP --------- 4-axis + classic mode
QUADX --------- 4-axis × mode
Y4 ------------ Y-type four-axis
Y6 ------------ Y-type 6-axis
HEX6 ---------- 6 axis + mode
HEX6X --------- 6-axis × mode
FLYING WING --- flying wing with a (non-multi-axis machine, the program is in testing phase).
Tool to connect the computer via FTDI, flight mode can be easily converted at any time.
MWC MultiWii Lite lightweight version of the hardware configuration:
· ATMEGA328P microcontroller
· ITG3205 three-axis digital gyroscope
· ADXL345 three-axis acceleration sensor
http://www.goodluckb...oard-quadx.html
Aceasta postare a fost editata de renatoa: 08 June 2012 - 11:08 AM
Acest topic e inchis
