Modelism - RHC Forum: De vanzare - Modelism - RHC Forum
De vanzare MWC MultiWii SE Standard Edition 4-axis Flight Control Board QUADX w/
#1 Useril este offline   aiurici
  • Postari: 35
  • Inregistrat: 23-June 10
Postat 11 June 2012 - 07:46 AM
De vanzare MWC MultiWii SE Standard Edition 4-axis Flight Control Board QUADX w/ FTDI Basic Breakout. My link
si
MWC MultiWii Lite /SE 4-axis FlightControler Flight Control Board LCD Debugger Module My link
se livreaza doar impreuna.
Cei interesati sa dea PM.
MWC MultiWii SE Standard Edition 4-axis X-mode Flight Control Board QUADX
MWC is MultiWii Copter abbreviation, this open source program's original author is a French program Alex, after two years of joint efforts of many enthusiasts, and now the MWC program has become increasingly mature, has become very popular abroad, cost-effective flight control one. DIY is not a flight control, but no one can do things, Chris launched the MWC model series of flight control, so that multi-axis aircraft MWC fans can easily access the high cost of this product, through the MWC program to control the hardware platform, can achieve a variety of multi-spindle, high-quality flight results, flexibility can be adjusted into a very stable or very flexible to fit aerial, FPV or stunt flying and many different needs.
With the same program for the open source compared to KK or ACM, MWC's more stable flight performance, flight skills required for novice lower debugging process more intuitive. Dedicated MWC GUI program can easily observe the PID parameters, flight control signal input / output status, sensor / switch-state, as well as aircraft attitude and heading sensor signal state of each group, sufficient for the initial configuration of the aircraft easier.
MultiWii SE Standard Edition supports the following aircraft models:
GIMBAL -------- PTZ stabilizer independent (non-flight control purposes)
BICOPTER ------ 2-axis aircraft Avatar
Tricopter ----- Y3 (Y-type 3-axis)
QUADP --------- 4-axis + classic mode
QUADX --------- 4-axis × mode
Y4 ------------ Y-type four-axis
Y6 ------------ Y-type 6-axis
HEX6 ---------- 6 axis + mode
HEX6X --------- 6-axis × mode
FLYING WING --- flying wing with a (non-multi-axis machine, the program is in testing phase).
Tool to connect the computer via FTDI, flight mode can be easily converted at any time.
Aceasta postare a fost editata de aiurici: 11 June 2012 - 07:46 AM
#2 Useril este offline   GST 7.7
  • Sky isn't the limit
  • Postari: 1074
  • Inregistrat: 13-August 07
  • Interests:Programare, IT, Modelism
Postat 11 June 2012 - 07:59 AM
Pret? sunt interesat
The GST 7.7 is over 30% larger than a Revo 3.3. Park the GST 7.7 next to a Savage, and the Savage doesn't look so tough anymore.
VISTA = Virus Inside Switch to Apple
#3 Useril este offline   aiurici
  • Postari: 35
Postat 11 June 2012 - 08:09 AM
Vezi postareaGST 7.7, la 11 June 2012 - 07:59 AM, a spus:
sunt nite link-uri in post. In rest, discutam PM
Price: $54.10
Price: $13.11
Aceasta postare a fost editata de aiurici: 11 June 2012 - 08:12 AM
#4 Useril este offline   moremih
  • Postari: 320
  • Inregistrat: 14-September 10
Postat 11 June 2012 - 08:38 PM
Ai PM cu telefonul .
Vorbim maine dimineata detsliile tranzactiei .
Statie Turnigy 9x
Trainer - Wing - Dragon
Deltamotor RC 2012
Trainer - Scorpio Fan Max
