Modelism - RHC Forum: SJM 325 ARTF+PIESE - Modelism - RHC Forum
SJM 325 ARTF+PIESE Pret super.
#1 Useril este offline   EBA
  • Postari: 956
  • Inregistrat: 09-April 09
  • Interests:AEROMODELISM
Postat 25 March 2012 - 01:37 AM
Salut.3 zboruri la activ doar dupa care a fost desfacut bucati si pus in cutie.Tot din lipsa de timp nu a mai zburat.L-am montat pentru poze.Se poate rimite in tara.
SJM325-C PRO V2 SE+ Specifications:
• Airframe Weight (Including Canopy and Main Blades): 505g
• RTF Weight: 775-875g
• Airframe Length (With Canopy): 710mm
• Airframe Width: 120mm
• Airframe Height: 220mm
• Main Blade Disk Diameter: Up to 760mm (Using 330mm Main Blades)
• Flybar Paddle Disk Diameter : 350mm
• Flybar Rod Size : Ø2.5mm x 240mm
• Tail Rotor Disk Diameter: 150mm (Using 58mm Tail Blades)
• Main Shaft Size: Ø6mm x 136mm
• Tail Rotor Shaft Size: Ø3mm x 45mm
• Tail Boom Diameter (External): Ø15mm
• Main Drive Gear: M0.6 125T
Motorizare. Brushless Motor: SJM-BM30 3000KV HP Outrunner (12T/13T Pinions Included)
• High Performance ESC: SJM40A (PRO) w/ 3A (5A max) 5V S-BEC
• Both the SJM motor and ESC are fully 11.1V~14.8V (3S/4S) ready!
SERVO.3xHitec HS65HB PLATOU
1XROBBE FS61BB COADA
ASSAN GA250 GYRO
SE poate vinde in 2 variante.
1.KITUL care include doar motor si ESC.500lei
2.ARTF 600lei La ambele variante am bonus piese de schimb crash kit 0788481022.Cristian
:yahoo:
:pardon:
:pardon:
:pardon:
:pardon:
:pardon:
:pardon:
:pardon:
:pardon:
  • Fisier atasat  1.jpg (333.25K)
  • Fisier atasat  2.jpg (343.66K)
  • Fisier atasat  3.jpg (342.01K)
  • Fisier atasat  4.jpg (337.59K)
  • Fisier atasat  5.jpg (365.54K)
  • Fisier atasat  6.jpg (343.66K)
  • Fisier atasat  7.jpg (312.51K)
  • Fisier atasat  8.jpg (344.45K)
  • Fisier atasat  9.jpg (441.28K)
  • Fisier atasat  10.jpg (288.1K)
  • Fisier atasat  11.jpg (267.3K)
  • Fisier atasat  13.jpg (365.54K)
SUNTEM FUDULI
#2 Useril este offline   EBA
  • Postari: 956
Postat 03 April 2012 - 10:17 AM
550lei Toata treaba.Tot frame-ul este carbon,canopia fibra sticla,mecanica Alu.
Aceasta postare a fost editata de EBA: 03 April 2012 - 10:21 AM
SUNTEM FUDULI
#3 Useril este offline   pavcostel
  • Postari: 1598
Postat 04 April 2012 - 10:42 AM
Ce cuprinde "toata treaba"? Te rog sa detaliezi un picut, eventual pe mesagerie.
#4 Useril este offline   EBA
  • Postari: 956
Postat 04 April 2012 - 12:59 PM
Vezi postareapavcostel, la 04 April 2012 - 10:42 AM, a spus:
550lei ARTF+piese de schimb crash kit + transport :) ?
Aceasta postare a fost editata de EBA: 04 April 2012 - 01:01 PM
SUNTEM FUDULI
#5 Useril este offline   pavcostel
  • Postari: 1598
Postat 04 April 2012 - 01:13 PM
E ok, fa-i drum catre mine! Multumesc.
#6 Useril este offline   EBA
  • Postari: 956
Postat 06 April 2012 - 04:26 PM
VANDUT.
SUNTEM FUDULI
