AJUTOR SKARP
Postat 27 October 2011 - 08:21 AM
Postat 27 October 2011 - 02:33 PM
Postat 27 October 2011 - 09:30 PM
skarp, la 27 October 2011 - 02:33 PM, a spus:
in afara de motoare trebuie sa ai in vedere si regulatoarele... si in functie de ce motoare ii pui poate treci si pe li-PO... avand in vedere ca esti pe Pb momentan.
La fel e si cand esti prost.
tel: 0771 088 207
adistul@yahoo.com
Postat 27 October 2011 - 09:36 PM
Ce voltaj ai pe barca?
uite un ex mai economic:
Speed 720 BB TORQUE SMC-M-6372
Nominal Voltage 12.0v - Voltage Range 6.0 - 13v - No load RPM 4,100 - No Load Current 0.75 A - Current @ Max Efficiency 3.0 A - Stalled Current 13A - Max Efficiency 75% - Case length mm 72.0 - Case dia. mm 44.5 - Free shaft length mm 6.5 - Shaft Dia. mm 5.00 - Weight (g)380
si unul ceva mai rapid:
Speed 900 BB TORQUE SMC-M-6373
Nominal Voltage 12.0v - Voltage Range 6.0 - 40v - No load RPM 6,500 - No Load Current 1.1 A - Current @ Max Efficiency 8.0 A - Stalled Current 54A - Max Efficiency 71 % - Case length mm 95.0 - Case dia. mm 51.5 - Free shaft length mm 15.0 - Shaft Dia. mm 6.00 - Weight (g)645
Aceasta postare a fost editata de Adistul: 27 October 2011 - 09:38 PM
tel: 0771 088 207
adistul@yahoo.com
Postat 27 October 2011 - 09:47 PM
Postat 28 October 2011 - 06:43 AM
ce motoare sunt folosite pe Skarp?
Aceasta postare a fost editata de Adistul: 28 October 2011 - 06:44 AM
tel: 0771 088 207
adistul@yahoo.com
Postat 28 October 2011 - 09:23 AM
Postat 28 October 2011 - 09:55 AM
Postat 28 October 2011 - 12:26 PM
skarp, la 28 October 2011 - 09:55 AM, a spus:
Postat 28 October 2011 - 03:01 PM
Postat 28 October 2011 - 06:26 PM
Postat 29 October 2011 - 09:41 AM
Postat 29 October 2011 - 10:07 AM
Postat 31 October 2011 - 11:40 AM
Postat 31 October 2011 - 12:19 PM
#19
Postat 13 November 2011 - 11:36 AM
#21
Postat 13 November 2011 - 08:53 PM
Am o coca (90cm lungime si 30cm latime)cu 2 cuve ,va rog ajutati-ma cu o lista completa cu piese necesare pt barcuta
nu prea ma pricep de acea va rog sa ma ajutati
#22
Postat 13 November 2011 - 09:29 PM
#23
Postat 13 November 2011 - 10:13 PM
Aceasta postare a fost editata de skarp: 13 November 2011 - 10:14 PM
#24
Postat 13 November 2011 - 10:15 PM
#25
Postat 14 November 2011 - 12:09 PM
Aceasta postare a fost editata de skarp: 14 November 2011 - 12:13 PM
#26
Postat 14 November 2011 - 12:15 PM
Pe barca merge pentru ca au fost montate sute sau chiar mii de bucati si la mine cel putin nu a venit nimeni inapoi cu voltmetru defect.
#27
Postat 14 November 2011 - 07:43 PM
