Modelism - RHC Forum: TURBINA + MOTOR 55 mm - Modelism - RHC Forum
TURBINA + MOTOR 55 mm noua
#1 Useril este offline   tantar
  • Postari: 2748
  • Inregistrat: 01-November 08
Postat 08 October 2011 - 04:02 PM
80 ron negociabil
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
#2 Useril este offline   Vreascu
  • Postari: 73
  • Inregistrat: 15-January 09
  • Interests:desenu, pictura, sculptura, motociclismul, tirul cu arcu, drumetiile si mai nu "zboru'"
Postat 08 October 2011 - 07:30 PM
Salutare...poti sa imi dai ceva detalii despre sistemele de 55 si 64 pe care le vinzi? In principiu ma intereseaza cat consuma si cam ce tractiune au....ca sa stiu cat de mare ar trebui sa fac avionu si ce esc si baterie mi-ar trebui.
P.S. am incercat sa iti trimit PM dar cred ca ai mesageria plina...
Aceasta postare a fost editata de Vreascu: 08 October 2011 - 07:31 PM
Nulla dies sine linea!
#3 Useril este offline   tantar
  • Postari: 2748
Postat 09 October 2011 - 06:43 AM
Vezi postareaVreascu, la 08 October 2011 - 07:30 PM, a spus:
64 mm
Uite aici specificatiile avionului pe care a venit este vorba de un rafale :
Specification:
Wingspan: 660mm
Length: 1000mm
Height: 305mm
Flying Weight: 610g
Channel: 4ch
Motor: 4100kv Brushless Outrunner
ESC: 30A
Servo: 3 x 9g
EDF: 64mm
Battery compartment size: 83 x 50 x 37mm
Si la cea de 55 mm
EDF55 w/ ADH300 Brushless Outrunner.
A good plug in and go system.
Spec:
Test Voltage: 11.1v
Test Current: 18A
Thrust: 470g
Power: 199.8w
Motor: ADH300L 4300kv
Outer Diameter: 58mm
Length: 42mm
Weight: 58g
Test Results:
@10v | 17A | 430g | 170W |
@11v | 18A | 470g | 199.8W
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#4 Useril este offline   Vreascu
  • Postari: 73
Postat 11 October 2011 - 09:32 PM
Mai este valabil? Daca da, iau eu setul de 55
