Modelism - RHC Forum: Hobbyking SS Heli Series 50-65A ESC - Modelism - RHC Forum
Hobbyking SS Heli Series 50-65A ESC ESC for Heli
#1 Useril este offline   Lego_Man
  • Postari: 196
  • Inregistrat: 24-August 10
Postat 15 September 2011 - 10:28 AM
Se vinde Hobbyking SS Heli Series 50-65A ESC cu suma de 80 RON.
De preferat in Bucuresti. Nu e nou, eu nu l-am folosit pentru ca nu se potriveste la proiectul meu si e greu de programat, asta trebuie stiut dinnainte, sa nu iasa probleme. Programarea corecta se poate gasi pe net, manualul nu e tocmai bun.
Iata si caracteristricile de pe site-ul de unde a fost cumparat initial:
The Hobbyking SS series comes with a limited range of programming functions and are designed to be plug-n-play.
A perfect ESC for those looking for something simple to use and economic.
Spec.
Weight: 40g
Cells: 4-10Ni MH ~ 2-4S Li Po
Max Current: 50A
Burst: 65A
BEC: 3A
Timing: 1/7/15/30 programmable
PWM: 8/16K
Features.
Constant current 50A Max 65A <10S
Li-Poly 2-4 cells Ni-MH 4-10 cells
Low Resistant 0.0014 Ohms;
Dynamic Braking
BEC: 3A
Auto shut down when lose signal
Slow down at 2.8V per cell Lipo, Cut-off at 0.8V/cell NiMh
User Programming options:
Battery setting
Throttle Range
Brake setting 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Governor mode
Soft start
Note;
FETs are Taiwanese, unlike our TURNIGY esc which use USA FETs. So we suggest customers to not draw more than the 50A rated capacity.
Pentru programare:
I got the same problem you guys faced while setting it up for a plane...
Here's how i work around it:
1. Program ESC to turn off throttle auto-range
2. Program ESC for hard-start
3. Power off ESC
4. Turn on Tx and set 5-6 clicks up trim on tx throttle channel
5. Pwr up ESC
6. ESC will not arm. Activate throttle cut to arm ESC.
7. Test the setup: Go full throttle, go min throttle, hold for 10sec. ESC should not want to re-initialize itself like before.
Now the ESC will never see a 0% in the full range of the throttle stick and will not re-initialise when throttle in min. position for >5sec. Btw, I'm using a DX6i.
The 5 clicks up will not be sufficient to spin the motor and my Emeter shows that current drawn is negligible (0.0A).
Hope this helps while we wait for HK to respond.
  • Fisier atasat  _9.jpg (212.58K)
  • Fisier atasat  _10.jpg (134.57K)
  • Fisier atasat  _11.jpg (135.32K)
#2 Useril este offline   valyman
  • Postari: 167
  • Inregistrat: 11-October 09
Postat 17 September 2011 - 07:32 AM
Unde se poate gasi pe net programarea ? Am aceeasi problema ....se initializeaza de fiecare data cand mansa sta inactiva la pozitia minima , mai mult de 5-6 secunde, apoi trebuie calibrat din nou throttle-ul.
Te rog , daca e posibil, sa pui adresa aici .
Multumesc , si spor la vanzare !!!!
#3 Useril este offline   Lego_Man
  • Postari: 196
Postat 22 September 2011 - 09:22 AM
Pret nou: 75 ron.
Up.
#4 Useril este offline   Lego_Man
  • Postari: 196
Postat 04 October 2011 - 12:05 PM
Pret nou: 70 ron.
Up.
#5 Useril este offline   Lego_Man
  • Postari: 196
Postat 24 October 2011 - 02:33 PM
Up.
#6 Useril este offline   Lego_Man
  • Postari: 196
Postat 02 November 2011 - 01:17 PM
Up.
#7 Useril este offline   Lego_Man
  • Postari: 196
Postat 09 November 2011 - 06:27 PM
Up.
Pt configurare:
http://www.dys.hk/Do...A%20W%20BEC.pdf
si explicatiile la :
http://www.rcgroups....d.php?t=1306198
Aceasta postare a fost editata de Lego_Man: 09 November 2011 - 06:29 PM
#8 Useril este offline   Lego_Man
  • Postari: 196
Postat 17 November 2011 - 02:58 PM
Up.
#9 Useril este offline   Lego_Man
  • Postari: 196
Postat 24 November 2011 - 03:57 PM
Up.
#10 Useril este offline   Lego_Man
  • Postari: 196
Postat 02 December 2011 - 09:42 AM
Up
#11 Userul este online   as2008
  • Postari: 733
  • Inregistrat: 04-May 10
Postat 04 November 2016 - 03:56 PM
Vezi postareaLego_Man, la 02 December 2011 - 09:42 AM, a spus:
Up
buna ziua , anuntul este vechi , dar trebuie sa intreb daca mai este valabil , va rog raspuns pm , multumesc
#12 Userul este online   as2008
  • Postari: 733
Postat 28 May 2017 - 06:24 AM
Vezi postareaas2008, la 04 November 2016 - 03:56 PM, a spus:
esc mai este valabil? , multumesc de raspuns
#13 Userul este online   as2008
  • Postari: 733
Postat 04 June 2017 - 06:17 AM
Vezi postareaas2008, la 28 May 2017 - 06:24 AM, a spus:
nimic?
