Salutare tuturor,
M-am hotarat sa vand urmatoarele articole:
1. Elicopter flybarless Walkera V200D02
- elicopterul este nou ( are 5 zboruri)
- 3 baterii rezerva
- 1 set piese rezerva inclus + 2 seturi pale+ capota rezerva
- video demontrativ: youtu.be/JolTNzWbiM4 - primul cadru din lista (copiati adresa pe youutube)
- Main Features
■The design of flybarless balance characterizes low power loss and great efficiency improvement.
■Three-Axis-Gyro in receiver control makes the flybarless balance system automatically amend the flight status and provide favorable safety for the beginners.
■Compact swashplate structure is adopted and with light and fine fuselage, it is super stable to fly.
■New 2.4G technology, with the functions of identification and precise code pairing, can allow above 20 aircrafts to fly in the same field and same time.
■The flying time can reach 9minutes-11minutes for one battery cycle with the high perfor mance brush motor and the high capacity Lipo battery.
Specification Walkera V200D02
■Main Motor: 370SH motor
■Tail Motor: 1225FC35
■All-up Weight: 268g (Battery included)
■Tail Rotor Diameter: 94 mm
■Main Rotor Diameter: 440 mm
■Overall Length: 432 mm
■Gyro: Three Axis
■Receiver: RX2440V
■Battery: 7.4V 1000mAh Li-Po
Pret: 150 Euro
TEL : 0729066880 / demo pe Chitila la cerere
2. Avion EPO electric FMS P-51 Mustang
- anvergura 1,45 m
- lumini navigatie
- tren retract fata + spate
- firewall intarit, retract intarit si aripi lipite + bara carbon in eleroane si stabilizator vertical
- avionul are 12 zborurui si este perfect functional si trimat
- motor brushless foarte puternic
- in pret sunt incluse servo-uri rezerva, retract rezerva si 4 baterii 4S- 3.700 maH ( utilizate de 12 ori).
- caracteristici de zbor foarte bune
- date tehnice:
Specification:
Wing span: 1450mm
Total Length: 1240mm
Weight: 1900g
Wing construction:EPOFLEX
Fuselage construction: EPOFLEX
Stablazer/Fin construction: EPOFLEX
Finishing (Wing): Painted
Finishing (Fuselage): Painted
Propeller: 4-Blads
Motor: FMS KV500 Brushless-motor
ESC: 50A Brushless Programmable ESC with 5A BEC
Transmitter (recomend): 6-Ch. 2.4GHz Radio system
Receiver (recomend): 6-8Ch. 2.4GHz Receiver
servo (recomend): 6 x FMS Metal 9g,1 x 17g Servos
Battery (recomend): 4S 14.8V 2400-3200mAh Li-Po Battery
Technical Nots:
The FMS P-51 V8 Mustang of the legendary North American is currently one of the largest and highest quality scale EPO warbird in the market with a wing span over 1450mm. This model has a lot of scale details molded on the EPO Fuselage and on the EPO wings with a very detailed canopy, Retractable landing gear, 4-blades propeller and stickers which make an excellent scale-look for the airplane. The new version has also position-light system include tail-retractable landing gear. The model construction is EPO which is very robust and flexible material that can be repaired with CA or Epoxy glue in very short time. The model is for intermediate to advanced pilots who wants a big electric scale-look airplane for more fun flying. This model comes with Pre-Installed electric main/tail retracts and flaps. All servos, ESC and Brushless motor are already installed and ready to use. The model is easy to assemble and transport. All what you need to fly the model is a 6Ch radio, Receiver and 4S 2400-3200mAh Lipo Battery
- video: youtu.be/jllFZdDuyDA / primul din lista pe youtube (copiati adresa pe youtube)
3. Avion ESM Hawker Sea Fury
- avion nou, in cutie - balsa, 2,03 m anvergura, flaps, retract - superb
- contine : Item Description Price (€) Amount Total (€)
ESM-W048 ESM Hawker Sea Fury Model Airplane ARF (203cm, 8kg, 40cc) 359,00 1
359,00
ESM-W048-E Electric retract system for Sea Fury 169,00 1 169,00
ESM 4.5" rubber tires, alu hub 18,00 2 36,00
ESM 1.75" rubber tires, alu hub 13,00 1 13,00
BPSE2400 4" (10.2 cm) Aluminium 2-Blade Spinner 29,00 1 29,00
ESM-S0035-1 Spinner Nut 50cc (10mm) 18,00 1 18,00
SM-S4481M
Very Strong Fast Digital (15.2 kg / 0.13 sec / 63 gr)
2 x Aileron, 2 x Flaps, rudder, elevator
29,90 6
179,40
B22210RSCBY 22x10" Biela 2-blade semi scale propellor 47,00 1 47,00
BPHWFJ450 45cm heavy duty twisted wire extension JR/Futaba (2 pieces) 4,00 1 4,00
BPHWFJ600 60cm heavy duty twisted wire extension JR/Futaba (2 pieces) 4,50 1 4,50
0,00
Subtotal 858,90
Shipping 127,00
Discount 135,90
Total 850,00
VAT 19% 135,71
- avionul este ARF si contine toate elementele descrise mai sus
- prezentare, date tehnice si video: http://www.troybuilt...FURY-80FAF.html
Pret: 850 EURO
Tel: 0729066880 /Daniel
AVIONUL SE VINDE CU MOTORUL SPECIAL COMANDAT PENTRU EL: Saito FG-57 twin
- motor cu cilindree 57 cc / 4 timpi/ benzina
- 4,4 cai putere
- motorul este rodat pe banc (3 litri benzina consumati) pozitionat optim si echilibrarea temperaturilor pe cilindri
- uleiul folosit este Motul 800 Road Racing / 5%
- video: youtu.be/vz0maw3Auys - primul din lista (copiati adresa pe youtube)
- descriere: http://www.espritmod...gine-300tl.aspx
Pret: 900 Euro
Pentru cei interesati va stau la dispozitie cu detalii si probe live / Chitila
vanzare elicopter/ avion/ motor termic + accesorii
