probleme la telecomanda Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)
Postat 26 July 2011 - 10:41 AM
:clapping:
tel. 0723693168
tel. 0766646477
id. mess. yulyyan
Postat 26 July 2011 - 01:17 PM
Tot aproape sigur este o problema de calibrare. Fa asa:
1. Intra aici: http://www.sgr.info/...io/download.htm si download-eaza programelul ala (DigitalRadio) si instaleaza-l.
2. Leaga cablul, seteaza trimurile si stick-urile pe 0.
3. Porneste secventa de calibrare (ai un buton sus - mai in dreapta).
4. DONE
Daca vrei poti sa ii dai tipului cu programul 2$ prin Paypal si ti-l inregistrezi si ai varianta Full. Daca vrei sa tii telecomanda eu zic ca merita.
Postat 26 July 2011 - 01:24 PM
Using this procedure you can to recalibrate the A-D encoders for the joysticks, the trims and the
knobs. Be careful with this function, because you change the internal parameters of the radio. So
after a calibration even if you didn’t change your settings you may have a difference in the servo
movements.
During the calibration you have to move the sticks and the trims at their extreme position, in this
way:
1. Sticks at the extreme left and down position, trims on the left or down position
2. Sticks at the extreme right and up position, trims on the right or up position
3. Move the knobs at their extreme position
4. Press Stop Calibration
During the calibration procedure no data are received from the radio, the power led on the radio
and the Sync light on the software flash. All the user interface, except the Stop Calibration button,
is disable.
Aceasta postare a fost editata de torelu: 26 July 2011 - 01:25 PM
Postat 26 July 2011 - 03:26 PM
tel. 0723693168
tel. 0766646477
id. mess. yulyyan
Postat 26 July 2011 - 04:22 PM
yyulyyan, la 26 July 2011 - 03:26 PM, a spus:
scuze torelu :) te-am botezat
am facut asa cum ai spus tu cu programul ala dar am luat demo si pe program functioneaza doar canalul 4 nu merge sa o recalibrez
Aceasta postare a fost editata de yyulyyan: 26 July 2011 - 04:25 PM
tel. 0723693168
tel. 0766646477
id. mess. yulyyan
Postat 26 July 2011 - 06:31 PM
Postat 26 July 2011 - 11:06 PM
Oricum afara e cald si-mi place berea rece!
:clapping:
La fel e si cand esti prost.
tel: 0771 088 207
adistul@yahoo.com
Postat 27 July 2011 - 03:13 PM
:good:
Spor!
tel: 0771 088 207
adistul@yahoo.com
Postat 27 July 2011 - 06:33 PM
Dar acum merge asta este iportant :good:
torelu, la 27 July 2011 - 09:51 AM, a spus:
Pana la urma ai cumparat-o de la un magazin de la noi? Ca altfel nu se merita cu garantia...
Ia legatura cu Adistul pt rc
tel. 0723693168
tel. 0766646477
id. mess. yulyyan
Postat 27 July 2011 - 06:34 PM
torelu, la 26 July 2011 - 04:05 PM, a spus:
De ce iti trebuie numarul meu?
nu mai este cazul
tel. 0723693168
tel. 0766646477
id. mess. yulyyan
Postat 06 August 2011 - 04:57 PM
Postat 13 August 2011 - 05:33 PM
sumerr, la 06 August 2011 - 04:57 PM, a spus:
ESTE ACEEASI RC DOAR CA ARE ARC PE STANGA
tel. 0723693168
tel. 0766646477
id. mess. yulyyan
Postat 23 August 2011 - 02:23 PM
