Conversie ST1 Pro de la TT din termic in electric Din ciclul "Cind omul se plictiseste!"
Postat 20 February 2011 - 01:39 PM
In topicul asta voi incerca prezentarea unei variante ECO al lui Thunder Tiger ST1 Pro.
Masinutza a fost achizitionata vara tracuta dar a cam stat pe tusa din lipsa de timp.
Caracteristici generale ale originalului:
Manufacturer:.............Thunder Tiger
Model:....................ST-1 RTR
Wheelbase:................13.7"-14.4" (349-365mm) adjustable
Width:....................15" (380mm)
Weight:...................8.64lbs (3920g)
Length:...................19.1" (485mm)
Height: ..................7.2" (182mm)
Front Track:..............13.1" (335mm)
Rear Track:...............13.6" (345mm)
Ground Clearance:.........1.9" (48mm)
Chassis type: ............3mm 7075 with radiused edges and front kick-up
Drive train type:.........CVA Shaft-drive 4WD, ALL-METAL CVA Center Driveshafts
Primary: .................13T clutch bell / 50T spur gear
Clutch type: .............3 shoes composite medium springs
Transmission ratio: ......4.3:1
Final drive ratio: .......16.54:1
Differential:.............Sealed bevel gear
Engine: .......Thunder tiger PRO-28BX-R with pullstart. 2 needle slide carburator Displacement: 4.63 cc. / 0.282 cu. in. Bore: 18.30 mm. / 0.720 in. Stroke: 17.6 mm. / 0.693 in. Practical RPM: 3,000 ~ 35,000 Weight: 460 g. wo/muffler
Steering servo: Ace Jaguar S2008MG Metal gear, 111oz
Throttle/brake servo: Ace Jaguar S2008MG Metal gear, 111oz
Postat 20 February 2011 - 01:42 PM
Postat 20 February 2011 - 01:50 PM
Pentru trecerea pe electric m-am oprit momentan la o echipare de criza: :pardon:
1. Motorul:
Caracteristici:
Motor: KD36
Kv (rpm/v) 1900
Weight (g) 370
Max Current (A) 75
Resistance (mh) 0
Max Voltage (V) 0
Power(W) 0
Shaft A (mm) 5
Length B (mm) 75
Diameter C (mm) 36
Can Length D (mm) 73
Total Length E (mm) 91
Coolerul motorului:
(Heat Sink with Fan for 36 series motors)
Spec.
Inner diameter: 35.55mm
Dimentions: 51 x 55 x 63mm (whole unit)
Weight: 75g
Regulatorul: HK150A
Specification:
Cont./Burst Current: 150A/1080A
Resistance: 0.0002 ohm
Suitable Car: 1/5, 1/8 on-road and off-road cars / trucks For competitive race
Suitable Brushless Motor: 3.5T (3660)
Battery: 6-18 cells Ni-xx (NiMH / NiCd) 2-6 cells Li-Po
BEC Output: 6V/3A of switch mode built-in BEC
Motor Type: Sensorless and sensored brushless motor
Dimension: 55(W)*60(L) *40(H)
Weight: 150g
Postat 20 February 2011 - 02:10 PM
1. Varianta simpla: electronica pe o parte, pakurile grupate pe cealalta
2. Varianta mai costisitoare dar care zic eu ca ar asigura o echilibrare mai buna a masinii:
Pakurile postate pe lateralele masinii.
PS: Decizia finala sper sa nu influentatata de cum pica carcasa! :pardon:
Aceasta postare a fost editata de Dragut: 20 February 2011 - 02:12 PM
Postat 20 February 2011 - 02:18 PM
Prinderea motorului.
Motorul original (cel termic) era prins pe sasiu.
Sa-l prind identic pe cel electric e delicat:spatiul de sub motor e infim, ca atare exista riscul ca tablitza de dedesupt sa se indoaie, sa se strice jocul danturii si sa nenorocesti fie spurul fie pinionul
Aceasta postare a fost editata de Dragut: 20 February 2011 - 02:19 PM
Postat 20 February 2011 - 02:26 PM
Postat 20 February 2011 - 03:10 PM
Spor la treaba!
Postat 20 February 2011 - 03:53 PM
1. Excelenta alegere de buget a modelului, motorului si ESC-ului. Cardul de programare al ESC-ului e ieftin, poate gasesti unul, e foarte util.
2. Poti echilibra modelul si cu acumulatorii pe o parte si motor+ESC pe cealalta parte, motorul e destul de greu si acumulatorii sunt mici si usori.
3. Daca ai in vedere participarea la concursuri, vezi ca mansele sunt de 10 minute, trebuie sa cronometrezi cat te tin acumulatorii sa nu ai surprize.
4. Indiferent de cum alegi sa plasezi acumulatorii, incearca sa ii pui cat mai spre interiorul modelului, eventual nu pe marginile laterale de plastic care pot ceda usor la un impact lateral. De aceea eu as opta pentru ambii acumulatori pe o singura parte, cat mai apropiati de cardan.
5. La prinderea motorului, "placa motor" este absolut suficienta (vezi majoritatea kiturilor electrice aparute pe piata). Asadar, distantierele pot lipsi, iar ca "placa fata" se poate folosi cea pe care o ai deja.
Spor la mesterit!
Postat 20 February 2011 - 08:10 PM
petrix, la 20 February 2011 - 03:10 PM, a spus:
Spor la treaba!
Fain motorul 3,6kw nu-i joaca da-i scoate la 36V si o sa-ti pape un minim de 98A.
Kv e ok ptr numarul asta de celule. Trebuie avut insa grija sa-ti reziste transmisia.
Postat 20 February 2011 - 08:36 PM
ovidiugm, la 20 February 2011 - 03:53 PM, a spus:
Spor la mesterit!
@Ovidiu
Nu permit chiar am rugamintea de a participa la discutii.
Luam pe puncte:
1. Cardul de programare exista.
2. accu nu-s asa usori (de asta am inirziat cu raspunsul).
- motor + cooler = 456 grame
- regulator = 192 grame
- 2 x accu 4000 = 536 grame
Diferenta e de 112 grame (mot+ reg)-2xaccu
3. Tinind cont ca suportul accu il fac eu pot jongla cu dimensiunile suportului de pack ... iar pakurile luate pot fi folosite pe buggy.
4. Mi-am pus si eu problema sa fac numai placa spate dar ca om patit si tinid cont ca-s doar "mecanic sef" in echipa Dragutilor am incercat sa iau in calcul ce se intimpla la impact cu suportul ala.
PS: feciorul are boala la sarit si busit :lol:
Aceasta postare a fost editata de Dragut: 20 February 2011 - 08:37 PM
Postat 20 February 2011 - 08:45 PM
Ady., la 20 February 2011 - 08:40 PM, a spus:
Daca vrei piesa finita o gasesti in afara pe la 45 USD.
Daca vrei materialul in sine gasesti la Color Metal din Odorheiu platband allu ptr prelucrare CNC lat 80mm gros 15mm
PS: ce masina ai?
Aceasta postare a fost editata de Dragut: 20 February 2011 - 08:46 PM
Postat 20 February 2011 - 08:54 PM
Dragut, la 20 February 2011 - 08:45 PM, a spus:
PS: ce masina ai?
Am un Ansmann Virus si nu prea as vrea sa il dau a fost prima mea masina si...are o valoare sentimentala pentru mine:D
Poti sa-mi dai in privat linkul cu piesa?:lol: eventual si cu marerialul pentru prelucrare?
Postat 20 February 2011 - 08:55 PM
Vezi aici http://www.rc-monster.com/rcm.php?pg=2
sau discutam in limita timpului disponibil.
Postat 20 February 2011 - 08:57 PM
Electronica
Sasiul gol
deci greutatea e cam peacolo
Termic: 3920 grame la ei fara combust + 150 grame comb = 4070
Electric: 3000 + 1177 = 4177
Mai grea cu 100 grame. ... Mh nus daca valorile lor sunt chiar reale. dar ne apropiem oricum binisor ca greutate
Aceasta postare a fost editata de Dragut: 20 February 2011 - 09:02 PM
Postat 20 February 2011 - 09:11 PM
Kv = 1900 rpm/V
tensiune: 14,4 V
RPM maxim: 27360 rpm
Rapoarte de transmisie:
1. Pinion spur: 12/54
2. din dif central / roata ~4 (pe masuratelea pe model)
Raport total: 18
Turatie la roata: 27360 / 18 = 1520 rpm
Diametru roata: 140mm
Perimetru: pi x 0,14 = 0.439 m
Viteza: turatie roata x Perimetru = 1520 x 0.439 = 668.53 m/min x 60 min = 40111.86 m/h = 40.11 km/h
Postat 20 February 2011 - 09:29 PM
KD36-74-06XL cu Kv 2800 pentru care viteza creste la 60km/h la 110 A
Am considerat tot seria XL
Celelalte au turatie dar n-au forta!
Aceasta postare a fost editata de Dragut: 20 February 2011 - 09:31 PM
#19
Postat 23 February 2011 - 03:23 PM
Deja de 10 ori am incercat sa comand de la ei si nimic.
In fine,bafta si sa vedem niste clipuri cu ea.
Aceasta postare a fost editata de petrix: 23 February 2011 - 03:24 PM
#21
#22
Postat 01 March 2011 - 09:16 PM
Mult succes in continuare. Abia astept sa vad rezultatul finit.
DJI Mavic Pro
#23
#24
Postat 02 March 2011 - 02:59 PM
Fie, parerile sunt impartie. :pardon:
Aceasta postare a fost editata de Ady.: 02 March 2011 - 03:02 PM
#25
Postat 03 March 2011 - 07:49 PM
Ady., la 02 March 2011 - 02:59 PM, a spus:
Fie, parerile sunt impartie. :)
Hehe mosule aicea va asteapta o alta surpriza de proportii de data asta.
Detalii despre ea abia dupa 26 martie.
In alta ordine de idei: un hardcase din lexan de 2 ... + amortizoare de soc la capete...
Ps: miine sper sa va arat finalul la pesa de fixare a motorului.
#26
Postat 03 March 2011 - 10:18 PM
Fie, parerile sunt impartie. 8)
Am aceeasi masina electrica echipata cu Tekin, e-revo este jucarie de carrefour pe langa ea.
#27
Postat 03 March 2011 - 10:34 PM
bogdan luben, la 03 March 2011 - 10:18 PM, a spus:
Totusi este o diferenta intre clase Truggy vs MT. Avand aceeasi electronica, e-revo s-ar putea sa stea in spatele ST1-ului, dar relativ aproape......in comparatie cu alte MT-uri 8)
Am avut un ST1, nu varianta PRO si am fost multumit,
Aceasta postare a fost editata de daniel_hnatec: 03 March 2011 - 10:36 PM
Schumacher Mi4LP
Hobao Hyper Competition ST
Hobao Hyper 7
LRP S8BX team X 2
LRP S8BX
Traxxas Revo => crawler
Hpi Wheely King
Sanwa M11X
#28
Postat 11 March 2011 - 12:05 AM
Mi-au dat ceva batai de cap la gaurile de fixare in sasiu (asa e omul care se invata numai cu CNC-ul :good: ) dar a iesit OK
S-a finalizat si fixarea harcase-ului
Suport cu motor fixat provizoriu
Inca din timpul prelucrarii am considerat ca "pesa" e suficient de tzeapana incit sa nu mai necesite modificarea piesei dinspre fatza
Mai trebuie fixata si piesa de protectie
Nu bagati in seama spanul! :)
Aceasta postare a fost editata de Dragut: 11 March 2011 - 12:05 AM
#29
Postat 11 March 2011 - 12:17 AM
Am facut un distantier cu h = 10mm din plexic ca sa ma ridic peste moturile de plastic ale fixarii lateralelor (am apreciat mult faptul ca baietii de la TT s-au gindit ca un filet de 2-3mm dat in plastic n-ar fi suficient!)
S-a fixat pe spate in cele 2 gauri originale in care venea aparatoarea de la electronica (acum disparuta) + o gaura suplimentara
Pe interior suruburi cu cap inecat cu filet tot in placa de 10
Fixare interioara
Fixare pe spate
Pina in wekend sper sa bag servo sa-i fac jocul in pinion si sa bag o tura cu el sa vedem ce zice!
#30
Postat 12 March 2011 - 07:39 PM
Masina se misca BESTIAL!!!!
NU are superviteza ....estimez un 35-40km/h (m-am asteptat la asta din KV motorului) dar e perfect controlabila chiar la viteza mare.
Cind ma intorc voi face si filmulete.
Varianta de asezare finala:
Aceasta postare a fost editata de Dragut: 12 March 2011 - 07:41 PM
