Modelism - RHC Forum: Intrebare. - Modelism - RHC Forum
Intrebare. Ajutor...
#1 Useril este offline   LEON13
  • Postari: 104
  • Inregistrat: 06-November 09
  • Interests:NAVOMODELISM
Postat 16 February 2011 - 06:47 PM
Salutare...
Pot sa folosesc un sistem radiocomanda E-FLY B62 2.4GHz, 6 canale pe un navomodel?
Caracteristici:
- Fully proportional
- Servo reverse function
- Using advanced technology of digital frequency hopping and inserting address code, the limited spectrum can be fully utilized to avoid interference with the same frequency
- Using highly-integrated frequency synthesizing technology, the microprocessor can automatically preset and set frequencies.
- With new digital technology, 2.4GHz remote control system is no need to change crystal
- Power amplifier works only at the time when data is being transmitted, thus shortening the working time, so as to extending the using times of remote controller after a charge
- 2.4 GHz wireless remote control system has short antenna length. The length of the antenna is usually 1/4 of the frequency wavelength.
Specificatii:
Numar de canale: 6
Modulatie: 2.4 GHz
Tensiune operare: 9...12 V
Raza de actiune: > 800 m la sol si >1200 m in aer
Dimensiuni: 180 x 160 x 60 mm
Masa: 500 g (fara acumulatori)
  • Imagine atasata: 27558.jpg
#2 Useril este offline   LARY
  • Postari: 559
  • Inregistrat: 31-October 09
  • Interests:VA SALUT CU RESPECT
Postat 16 February 2011 - 09:32 PM
Nu, nu poti folosi aceasta telecomanda la navo. Din descrierea producatorului reiese ca are o raza de actiune de 1200 m aero si 800 m la sol, deci pe apa nu merge.
#3 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2401
  • Inregistrat: 01-December 08
Postat 16 February 2011 - 10:44 PM
LEON13 ,salut merge foarte bine la barca de nadit ,am avut eu una din asta pe o barca de nadit si sigur duce 500de metri testata de mine ,poate se mai ducea dar nu o mai vedeam nici cu binoclu ! :)
nu o sa plantezi nici-0 data la o distanta mai mare de 300 de m si asa e cam mult !
Aceasta postare a fost editata de stelian: 16 February 2011 - 10:46 PM
facebook
0721 241 744 VODAFONE
0762 028 013 COSMOTE
#4 Useril este offline   ipsihi
Postat 16 February 2011 - 10:51 PM
Vezi postareaLARY, la 16 February 2011 - 09:32 PM, a spus:
...cum ai ajuns concluzia asta?!!!
Aceasta postare a fost editata de ipsihi: 16 February 2011 - 10:51 PM
#5 Useril este offline   LEON13
  • Postari: 104
Postat 16 February 2011 - 11:20 PM
Deci o sa iau in considerare ce au spus din bransa OLD SCHOOL si le multumesc..
Nu are nimic daca nu folosesc toate canalele?
Postat 16 February 2011 - 11:41 PM
...o poti folosi in toate pozitiile posibile pe care ti le imaginezi, se duce lejer 300m cu conditia sa pozitionezi corect receptorul in barca, sa scoti in exterior macar una din mustati ,de preferat la receptorul asta este sa-l proptesti in punctul cel mai inalt al barcii !!!
