Sistem FPV 900-1000Hz Intrebari cu privire la sisteme FPV
Postat 26 January 2011 - 05:55 PM
Am vazut la sectiunea frecvente ca frecventa de 900-1000Hz pentru sisteme FPV nu apare.
Intrebarea mea este:
Daca sistemul care vreu sa il cumpar este : 900MHZ 200mW Tx/Rx & 1/3-inch CCD Camera NTSC , il voi putea folosi? Ma va verifica cineva? Mi se va confisca la vama ?
Mai multe detalii despre sistem ( se gasesc si il linkul de mai sus):
Camera spec.
CCD sensor type:1/3 color SONY CCD
Pixel;
NTSC: 510(H)*492(V) (included)
PAL: 500(H)*582(V)
Scanning system: Interlaced scanning
Synchronization: System:Inter
Horizontal resolution: 420TV line
Minimum Illumination 0.01LUX/F1.2
DSP+CCD: CXD3142R+405AK
S/N Ratio: 48dB
Gamma Modification: 0.45
White balance: Auto
Auto backlight compensation: Auto
Lens: 3.6MM
Audio: No
Input voltage: 9~12.6V
Electric current 80MA
Electronic Shutter: 1/50 (60) ~ 1/100,000s
Video output: 1.0VP-P composite video
Operation Temp.: -20~50
Flight time: Approx 60min/100mah 3S
FPV Tx Spec.
Channel: 4-Ch, AV synchronization
Power: 200mW
Input voltage: 12V
Weight: 18g
Frequency: 0.9G 0.910G,0.980G,1.010G,1.040G
Postat 26 January 2011 - 06:06 PM
Aceasta postare a fost editata de mugurg: 26 January 2011 - 06:06 PM
Postat 26 January 2011 - 06:17 PM
mugurg, la Jan 26 2011, 07:06 PM, a spus:
Cum merge cel de 1000mW ?
Ce citeam eu despre asta de 200mW e ca ar merge destul de bine , iar daca ii mai pun si alte antene la TX si RX merge super.
Postat 26 January 2011 - 07:05 PM
Chestiunea nu-i daca te controleaza cineva, chestiunea este ce ai putea deranja la acea putere si la acea frecventa...
Spunea Tiriac: ''daca in lumea civilizata scrie interzis pe o usa, nu incearca nimeni sa intre. La noi este exact contrarul...''
Postat 26 January 2011 - 07:29 PM
Postat 26 January 2011 - 09:27 PM
Postat 26 January 2011 - 09:43 PM
daca ar fi sa iau un 2.4GHZ 100mW la frecvente :
2.4G 2.410G/2.430G/2.450G/2.470G
ar avea interferente cu Telecomanda de 2.4 care o am deja ?
OBS: Vad ca in regulament scrie:
"Dispozitive cu raza mica de actiune destinate aplicatiilor
nespecifice:
2400 - 2483,5 MHz / RO-IR 001
Asta inseamna ca am voie ?
Postat 26 January 2011 - 09:54 PM
BIbiricat, la Jan 26 2011, 09:19 PM, a spus:
Teoretic da, insa daca esti discret nu ar trebui sa ai probleme. Renatoa a expus pe scurt care sunt optiunile noastre.
Transmitatorul 2.4 video iti "orbeste" receptorul RC(tot in 2.4) si nu merge.
Aceasta postare a fost editata de Zen: 26 January 2011 - 10:04 PM
Postat 27 January 2011 - 01:13 AM
Va prezint un scenariu: Modelul, echipat cu un emitator puternic, pe o frecventa alocata altor aplicatii, este trimis, orbeste, la distanta de kilometri. Nu stii peste ce trece si ce necazuri face. Poti sa fii sigur ca este ceva nevinovat?
Zic si eu si va promit sa nu mai intervin in subiect.
Multa bafta.
Postat 27 January 2011 - 04:13 AM
dan_mitea, la Jan 27 2011, 01:13 AM, a spus:
Multa bafta.
In 900mhz cu 200mw si antene de 5db pe emisie si 5db pe receptie, distanta maxima calculata este de 1.669 Km.
Scenariul PICA
Aceasta postare a fost editata de zgr_44: 27 January 2011 - 04:17 AM
Postat 27 January 2011 - 04:27 PM
BIbiricat, la Jan 26 2011, 10:25 PM, a spus:
Intra la sectiunea FPV de la Aeromodelism si citeste tot ce e acolo, nu e foarte mult pentru ca sectiunea e relativ noua. Eu zic ca e un minim, sa-ti faci o idee despre complexitatea problemei.
In urma concluziilor pe care le-am tras si sfaturilor primite(nu doar de pe rhc) o sa merg pe un set Lawmate 1.2/1.3 GHz 500mW - canalele superioare sunt practic tot ale hobistilor (HAM) deci nu poti provoca nimic grav, in rest e curata banda. Te feresti in felul asta si de RC-urile 2.4(si nu numai...) si de telefoanele 0.9, insa nu inseamna ca e cea mai buna solutie. Depinde de stilul tau de zbor, de cat de departe vrei sa zbori, de buget,etc.
