Se poate sa dau la aviatie?
Postat 03 June 2010 - 09:43 PM
buna tuturor! la fel ca si multi altii care au inceput un astfel de topic si eu am 17 ani si la fel ca si eu vreau sa ajung in aviatie. problema e ca nu vad prea bine si trebuie sa fac operatie in ianuarie cand devin major sa imi indrept vederea...ma impiedica acest lucru in a deveni pilot?
Postat 04 June 2010 - 10:45 AM
BogdanStancu, la Jun 4 2010, 11:20 AM, a spus:
Daca nu esti perfect, n-ai ce sa cauti la naviganti. Pacat.
Cred ca te referi la aviatia militara. La aviatia civila e altfel. Uite un paragraf din baremele europene JAR-FCL3, care se aplica la noi in RO.
Distant visual acuity. Distant visual
acuity, with or without correction, shall be 6/12
(0,5) or better in each eye separately and visual
acuity with both eyes shall be 6/6 (1,0) or better
(see JAR–FCL 3.340(f) below). No limits apply to
uncorrected visual acuity.
(B ) Refractive errors. Refractive error is
defined as the deviation from emmetropia
measured in dioptres in the most ametropic
meridian. Refraction shall be measured by
standard methods (see paragraph 1 Appendix 13 to
Subpart C). Applicants shall be [ ][assessed as] fit
with respect to refractive errors if they meet the
following requirements.At the initial examination the
refractive error shall not exceed [ ][+5 to-8] dioptres (see paragraph 2 ©
Appendix 13 to Subpart C)[....]Cataract surgery, retinal surgery and
glaucoma surgery entail unfitness.
Aceasta postare a fost editata de BIGfoot: 04 June 2010 - 10:45 AM
Fly to live
Live to fly
Live to fly
Postat 04 June 2010 - 11:51 PM
Si eu am probleme cu vederea ,dar totusi am trecut tooate examenele medicale cu brio ! Port lentile la zbor.Daca problema nu e extrem de grava se poate zbura si asa dar o sa ai muulte restrictii si repeti examenele medicale mult mia des !
Eu zic sa mergi totusi dupa operatie sa i-ti faci examenul medica lsi vezi acolo ce zice nenea ala.
Aceasta postare a fost editata de cybershot: 04 June 2010 - 11:51 PM
Rx: Futaba T6EXP,T14MZ , Airtronics MX-3.
Robbe Arcus,Multiplex Cularis , ,TwinStar,Twist 60, Alpha 40 DSM2, Easy Star,
T-Rex 250
Team Losi 8IGHT,,Kyosho Inferno GT roller
T-Rex 250
Postat 04 June 2010 - 11:59 PM
tudor93, la Jun 3 2010, 10:43 PM, a spus:
Ai grija cum formulezi cand postezi pe forum, ai cam zbarcit-o la inceput .
E nasol daca te exprimi asa la 17 ani, daca e forum de modelism asa nu inseamna sa trebuie sa ne exprimam la ca Ghiemboaia.
Ai grija ca te nominalizeaza moderatorul dupaia !
T-Rex 250
T-Rex 250
Postat 06 June 2010 - 09:02 AM
cybershot, la Jun 5 2010, 12:59 AM, a spus:
I-mi,i-ti, pe langa alte exprimari elevate din postarile tale.Inainte de a atentiona pe cineva de felul cum scrie, priveste putin si prin ograda ta.
Ai grija ca te nominalizeaza moderatorul dupaia ! :rolleyes:
Its nice to be important, but its more important to be nice ...
