Problema ESC Tower Pro MAG 8 25A
Postat 21 March 2010 - 03:57 PM
Pina azi a mers bine, adica pina in toamna anul trecut, azi am vru sa scot EG-ul la un zbor si surpriza, motorul tremura si se invartea sacadat.
Am verificat cu alt ESC si merge perfect motorul.
Am verificat firele la ESC si nu sunt rupte, BEC-UL functioneaza dar motorul tremura si sacadeaza.
Am citit undeva ca se poate reseta ESC-ul dar nu am gasit nicaieri cum se procedeaza.
Sau pote fi taimingul de vina?
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
Postat 21 March 2010 - 10:47 PM
Postat 22 March 2010 - 03:34 PM
Am luat manualul dar nu reusesc sa fac nimica cu el, nu ma lasa sa setez timingul.
Chiar nu stie nimeni cum se reseteaza un ESC?
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
Postat 22 March 2010 - 05:38 PM
...urmezi aceasi pasi ca la prima programare, adica duci mansa in pozitie extrema si apoi pornesti txul, dupa ce bipaie intri in program, citeste manualul!!!
...1. Open the transmitter, switch throttle stick to the full power position (for FUTABA series transmitter, the throttle stick shall be switched to REV).
2. Connect the receiver and motor.
3. Connect the power to the speed controller.
4. If the transmitter is in normal condition, it will have the following sound: (if there are no more sounds after a long low sound at the end of this sound, check the reverse setting of the transmitter throttle channel).
...vrei si traducerea?!!!
Aceasta postare a fost editata de ipsihi: 22 March 2010 - 05:40 PM
Postat 22 March 2010 - 06:33 PM
renatoa, la Mar 22 2010, 05:57 PM, a spus:
Ce faci cand ESC-ul nu se mai comporta ca in manual ?
Eu am unul in aceasta situatie ...
La pornire da beep-uri nedocumentate, cand e pornit cu mansa la maxim, nu scoate nici pas
Asculti beepurile si cauti un alt manual care are ceva asemanator.Unele fac beep dar nu executa nimic,indiferent ce faci.
Postat 22 March 2010 - 06:49 PM
Nu am fost suficient de clar, mea culpa...
Este vorba de unul care a mers si acum se comporta ciudat.
Am doua la fel, am manualul original, nu e nevoie de cautat ceva similar.
Cel care face figuri nu mai pune frana, scoate alte beep-uri si parca sa zic ca nu mai trage la fel ca celalalt.
Postat 22 March 2010 - 07:10 PM
@ipsihi nu ma intelegi, stiu cum se programeaza un ESC doar ca la acesta nu ma mai lasa sa merg decat pina la meniul de timing si nu vrea sa intre in el.
Eu chestia asta vreau sa o fac:
Factory parameter reset function: because this series of electronic governor has an overheating and false operation protective function, if you find that the speed controller is accelerating or changing is direction, or the throttle is different from the original condition, you can reset the factory parameters to obtain the highest performance.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
