Modelism - RHC Forum: Setare ESC - Modelism - RHC Forum
Setare ESC Cum sa setez ESC?
#1 Useril este offline   tnt
  • Postari: 1
  • Inregistrat: 24-March 09
  Postat 03 July 2009 - 06:18 PM
Salut!
Stie cineva cum sa setez ESC-ul la o masinuta electrica?
ESC-ul este EK2-0605 (40A) Are un singur buton "Set" si nu reusesc sa ma descurc.
Mai jos dau Paste la ce am gasit pe net si am tot incercat.. dar nu imi iese.
To Set up Your new ESC
Caution! After installation and when first connecting the battery or switching on the wheels or motor may run until setup has been carried out.
Setup Instructions
1. Before connecting the battery or switching on make sure that no damage or injury can occur from spinning wheels or propeller.
2. Set the throttle in the position you will use for neutral (engine off).
3. Connect the power and or switch on (Careful the motor may spin) The LED may flash and then go a constant red.
4. Using a pen or small screwdriver depress the "SET" button on the front face of the ESC The LED will flash - This has set the neutral throttle position.
5. Select full reverse and depress the "SET" button. The LED will flash - This has set the full reverse position.
6. Select full forward and depress the "SET" button. The led will flash - This has set the full forward position.
7. Turn off and turn on check that neutral and forward and reverse are correct. If as with some transmitters the motor is running opposite direction redo the set up with the forward and reverse in the reverse order.
Astept sfaturile voastre! Multumesc!
#2 Useril este offline   RAnet
  • Postari: 511
  • Inregistrat: 19-January 06
Postat 03 July 2009 - 06:47 PM
Vezi postareatnt, la Jul 3 2009, 07:18 PM, a spus:
Salut!
Setup Instructions
Incearca pasii urmatori:
1. Porneste emisia. Lasa acceleratia/frana in pozitia neutra.
2. Fara motor conectat, apasa butonul "SET" si alimenteaza ESC-ul tinand butonul in continuare apasat.
3. Dupa ce led-ul clipeste si ramane constant aprins rosu, elibereaza butonul "SET".
4. Din statie - frana maxima pana cand led-ul clipeste (fara a mai apasa butonul "SET" al ESC-ului)
5. Din statie - acceleratie maxima pana cand led-ul clipeste (fara a mai apasa butonul "SET" al ESC-ului)
6. OFF/ON - ESC.
Daca dupa conectareamotorului observi ca acesta se roteste invers fata de comenzile primite, iti recomand sa folosesti functia REV (reverse) din statie. Daca statia nu are asa ceva, reia toti pasii, inversand pasul 4 cu pasul 5.
Sper sa mearga asa.
In the laws of nature, there is nothing imposible except the state of your mind!..
Locuri de munca - Angajari - Companii: myFirstJob.ro
Publicitate aproape gratuita: tag-uri.ro
#3 Useril este offline   tnt
  • Postari: 1
Postat 03 July 2009 - 07:09 PM
Merge! Multumesc mult!
Se pare ca problema era motorul pe care nu il deconectam.
Multumesc inca o data!
#4 Useril este offline   RAnet
  • Postari: 511
Postat 03 July 2009 - 07:12 PM
Vezi postareatnt, la Jul 3 2009, 08:09 PM, a spus:
Ma bucur! Cu placere!
