am pus pe acromaster un ESC SUPPO (50A with external bec 3A)
setari din manual si cele cu rosu setate de mine
1-1 = NiCd
1-2 = 7 cell LiPo
1-3 = 6 cell LiPo
1-4 = 5 cell LiPo
1-5 = 4 cell LiPo
1-6 = 3 cell LiPo
1-7 = 2 cell LiPo
2-1 = Auto throttle range
2-2 = 1.1ms to 1.8 ms from Recvr
2-3 = Accelerate Fast
2-4 = Accelerate by ramp-up
3-1 = Normal (disable governor)
3-2 = Governor mode with 2-4 poles motors
3-3 = Governor mode with 6-10 poles motors
3-4 = Governor mode with 12-14 poles motors
4-1 = CW rotation
4-2 = CCW rotation
4-3 = Cutoff soft (When battery low)
4-4 = Hard cutoff
5-1 = 2 to 4 pole motors
5-2 = 6 to 8 pole motors
5-3 = 10 to 14 pole outrunner
5-4 = 10 to 14 pole outrunner Hi RPM
6-1 = 8 kHz PWM for low RPM
6-2 = 16 kHz for outrunners
toate bune si frumoase, dar, dupa o acceleratie full, dau stik-ul la zero, se aude o succesiune se sunete si anume: --~ (doua sunete scurte plus ton muzical) si • • • (trei beep-uri)
daca, dupa cele 3 beep-uri, duc mansa in full, intra in mod programare. daca astept cateva secunde (3-4) se accelereaza, dar nu in mod hard. apoi la prima pornire a motorului (dupa initializare) duc mansa in full, se accelereaza treptat, pana atinge turatia maxima (dureaza cam 2-3 secunde pana prinde turatia maxima).
acum intrebare:
am gresit eu ceva la setari sau este ESC-ul defect?
echipare model:
Servo Hitec HS-82MG (2 buc)
Servo TOWERPRO SG-90 Micro (2 buc)
</SPAN>AXI 2820/12
pack zippy 3s 2200mA 20C
ESC SUPPO defect sau eroare de programare
Postat 30 June 2009 - 06:59 PM
Postat 06 July 2009 - 12:43 PM
dupe N incercari si setari, concluzia este una singura: ESC defect.
sau... mai bine nu faceti ca mine, teste pe chestii ieftine si nesigure.
