Modelism - RHC Forum: Hitec Optic 6 - Modelism - RHC Forum
Hitec Optic 6 alimentare inversa
  • Lifetime Beginner
  • Postari: 3633
  • Inregistrat: 09-June 07
  Postat 21 June 2009 - 09:56 PM
Azi am fost la zbor si am ramas fara acc. in statie, am schimbat bateria dar am conectat gresit acc., am schimbat mufa si a mers fara probleme.
Acasa am incarcat acc. de la statie si am pus acc. in statie, surpriza, nu merge. Merge numai ledul de power, nu porneste displayul si nici nu piuie.
Care ar putea fi problema?
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
  • Lifetime Beginner
  • Postari: 3633
Postat 21 June 2009 - 10:28 PM
Exista vreu service Hitec in tara?
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
  • Lifetime Beginner
  • Postari: 3633
Postat 22 June 2009 - 08:13 PM
Ca prin minune merge.
Am conectat alimentarea invers si am pornit statia sa vad ce ii defect (sa scoata fum sau sa se incalzeasca) sa incalzit doar un condensator electrolitic smd si un integrat, cred ca ii un 324.
Am conectat invers (normal) si merge, cred ca condensatorul a ramas in scurt si la ultima inversare sa ars si a pornit statia.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#4 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 23 June 2009 - 08:36 AM
Daca gasesti, inlocuieste condensatorul ala (mai ales daca e si afumat nitel...)
Daca nu gasesti, roaga pe cineva sa ti-l schimbe :D
Ave
#5 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3633
Postat 23 June 2009 - 09:15 PM
Am sa il schimb cand o sa gasesc, am cautat in tot orasul, imi trebuie 10 microfarazi SMD dar nu am gasit. Mai caut dar daca nu gasesc pun unul normal ca am loc.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#6 Useril este offline   vld
  • Postari: 244
  • Inregistrat: 20-January 08
  • Gender:Not Telling
Postat 23 June 2009 - 09:24 PM
Nu incerca sa-l cumperi de la magazin pentru ca e putin probabil sa-l gasesti. Cu siguranta o sa-l gasesti la un prieten sau cunostinta electronist recuperat de pe vreo placa electronica. Cand o sa-l schimbe o sa-si arunce si un ochi sa vada daca nu s-a mai ars altceva (de ex. un stabilizator de tensiune s-ar fi putut pune in scurt si in felul acesta statia s-ar putea alimenta dar la tensiune mai mare).
  • Lifetime Beginner
  • Postari: 3633
Postat 23 June 2009 - 10:31 PM
Am vorbit cu un prieten ce lucreaza la un service GSM si vineri merg cu statia la el, are condensator si il schimba si verifica si stabilizatorul de tensiune care se incalzea.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#8 Useril este offline   ave
  • Postari: 1010
Postat 24 June 2009 - 08:06 AM
Bafta! Sa ne spui si noua ce si cum, te rog.
Ave
