Povestea unui "Fier de Calcat" sau "Sageata Nebuna"
Postat 29 December 2007 - 08:06 PM
R/C WFLY 6 canale 35MHz
variator Aquaspeed 50
3 servo Futaba S3003
motor aeroterma Dacia
carma 70*36mm
Elice Dynamic 3 pale 75 mm stanga
cuplaj Super Navy Kardan
baterii 2 x 6V 12A
Si uite asa am avut motiv sa invat ceva Autocad. Asa a iesit prima simulare 3D : http://i221.photobucket.com/albums/dd21/pescarpro/barcanoua3D.jpg
O vedere din lateral : http://i221.photobucket.com/albums/dd21/pescarpro/Proiectbarca3.jpg
Postat 29 December 2007 - 08:09 PM
http://i221.photobucket.com/albums/dd21/pescarpro/IMG_2047mica.jpg
Postat 29 December 2007 - 08:15 PM
http://i221.photobucket.com/albums/dd21/pescarpro/IMG_2111mica.jpg
Aceasta postare a fost editata de paulp: 29 December 2007 - 10:37 PM
Postat 29 December 2007 - 08:19 PM
http://i221.photobucket.com/albums/dd21/pescarpro/Comanda-lumini.jpg
Postat 29 December 2007 - 08:23 PM
http://i221.photobucket.com/albums/dd21/pescarpro/lumini.jpg
Desi apararul meu nu prea exceleaza in modul manual iata cam cum se vede noaptea :
http://i221.photobucket.com/albums/dd21/pescarpro/night-view.jpg
Postat 29 December 2007 - 08:28 PM
http://i221.photobucket.com/albums/dd21/pescarpro/lumini-carcasa.jpg
Postat 29 December 2007 - 08:33 PM
http://i221.photobucket.com/albums/dd21/pescarpro/comanda-cuva-1.jpg
http://i221.photobucket.com/albums/dd21/pescarpro/cuva-inchisa-1.jpg
http://i221.photobucket.com/albums/dd21/pescarpro/cuva-deschisa-1.jpg
Postat 29 December 2007 - 08:36 PM
http://i221.photobucket.com/albums/dd21/pescarpro/antena.jpg
Postat 29 December 2007 - 08:38 PM
http://i221.photobucket.com/albums/dd21/pescarpro/Carma-1.jpg
Postat 29 December 2007 - 08:43 PM
http://i221.photobucket.com/albums/dd21/pescarpro/protectie-elice.jpg
Postat 29 December 2007 - 08:50 PM
http://i221.photobucket.com/albums/dd21/pescarpro/desusmica.jpg
si o vedere din lateral :
http://i221.photobucket.com/albums/dd21/pescarpro/lateralmica.jpg
Postat 29 December 2007 - 08:55 PM
http://i221.photobucket.com/albums/dd21/pescarpro/hainuta.jpg
Aceasta postare a fost editata de paulp: 29 December 2007 - 08:57 PM
Postat 29 December 2007 - 08:56 PM
http://i221.photobucket.com/albums/dd21/pescarpro/cu-montura.jpg
Postat 29 December 2007 - 09:02 PM
http://i221.photobucket.com/albums/dd21/pescarpro/incarcator-2.jpg
http://i221.photobucket.com/albums/dd21/pescarpro/incarcator-1m.jpg
Postat 29 December 2007 - 09:06 PM
Postat 30 December 2007 - 11:08 AM
Postat 30 December 2007 - 12:23 PM
#19
Postat 30 December 2007 - 01:13 PM
paulp, la 30 Dec 2007, 12:51, a spus:
...eu am mari dubii ,dar cine stie poate ma insel! Poti sa ne dai niste dimensiuni ?
#20
Postat 30 December 2007 - 04:02 PM
Sper ca nu esti din specia celor ce nu stiu de gluma... Dar cu LED-urile alea albastre, obiectul devine BESTIAL!!!
Acum lasand gluma, nici eu nu prea inteleg treaba cu stabilitatea...... Un filmulet pe val cred ca m-ar uimi; stii, totusi forma, cum ai spus si tu e chiar cel putin ciudata.....
#21
Postat 30 December 2007 - 08:15 PM
Sper sa nu te superi!!!
#22
Postat 30 December 2007 - 09:11 PM
ipsihi, la 30 Dec 2007, 20:15, a spus:
NU, nu se va scufunda.
Apa ii va veni dupa aproximarile mele cam la 2cm sub LED-urile alea rosii din spate. Problema e ca la val din lateral, apa ii va trece peste acel ``capac`` pe care, eu personal nu-l vad bine etansat cu cauciucul ala de ermetizat casnice (asa pare in foto). Cred ca vei pune silicon dupa fiecare demontare...
Sunt curios sa vad daca am aproximat bine linia de plutire... Poti sa-i faci o poza in cada(pune tot in ea!!!)
Inca ceva: asa cum e in poza, nu iti sta putin lasata de bot (pana intr-un cm) ? Ia masoara linia de plutire fata de partea superioara mare.
Sfat DE AUR: baga bine RX-ul in ceva, ca e amplasat exact... (ESC-ul ala nu ia apa).
Cred ca trebuia sa te mai gandesti putin la sistemul ala de etansare... e tare ciudat. Eu zic sa o modifici de pe acum. Vezi pe forum, ca s-a mai discutat...
Motorul il vei schimba sigur ca se va incinde ca dracu. Elicia e OK, nu o schimba!
Aceasta postare a fost editata de HESS: 30 December 2007 - 09:18 PM
#23
Postat 30 December 2007 - 09:24 PM
#24
Postat 30 December 2007 - 09:37 PM
Daca o lasa p`aia, ca sa-i duca barca la o viteza cat de cat acceptabila, treb schimbat motorul...
Eu gandesc plecand de la ce are: barca grea. Apoi, vrea sa nu se tarasca, deci consider elicia pe care o are, ca fiind buna. Ramane de schimbat motorul...
Daca o luam invers, lasa motorul dar schimba elicia cu ceva mai mic, corect, nu se mai incinde motorul si face fata, dar barca se taraste.
Bine, asta va rezolva prin experimente, dar empiric, cred ca pe motor dau eu vina, nu pe elicie..
Clar e ca ii trebuie un motor de cuplu, nu de turatie,ca al lui; si o elice mare.
Aceasta postare a fost editata de HESS: 30 December 2007 - 09:44 PM
#25
Postat 30 December 2007 - 09:39 PM
``fierul de calcat apa din cada`` :D
Bafta, suntem numai ochi!
Aceasta postare a fost editata de HESS: 30 December 2007 - 09:41 PM
#26
Postat 31 December 2007 - 10:57 AM
Din cate imi aduc plutea destul de bine :) avand chiar un mers "leganat" inconfundabil de ratza :D
Nu mai stiu unde e filmuletul ....
Bucuresti/Rahova
#27
Postat 31 December 2007 - 06:32 PM
uite si un film :
http://www.youtube.c...h?v=BqjmQ7Ppc08
altul
http://www.youtube.c...h?v=qEcF-fIAfLI
Aceasta postare a fost editata de paulp: 31 December 2007 - 06:34 PM
#28
Postat 31 December 2007 - 06:42 PM
O poza cu diverse proiecte incepute unele abandonate altele terminate:
http://i221.photobucket.com/albums/dd21/pescarpro/diverse-proiecte.jpg
#29
Postat 01 January 2008 - 04:46 PM
Poate nu ma insel nici cu motorul... http://www.rhcforum....tyle_emoticons/default/tongue.gif
#30
Postat 02 January 2008 - 11:54 PM
ce motorizare,una,doua motoare?acumulatori?
