Modelism - RHC Forum: Sukhoi SU-31 .46 P HOENIX Models - Modelism - RHC Forum
Sukhoi SU-31 .46 P HOENIX Models ASP 7,5 cc
#1 Useril este offline   Miezu_eu
  • Postari: 553
  • Inregistrat: 13-July 07
  • Interests:Aeromodelism
  Postat 21 May 2009 - 10:56 AM
This is the radio controlled, glow powered, Almost-Ready-to-Fly
"Feonix" Models Sukhoi Su-31 .46 sport aerobatic airplane kit.
For intermediate to advanced modelers.
FEATURES: Construction: Built-up balsa and plywood
Covering: Pre-applied heat shrink film, color scheme is Yellow with
Red on the nose of the fuselage and forward wing section and a Red
diamond pattern extending from the front to the middle of the
fuselage
Wings: Two-piece wood, must be joined before installation
Radio Compartment: Plywood reinforced, easily accessible over wing
Cowling: Painted fiberglass
Canopy: Clear, single
Wheel Pants: Painted fiberglass
Cockpit features: Detailed and painted pilot figure
Landing gear: Pre-bent 3/16" (4mm) aluminum with 2-1/4" (57mm)
treaded rubber main wheels and one 1" (25mm) rubber tail wheel with
pre-bent 0.078" (2mm) thick wire
Dual aileron servos: Yes, standard size and torque required
Hardware: Hinges, wing bolts and all other required fasteners
included
Motor Mount: Nylon, with engine mounting hardware
INCLUDES: Prebuilt and pre-covered wings fuselage and tail section aluminum
main landing gear, tailwheel wire, nylon adjustable engine mount,
main and tail wheels, pre-bent pushrods, hardware package,
fiberglass cowling and wheel pants, clear canopy, pilot figure,
decals, photo-illustrated instructions,
REQUIRES: Engine: .46 cu in (7.5 cc) 2-stroke
OR .53 cu in (8.7cc) 4-stroke
Muffler: Standard type included with engine
Radio: Four channel
Servos: Five, 42 oz/in torque minimum
(2-ailerons, 1-elevator, 1-rudder, 1-throttle)
Servo Extension: One 6" (152mm) for ailerons
Y-Harness: One for aileron servos
Misc. Items: 2" (51mm) spinner, 1/4" foam rubber padding, 3' medium
fuel tubing, fuel filter, propeller, building and field equipment
SPECS: Wingspan: 55.9" (1420mm)
Flying Weight: 6lbs (2700g)
Specs such as Wing Area and Wing Loading are not provided by the
manufacturer
Length: 48.4" (1230mm)
Airfoil: Fully-symmetrical, low wing
Center of Gravity: 4.3" (110mm) Back from the wing's leading edge
at the fuselage sides.
Control Throws-
Ailerons: Up & Down 0.40" (10mm)
Elevator: Up & Down 0.43" (11mm)
Rudder: Right & Left 0.79" (20mm)
Aceasta postare a fost editata de Miezu_eu: 21 May 2009 - 10:57 AM
doar....eu
0721.798.720
#2 Useril este offline   Miezu_eu
  • Postari: 553
Postat 21 May 2009 - 11:01 AM
doar....eu
0721.798.720
#3 Useril este offline   Abburo
  • Postari: 1317
  • Inregistrat: 02-June 07
Miezule, baga repede un "mozaic" pe poza #3 din primul post ;) :rolleyes:)
#4 Useril este offline   Miezu_eu
  • Postari: 553
  Postat 21 May 2009 - 11:02 AM
Cu dedicatie speciala penru Abburo !!!!!!!!!!!!!!!!!!!!!!! :rolleyes:
doar....eu
0721.798.720
#5 Useril este offline   B-222222
  • Postari: 119
  • Inregistrat: 02-May 07
Postat 21 May 2009 - 03:42 PM
Frumos avion. Sa-l zbori cu placere.
Daca nu era avionul in poza 3 se vedea miezul miezului :)
Bafta si aterizari line!
#6 Useril este offline   Abburo
  • Postari: 1317
Postat 21 May 2009 - 04:37 PM
Vrem si ceva comentarii de la zbor...
#7 Useril este offline   Miezu_eu
  • Postari: 553
  Postat 21 May 2009 - 10:05 PM
O prima problema din timpul constructiei a fost modul amplasarii batiului pentru motorul termic. In carte este prezentata o ilustratie pentru un batiu pentru un motor in 4T de 8,5 cc. Pana la urma am realizat ca cercul din panoul de foc, acea gaura, trebuie sa fie inscrisa pe forma patrata a batiului; asta dupa vreo zi de ezitari ca nu cumva sa fac din panoul de foc un ciur de malai. A doua chestie suspicioasa a fost amplasarea rezevorului intr-o mare caura cu un pic de buretel din kit, am bagat burete la greu :)
La zbor, mare mare diferenta intre electric si termic, parol....extrem de mare diferenta. Nu ii place deloc viteza mica, se angajaza cam repejor, asta la primul zbor, poate ca pe viitor o sa ma invat cu el si o sa anticipez tendintele lui de zapaug.
L-am centrat longitudinal, transversal ca la carte. O mare problema a fost ca nu stiu cum, necum, ceva s-a dereglat, probabil ca in tensiune, echiile, bratul de servo si etc. s-au asezat pe "normal" si profundorul la TRIM 0 era un pic ridicat, vreo 2-3 mm din cei 11 admisi, mult zic eu aproape 18-27 %. Drept urmare la aterizare cand il puneam usor pe panta o lua usurel in sus, am facut T and Go fara sa vreau si la prima aterizarea ca sa atinga pamantul l-am bagat cu botul in pamant si am tras in ultimul moment de profundor si s-a indoit un pic trenul, drept urmare elice rupta! Al doilea zbor in loc sa il trimez cum trebuie l-am trimat invers, in euforia mea. Cum necum a fost mai OK. Sper ca sambata sa fie mult mai bine mai ales ca o sa ma uit de 100.000 de ori inainte sa il zbor, la toate suprafetele.
Ca design este bestial, contrastul intre rosu si calben, e criminal!
PS: Cam asta e misterul se vedea sau nu miezu' :)
Aceasta postare a fost editata de Miezu_eu: 21 May 2009 - 10:07 PM
doar....eu
0721.798.720
#8 Useril este offline   Miezu_eu
  • Postari: 553
  Postat 26 May 2009 - 08:30 PM
O decolare scurta!
doar....eu
0721.798.720
#9 Useril este offline   Miezu_eu
  • Postari: 553
Postat 26 May 2009 - 08:36 PM
O poza in care Abburo imi explica modul cum trebuie sa decolez si sa aterizez:
doar....eu
0721.798.720
#10 Useril este offline   Miezu_eu
  • Postari: 553
  Postat 26 May 2009 - 08:38 PM
O poza la sol pe iarba, se odihnea dupa primul zbor de duminica :)
Aceasta postare a fost editata de Miezu_eu: 26 May 2009 - 08:38 PM
doar....eu
0721.798.720
#11 Useril este offline   Miezu_eu
  • Postari: 553
  Postat 26 May 2009 - 08:39 PM
una mai de tablou asa.......
doar....eu
0721.798.720
#12 Useril este offline   ARU
  • Postari: 1427
  • Inregistrat: 15-February 08
  • Interests:aero
Postat 26 May 2009 - 09:14 PM
...nota 10 pentru acest lucru !
#13 Useril este offline   Miezu_eu
  • Postari: 553
Postat 27 May 2009 - 01:08 PM
Vezi postareaARU, la May 26 2009, 10:14 PM, a spus:
vorbesti serios? sau esti ironic? da argumente. AM zis sa aibe racire cum trebuie pe aripioarele de pe toba :)
doar....eu
0721.798.720
#14 Useril este offline   ARU
  • Postari: 1427
  • Interests:aero
Postat 27 May 2009 - 01:40 PM
...ma refeream la servetel , este un lucru marunt pe care multi nu-l practica ! ..... dar poate se gaseste un dop de pluta !
#15 Useril este offline   Calin
  • Postari: 2468
  • Inregistrat: 11-June 07
Postat 27 May 2009 - 01:44 PM
e foarte buna solutia:) Si eu o folosesc. Cu dopul de pluta risti sa-l rupi in toba si daca nu ai un tirbuson la indemana... nasol :)
#16 Useril este offline   andreirosca
  • Postari: 271
  • Inregistrat: 08-December 06
Postat 27 May 2009 - 02:23 PM
... si miezule nu uita ca ala se scoate inainte de a incerca sa pornesti motoru' ... hi hi hi.
#17 Useril este offline   ARU
  • Postari: 1427
  • Interests:aero
Postat 27 May 2009 - 05:52 PM
Vezi postareaCalin, la May 27 2009, 02:44 PM, a spus:
e foarte buna solutia:) Si eu o folosesc. Cu dopul de pluta risti sa-l rupi in toba si daca nu ai un tirbuson la indemana... nasol :rolleyes:
unul de cauciuc este mult mai util dar in caz fortuit merge si unul de la sticla cu vin !..sau sampanie !
Postat 28 May 2009 - 01:06 PM
Great Planes, mon amour, s-a gandit la noi:
http://www3.towerhobbies.com/cgi-bin/wti00...=LXK144&P=7
Am vazut aceleasi capacele si la magazinele de constructii. Se folosesc ca sa protejeze capetele suruburilor.
Aceasta postare a fost editata de dan_mitea: 28 May 2009 - 01:06 PM
#19 Useril este offline   Porumbeu
  • Womens In Your City - Anonymous Adult Dating - No Verify
  • Postari: 831
  • Inregistrat: 09-July 07
  • Gender:Female
  • Interests:Girl,Woman
Postat 30 May 2009 - 09:42 PM
Dan, fara suparare dar din cunostintele mele de limba engleza " Carb Cover " nu este acelasi lucru cu ala pentru toba. Asta este special pentru carburator :angry2:
#20 Useril este offline   Miezu_eu
  • Postari: 553
Postat 01 June 2009 - 02:26 PM
servetelul rules...ieftin, abundent si biodegradabil http://www.rhcforum....tyle_emoticons/default/wink.gif
doar....eu
0721.798.720
Postat 01 June 2009 - 06:16 PM
Vezi postareaPorumbeu, la May 30 2009, 10:42 PM, a spus:
Dan, fara suparare dar din cunostintele mele de limba engleza " Carb Cover " nu este acelasi lucru cu ala pentru toba. Asta este special pentru carburator :)
Nici o suparare. Doar ca merge perfect si la toba. Eu am la toate motoarele.
Baftaaaaaaaaaaaaaaaaaaaaaaaaa.
#22 Useril este offline   Miezu_eu
  • Postari: 553
Postat 02 June 2009 - 08:16 PM
Vezi postareadan_mitea, la Jun 1 2009, 07:16 PM, a spus:
Amandoi aveti dreptate, un capac de carburator de la un motor de 1,5cc spre exemplu poate merge ca si capac de toba la un motor de 20cc, probabil ca la asta te-ai referit dane,
acum pt porumbeu, sa ii dam si lui dreptate, un capac de carburator de 4 cc nu o sa mearga la toba aceluiasi motor
doar....eu
0721.798.720
Postat 03 June 2009 - 01:12 AM
Bineinteles. Poate nu am fost clar si poate nu s-a observat din link. In cutiuta de la Great Planes sunt mai multe capacele. De diferite dimensiuni, astfel gandite incat se potrivesc la carburatoarele si tobele uzuale.
#24 Useril este offline   docmarius
  • Postari: 398
  • Inregistrat: 05-July 08
Postat 03 June 2009 - 07:51 AM
Vezi postareaARU, la May 27 2009, 06:52 PM, a spus:
FORTUÍT, -Ă adj. neprevăzut, întâmplător, venit pe neaşteptate; inopinat. o (jur.) caz ~ = eveniment independent de culpa debitorului, care îl împiedică să-şi execute o obligaţie. (< fr. fortuit, lat. fortuitus)
Scuze dar ma zgarie in ochi fraza asta...
West Hobby Team
#25 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 03 June 2009 - 08:01 AM
Vezi postareadocmarius, la Jun 3 2009, 08:51 AM, a spus:
Ce sa zic, ai si tu niste pretentii... Unde te crezi, la ora de limba romana? :D
Ave
