"German company Acme were displaying the next generation FlyCamOne video camera system at this year's Nuremburg trade show. Pictured here, FlyCamOne V3 is a modular system designed to provide 'still' pictures, video and real-time footage via the ground station monitor along with an FPV (first person view) facility.
For a start it's modular so you buy what you need and then add on items after. Some parts are interchangeable so the camera monitor screen can be removed and switched to the 2.4GHz ground station monitor module, the 2.4GHz camera transmitter plugging in where the camera screen goes.
Footage can be transmitted via the 2.4GHz link to the ground station so the view from the model can be instantly seen on the 2" screen.
The camera itself remains VGA quality :blink:
Likely pricing was unavailable. "
Articol complet si imagini la:
http://www.modelflyi...icle.asp?a=4425
FlyCamOne V3 FPV ready
Postat 26 February 2009 - 05:21 PM
Si iat-o deja si in Romania, cu specificatii complete, mult mai complete ca cele de pe site-ul englezesc.
Pentru mine surpriza cea mare este ca are incorporat mecanism pan/tilt chiar in constructie, care se comanda cu doua canale RC, *sau* cu un sistem separat emitand in 433MHZ !
Pacat ca nu e HD, ar cam fi facut partie in lumea FPV...
The FCOΞ, as the 3 issue of the successfully FlyCamOne series enables completely new possibilities.
In the past you need to take your PC or laptop to watch your recorded videos. Within the FCOΞ Core Set a 2" TFT screen is included. It can be separated from the camera to save weight.
The screen's place can also be taken by the mounting base or by the FCOΞ video-transmitter (part of the FCOΞ transmitter set). The camera now sends the video at 2.4 GHz to the receiver connected with the screen.
The receiver module can also be connected to the soon available FCOΞ V-Eyes. Like that you can see the world from the birds view as a live stream. Data like speed, high and direction will be supplied by the separate GPS-module. The cams head follows with the integrated Head-Tracking-System the movement of the pilots head, as far as the model-receiver has three free channels (pan/ tilt/ trigger). Last but not least a 433 MHz transmitter /-receiver (FCOΞ Linx) will be available. Like that it´s also possible to move the cams head and trigger the recording without the models transmitter.
Aceasta postare a fost editata de navigator: 19 June 2009 - 06:49 AM
Motiv editare: reclama
Postat 18 June 2009 - 08:07 PM
Cred ca trebuia sa inchid topicul asta... raspunsul de ce il gasesti aici:
http://www.rhc.ro/forumrhc2/index.php?show...st&p=301338
Dar nu fii trist, ai facut o economie, nu merita, calitatea e cam... lipsa.
Mai bine strange bani pentru ceva mai serios.
