Modelism - RHC Forum: permax 280 help - Modelism - RHC Forum
permax 280 help
#1 Useril este offline   tehnium
  • Postari: 6
  • Inregistrat: 23-March 04
  Postat 02 April 2004 - 08:44 PM
am luat recent un motor permax 280 si nu stiu ce acumulatori ii trebuie,ce amperaj tre sa aiba fiecare acumulator din celula de acumulatori si daca il pot folosi fara variator de turatie.de asemenea ce incarcator trebuie pt acumulatori si ce putere tre sa debiteze,ce tensiune si ce amperaj . daca stie cineva il rog sa-mi dea un mi
  • Postari: 1784
  • Inregistrat: 13-March 04
Postat 02 April 2004 - 08:50 PM
Uite informatiile de care ai nevoie:
NOTES FROM OUR TECH DEPARTMENT
This is the Multiplex Permax 7.2 Volt 280 BB Electric Motor.
FEATURES: Ideal choice for sub 400 class model aircraft
Ball race construction
INCLUDES: One Multiplex Permax 7.2V 280 BB electric motor
Three capacitors
Instruction sheet
Pre-tinned wires with connector, available separately MPUC8513
REQUIRES: Soldering of capacitors and wires to motor, installation onto model.
SPECS: Length of can: 1.5" (38mm)
Length to shaft end: 1.9" (49mm)
Diameter: 0.94" (24mm)
Weight: 1.9oz (54g)
Shaft Diameter: 2.1mm
_ Nominal Voltage: 7.2V
No-load speed: 30,000 RPM
No-load current: 0.8 Amps
_ Speed at max efficiency: 24000 RPM
Current drain at max efficiency: 3.5 Amps
Max efficiency: 75%
Typical output power: 28 Watts
Typical operating voltage: 6-8.4V
COMMENTS: High current sockets are available separately to plug into motor
connector, MPUC8514.
jxs 9/09/03
ir/jxs
#3 Useril este offline   Enigma
  • Postari: 142
  • Inregistrat: 05-February 04
Postat 02 April 2004 - 08:59 PM
Am un motor IDENTIC.
Eu folosesc acumulatori Graupner 7 x 1000mA.
Oricum un acumulator Graupner sau oricare alta firma e buna,numai ca iti ajunge si cu 6 elementi,adica 7.2v.
Over the hills and far away,
he swears he will return one day.
Far from the mountains and the seas,
back in her arms again he'll be.
Over the hills and far away.
#4 Useril este offline   droopy
  • Postari: 131
  • Inregistrat: 06-May 03
Postat 06 April 2004 - 04:37 PM
Si cam la cat incarci acei accu de 1A?
Si cat ii tii la incarcat?
Un nebun lanseaza un aeromodel,
si 10 modelisti nu-l pot ateriza.....
#5 Useril este offline   Enigma
  • Postari: 142
Postat 06 April 2004 - 09:31 PM
Pai cum am mai spus timpul de incarcare este 1.4 x amperajul acumulatorului impartit la amperajul incarcarii,deci 1.4 x 1000mA / 180 = 7.77 ore sau ceva de genul :):):)
#6 Useril este offline   zozo
  • Postari: 1126
Postat 06 April 2004 - 10:09 PM
Enigma, la 6 Apr 2004, 21:31, a spus:
...1.4 x 1000mA / 180 = 7.77 ore....
Mai frate ne-ai spart! 7 ore mai inteleg dar 7.77 ore cat fac daca nu te superi...?
Postat 06 April 2004 - 10:13 PM
Daca n-a facut transformarea in continuare, 0,77 ore inseamna cam 46,2 minute. Adica 7 ore si 46 minute. Dupa calculele mele. Dar n-am urmarit ce-i acolo.
E ca si cum ai scrie ca 0,5 ore inseamna 30 minute. Parerea mea.
#8 Useril este offline   zozo
  • Postari: 1126
Postat 06 April 2004 - 10:36 PM
Mersi Bitex pentru lamuriri dar mai am o neclaritate...care-i faza cu 1.4 ? Nu era mai simplu astfel 1000/180 = 5.55 ? adica 5 ore si 33 minute? Deci la un acumulator deobicei se recomanda incarcarea lenta cu a 10-a parte a curentului nominal 1000/100 = 10 ore este simplu iar daca cineva doreste sa faca experimente cu diferiti curenti de incarcare vizitati AICI
#9 Useril este offline   tehnium
  • Postari: 6
Postat 06 April 2004 - 10:39 PM
multumesc de sfaturi! m-am lamurit ,in sfarsit!!!
#10 Useril este offline   xorg
  • Postari: 1352
  • Inregistrat: 16-February 03
Postat 06 April 2004 - 10:49 PM
Am si eu o intrebare aici apropo de 280-ul asta cu ce elice-l folosesti?
merge si fara reductor?
Postat 06 April 2004 - 10:55 PM
Din nefericire nici faza cu 1,4 si nici ce-i scris mai sus nu-mi este cunoscut, ca nu am urmarit ce-i acolo. N-am facut calcule sa vad daca rezultatul este corect si macar apropiat de ce stiu eu.
Cred ca se refera la faptul ca merge cu varianta a treia (140%) si in cazul asta e corect. Ca tot ai dat acel link, a treia varianta este cea data de el, adica isi ia un coeficient de 1,4. Abia acum mi-am adus aminte ca incarcam cu a zecea parte din "amperaj" timp de 14 ore, nu 10 (la acumulatorul modelului 1:1) si cred ca nu-i rau. Nu stiu nimic de accu astia mici... N-am avut treaba cu ei, ca eu faceam precum copiii: impingeam modelul cu mana (si-l opream cu matura).
#12 Useril este offline   Enigma
  • Postari: 142
Postat 07 April 2004 - 10:28 AM
In fine am cautat manualul incarcatorului si citez:
"Charge time = Battery capacity(mAh) / Charge current(mAh) - PENTRU ACUMULATORI CU PLUMB
Charge time = Scuze pentru chestia aia cu 1.4,era pentru aflarea curentului incarcarii.
Era cam asa:Charge current = Battery capacity(mAh) / 10 = 600mA/10 = 60mA
Charge time = 1.4 x battery capacity (mAh) / Charge current (mA) = 1.4 x 600mA / 60mA = 14 hours. - PENTRU NI-CD SI NI-MH"
Sper ca am clarificat cum sta treaba :)
Aceasta postare a fost editata de Enigma: 07 April 2004 - 10:30 AM
