http://www.youtube.com/watch?v=Vi0hrjqU15I...feature=related
Inca nu imi vine a crede ce am vazut acolo. Dynamic soaring....
Cel mai rapid aeromodel e un planor?
Postat 11 January 2009 - 05:53 PM
Postat 11 January 2009 - 06:03 PM
protheus, la Jan 11 2009, 05:53 PM, a spus:
Postat 11 January 2009 - 06:06 PM
Postat deja la vremea aia:
http://www.rhc.ro/fo...showtopic=16526
"Dynamic soaring is a gliding technique used to gain kinetic energy by repeatedly crossing the boundary between air masses of significantly different horizontal velocity. Such zones of high wind gradient or low level wind shear are generally found close to obstacles and close to the surface, so the technique is mainly used by birds, but glider pilots have occasionally been able to soar dynamically in meteorological wind shears at higher altitudes. radio-controlled gliders can employ this technique on a hill with significant flow separation."
http://en.wikipedia....Dynamic_soaring
caius71, la Jan 11 2009, 06:03 PM, a spus:
Seamana perfect cu un captiv(ceva nu este in regula!).
Postat 11 January 2009 - 06:13 PM
Vroiam sa spun, adica nu s-a depasit aceasta viteza cu alt aeromodel motorizat? Tot acel record a ramas in picioare? Realizat de un planor?
