Modelism - RHC Forum: Accumulatori: stocare - Modelism - RHC Forum
#1 Useril este offline   Romulus
  • Postari: 1190
  • Inregistrat: 02-June 08
Postat 24 October 2008 - 10:57 AM
Stiu ca sunt diferite forme de a stoca acumulatorii, pentru diferite perioade de timp. Spre exemplu, lipo se stocheaza cu tensiunea la jumatate.
Poate cineva sa spuna cum e cel mai bine de stocat? Am in incarcator care stie face minuni, dar nu am teoria la baza, despre ce trebuie facut. Scrie cate ceva in manual dar prea putin...
Deci, cum se incarca accumulatorii (LiPo, LiFe, LiIo, NiMH si NiCd) in vederea stocarii?
  • Postari: 19188
Postat 24 October 2008 - 11:09 AM
http://batteryuniver.../partone-19.htm
#3 Useril este offline   Calin
  • Postari: 2468
  • Inregistrat: 11-June 07
Postat 24 October 2008 - 11:11 AM
e o intreaga sectiune despre baterii la vademecum. Vezi acolo.
#4 Useril este offline   Romulus
  • Postari: 1190
Postat 24 October 2008 - 11:14 AM
Daca e in plus topicul, stergeti-l.
Pe linkul de mai sus citisem... Dar am senzatia ca e prea vag.
  • Keep batteries in a cool and dry storage area. Refrigeration is recommended but freezers should be avoided. When refrigerated, the battery should be placed in a plastic bag to protect against condensation
  • Do not fully charge lithium and nickel-based batteries before storage. Keep them partially charged and apply a full charge before use. Store lithium-ion at about 40% state-of-charge (3.75-3.80V/cell open terminal). Lead-acid batteries must be stored fully charged.
  • Do not store lithium-ion fully depleted. If empty, charge for about 30 minutes before storage. Self-discharge on a depleted battery may cause the protection circuit to trip, preventing a recharge.
  • Do not stockpile lithium-ion batteries; avoid buying dated stock, even if offered at a reduced price. Observe the manufacturing date, if available.
  • Never leave a nickel-based battery sitting on a charger for more than a few days. Prolonged trickle charge causes crystalline formation (memory).
  • Always store a lead acid battery in full-charge condition. Observe the open terminal voltage and recharge the battery every 6 months or as recommended by the manufacturer.
Postat 24 October 2008 - 11:17 AM
incearca si subiectul asta,sau
vademecum
sau rcbatteryclinic.com
#6 Useril este offline   Romulus
  • Postari: 1190
Postat 24 October 2008 - 11:27 AM
E un subiect foarte complex. Eu nici nu vroiam stocare peste iarna. Vroiam pentru 1-2 saptamani cand nu-i folosesc. Poate nici nu conteaza... Dar se poate lipi topicul la unul existent.
#7 Useril este offline   Calin
  • Postari: 2468
Postat 24 October 2008 - 05:21 PM
daca vrei un raspuns rapid si nedocumentat: incarca-le si pune-le de-oparte. La mine zac in boxa de 3 sapt deja pe yak cat astept sa-mi vina noua fisa de bujie :)
#8 Useril este offline   pavcostel
  • Postari: 1598
Postat 24 October 2008 - 06:51 PM
@Romulus
Cel mai sigur este sa fie incarcati cam jumatate, si pusi frumos in cutia de jos de la frigider. Asta in cazul in care jos nu ai congelatorul.... Le face bine sa stea la o temperatura mai mica. Apoi se pun la incarcat inainte de zbor si gata. NiXX chiar se comporta excelent dupa un astfel de tratament. LiFe nu stiu sa-ti spun.
Aceasta postare a fost editata de pavcostel: 24 October 2008 - 06:53 PM
