Am extras cateva date desore regulament:FOR 1/8 TOP FUEL
Engine : Maximum 3.5cc (total)
Transmission : Free
Fuel : Free
Exhaust : Free
Weight : Minimum 2800g
Wheelbase : Maximum 953mm
Track (rear) : Maximum 135mm
Rear tires : Width Maximum 70mm, Diameter Minimum 100mm
Body, wings, and everything else......as close to the real thing as possible!
For other measurements look in the NHRA Rulebook, and divide by eight!
For the Swedish STEP ONE electric 1:10 scale dragster class
Motor: Kyosho K-speed 13 turn
Free brushes and springs Energy: 7 NiCd standard sub-C (diam. 23 mm) cells (NOT pushed)
Weight: 1020.6 g minimum (36 oz.)
Wheels: rear diameter 50,8 mm minimum (2") Front diameter 12.7 mm minimum (½")
Chassis: length 760 mm (30")maximum.
Wheelbase 406 ? 760 mm (16" ? 30") Rail or Funny car type.
Total width: 250 mm Wing: height 204 mm (8") off the ground maximum.
Body: must have dummy motor or intake with dummy exhaust pipes
La
http://welcome.to/mtfa la sectiunea movies exista si un film de 5Mb.
Primele poze postate de mine sunt tot de pe acest site (ha,ha, ce mica e lumea..) si iata si comentariul alaturat lor:
When Lelle came with the idea of putting rockets into his funnycar, we all encouraged him.
Who would'nt like to see a funnycar "burning up the track"
So far he has made three runs, to decide what kind of rockets he should use.
The car is the same car he tried with the a 3.5cc engine earlier in the season.
It has only been modified a little bit (look at the pic's)
He is using 6 model rocket engines. A 7.2v acc and a switch is used to get it on it's way.
The diskbrake is the same as on all our cars.
The rockets he has tried so far has had to short burning time.
The power is enough for 30meters or so.
But he has promised that he will be back with more power.......
Alte reguli:
MTFA Radio Controlled Dragracing in Sweden
Here you have some info about what we are doing..........
THE TRACK
The track is 402.33 meters divided by eight = 50.29 meters
It's prepared with trackbite (same as for the real dragsters) to get tracktion.
The cars need about 20-40 meters to stop so total length is about 100 meters.
THE CARS
The cars are in 1/8 scale of a Top fuel Dragster, about one meter long.
The measurments for tyres,wings and body are taken from the NHRA rulebook and divided by eight. To make the cars look like the real thing.
We use a 3,5cc engine with tuned speed exhaust (rev's ~47000 rpm at the finishline).
The engines are modified for this sole purpuse, a pas down the strip ~3sec of hard running.
A very small colinghead so that the engine don't lose the temp at the end of the run.
Modified crankshaft to increase the fuel flow.
The fuel is a mix of Nitromethane, Methanol and Oil. (usually 70% Nitro, 25% Methanol and 5% Castrol M-oil).
Different types of clutches has been tested, the best one yet is Serpent's adjustable Centax clutch. It can be used with some minor mod's, and works very good.
One or two cars has been using a BMT two speed gearbox, performance is quite equal to the one speed cars.
The breaking is handled by a single breakdisk on the rearaxel.
The minimum weight is set at 2800g (2.8kilo). This so that everyone can build a competitive car.
TIMING
Timing is done wiht a "Home made" equipment. It can measure Reaction, 60 foot, ET and Topspeed.
To this we have a Windows program for easy handling, It can also be run without the PC, Then you use internal display's.
Under construction Scorebords.
Aceasta postare a fost editata de PiccoMaster: 28 January 2004 - 09:46 AM
