Modelism - RHC Forum: Interferente in 2.4 GHz - Modelism - RHC Forum
Interferente in 2.4 GHz Futaba T6EXP, T7CP si TM7 RF module
#1 Useril este offline   Abburo
  • Postari: 1317
  • Inregistrat: 02-June 07
  Postat 21 April 2008 - 08:16 PM
Se pare ca unele statii in 2.4 GHz de la Futaba pot avea un "defect" de fabricatie prin care GUID-ul (identificatorul unic) statiei este egal cu 0 (zero). In caz ca doua astfel de statii sunt pornite in acelasi timp este echivalent cu bruiajul a doua statii clasice in acelasi canal.
Atasez documentul oficial al Robbe prin care se face cunoscuta aceasta problema.
Eu sunt posesorul unui model T6EXP si am zburat impreuna cu alte statii tot in 2.4 GHz dar nu am avut probleme pana acum.
De remarcat ca este posibil dar nu obligatoriu ca GUID-ul sa devina 0 in cazul in care statia ramane pornita si i se termina acumulatorul (descarcare adanca).
Deci posesori de statii in 2.4 GHz faceti teste de bruiaj obligatoriu!
Aceasta informatie este oficiala pe site-ul Robbe:
http://at.robbe-onli...t.storefront/en
Modificare Iunie 2008:
Si Futaba a aflat loturile cu probleme. Va puteti verifica statiile cu usurinta:
It is important to note that the precautionary measures are relevant only to the Futaba FASST items with serial numbers as described below. To determine if your transmitter might be affected, look on the bottom of the transmitter case. If using the TM-7 module, the serial number is located on the inside portion of the module:
6EX: A7xxxxxxx without the "I" (Inspected) sticker
7C 07xxxxxxx without the "I" (Inspected) sticker
TM-7 07xxxxxx without the "I" (Inspected) sticker
The precautionary measures do not apply to systems that utilize a serial number as noted below:
6EX ALL A8xxxxxxx or systems with the A7xxxxxxx serial number which include the "I" (Inspected) sticker
7C ALL 08xxxxxxx or systems with the 07xxxxxxx which include the "I" (Inspected) sticker
TM-7 ALL 08xxxxxx or modules with the 07xxxxxx which include the "I" (Inspected) sticker
As with all radio control equipment, we strongly suggest that you pre-flight your aircraft thoroughly prior to flying. When flying at a location with other FASST owners, prior to flying we suggest that all pilots briefly activate their systems simultaneously to check for any interaction between units. If any interactions should occur, do NOT fly. Return the unit to the Futaba Service Center for immediate replacement.
Each time that your transmitter is turned on, it is imperative that you allow the FASST system an adequate amount of time to thoroughly boot-up completely before shutting down the transmitter. After the battery voltage appears on the LCD, we recommend allowing the system to remain on at least one (1) additional second prior to turning off the power to the transmitter.
If the transmitter and receiver have lost their binding which required them to be re-linked, we recommend returning them to the Futaba Service Center for analysis. This is not expected behavior and should be investigated accordingly.
Aceasta postare a fost editata de Abburo: 17 June 2008 - 12:49 PM
  • Postari: 2453
  • Inregistrat: 28-February 05
Postat 23 April 2008 - 08:59 PM
au fost citeva statii...
ideea e ca NICI un alt vinzator n-a anuntat nica .... asa ca nu e de speriat!
Stima
#3 Useril este offline   mack_ro
  • Postari: 219
  • Inregistrat: 21-February 08
Postat 24 April 2008 - 01:31 PM
Eu si domnul Dragut am zburat de cateva ori in paralel (fiecare utilizand echipament FASTT 2.4 Ghz) si n-am sesizat niciun fel de probleme.
happy landings,
mack_ro
"Anyone who's not interested in model airplanes must have a screw loose somewhere"
Paul MacCready
#4 Useril este offline   Abburo
  • Postari: 1317
Postat 25 April 2008 - 09:39 AM
Dupa cum vedeti in descrierea lor, aceasta problema poate apare doar la cateva statii, si este pur si simplu o greseala de programare.
Daca o statie are GUID=0 iar alta are GUID="ceva" atunci nu vor apare nici un fel de probleme si nimeni nu va sti nimic. Insa daca doua statii cu acelasi GUID sunt pornite in acelasi timp atunci vor exista interfernte. Datorita numarului foarte mare de combinatii posibile s-a descoperit ca doar cele cu valoarea "0" sunt predispuse sa se intalneasca. Valoarea "0" este data de o posibila greseala de programare sau o resetare necontrolata a EPROM-ului statiei.
Acest subiect l-am postat aici mai ales pentru ca urmeaza intalnirea de la Rapa Rosie si nu numai, unde sunt convins ca vor fi destui participanti cu astfel de statii. Cum o verificare in prealabil, de tipul "fiecare cu fiecare", dureaza cateva minute, consider ca este absolut normal si de bun simt sa se faca. Cred ca este mult mai ieftin sa cheltuiesti cateva minute in teste decat sa rupi un model. Pana la aparitia acestui anunt nici eu nu faceam teste cu ceilalti participanti deoarece eram absolut convins ca nu se poate intampla nimic, acum insa...
Dealer-ii de la noi nu au cum sa cunoasca in detaliu aceaasta problema, insa daca cei de la Robbe au anuntat-o oficial atunci putem fi siguri ca si exista.
#5 Useril este offline   MojiTTo
  • Postari: 56
  • Inregistrat: 03-March 08
Postat 25 April 2008 - 05:32 PM
Eu din nestiinta de cauza, am lasat statia (T6EX) pornita de doua ori, dar voit, pt descarcarea accumulatorului... Sper sa nu fi stricat, bulit si eu ceva. http://www.rhcforum....tyle_emoticons/default/sad.gif
Maine pe camp fac o proba daca mai intalnesc pe cineva cu statie in 2.4G
Este usor sa pacalesti ochiul, dar este greu sa pacalesti inima!
#6 Useril este offline   CristiM
  • Postari: 673
  • Inregistrat: 22-January 03
Postat 25 April 2008 - 06:54 PM
Testul este destul de simplu. Daca receptorul inca merge cu emitatorul respectiv, fara sa fie nevoie de inca un "bind" atunci e ok. Daca nu cumva a avut din fabricatie ID-ul "0".
2 fast 4 you 2
#7 Useril este offline   MojiTTo
  • Postari: 56
Postat 25 April 2008 - 10:42 PM
Vad ca au anuntat si aici (Italia) despre aceasta problema:
Futaba
http://img102.imageshack.us/img102/9153/futababe8.jpg
Aceasta postare a fost editata de MojiTTo: 25 April 2008 - 10:52 PM
Postat 27 April 2008 - 03:50 PM
Urmatorul radio va fi JR. Cam des apar anunturi la Futaba.
#9 Useril este offline   vlad1
  • Postari: 2659
Postat 29 April 2008 - 08:25 AM
Ai vazut tu la JR 'garantat fara interferente' ?.
#10 Useril este offline   nen77
  • --tadadam--
  • Postari: 1567
  • Inregistrat: 08-March 06
Postat 29 April 2008 - 11:41 AM
folosesc in paralel un dx7 si cu un mx 22 pe care am instalat un modul 2,4 IFS- adica cel acceptat de standardele 2.4 ghz in europa..si care cia ar fi si cel mai perfomant .cel mai rapid ..etc..singura problema observata e pretul receptoarele care le gasesti is 130-140 euro ..am deja ceava timp cu el nu am nici o problema merge ireal de bine ..il recomand tuturor posesorilor de jr-graupner
West Hobby Team
#11 Useril este offline   MojiTTo
  • Postari: 56
Postat 22 May 2008 - 03:18 PM
MojiTTo, la 25 Apr 2008, 17:32, a spus:
Eu din nestiinta de cauza, am lasat statia (T6EX) pornita de doua ori, dar voit, pt descarcarea accumulatorului... Sper sa nu fi stricat, bulit si eu ceva. :D
Am facut proba pe camp, cu alte 5 statii Futaba 2.4G, toate au functionat normal, fara interferente sau alte probleme...
#12 Useril este offline   Abburo
  • Postari: 1317
Postat 17 June 2008 - 12:50 PM
Am modificat postul initial cu detalii despre loturile cu probleme. Asadar verificati-va statiile.
#13 Useril este offline   Abburo
  • Postari: 1317
Postat 12 April 2009 - 07:02 PM
Typer, imi pare sincer rau de Yakul tau...
Motorul e recuperabil?
Poate scrii totusi la kit review cateva impresii de la cele doua zboruri. Ca fapt divers ce statie ai? 2.4 sau clasica?
Hmmm... ia sa mai verific si io pe la al meu una alta :D.. nu de alta dar si mie mi-a zurat doua surubur de la cabina din cauza vibratiilor :)
#14 Useril este offline   pistolaSHNIKOV
  • Postari: 221
  • Inregistrat: 09-March 07
Postat 12 April 2009 - 08:48 PM
Nenea Typer, îmi pare foarte rău pentru YAK-ul matale
Nu trebuie să excluzi staţia din ecuaţia prabuşirii; iată 2 posibile motive:
la sol -perfect, în aer -defect
http://www.futaba-rc...vers-q1060.html
şi de-acum "clasica" boală a copilăriei:
http://www.2.4gigahertz.com/techsupport/se...tm7-7c-6ex.html
"Misiunea mea este sa imi omor timpul, a lui - sa ma omoare pe mine. Ne intelegem bine, ca intre asasini."
Emil Cioran
#15 Useril este offline   typer
  • Postari: 440
  • Inregistrat: 28-April 08
Postat 12 April 2009 - 09:50 PM
Cred ca ai dreptate, acum ce sa mai zic :rolleyes: ? O lectie dureroasa.
Intr-adevar telecomanda mea e afectata de acel bug(common code). Mai zbura cineva cu acelasi tip de telecomanda. Acum ce sa mai zic? O s-o schimb si sa nu mai zburam in in 2.4 decat unul pe rand, cei cu 7CP.
Verificati toti care aveti articolul din link.
Asa s-ar explica de ce motorul nu a coborat la relanti, asta ar fi trebuit sa se intample in caz power failure. Am testat la rodaj sin 2 secude motorul revenea la relanti sau cobora repede. Asta nu s-a intamplat. A stat aproape in plin.
Nu zic ca asta e dar mi-a picat fata cand am citit articolul de la futaba.
Aceasta postare a fost editata de typer: 12 April 2009 - 10:01 PM
"An engineer once said to build something great is like swimming in honey"
"I have always said i'd rather crash a pretty plane than fly an ugly one..." Dave F.
#16 Useril este offline   Abburo
  • Postari: 1317
Postat 12 April 2009 - 10:24 PM
Typer, in articol se spune ca "exista posibilitatea" nu ca ar fi obligatoriu sa ai acea problema.
Ai testat cu acel cineva si au existat interferente? Te intreb pentru ca si eu am o statie 6EX susceptibila de aceasta problema, si cu toate astea pana acum nu am avut parte de evenimente neplacute.
#17 Useril este offline   typer
  • Postari: 440
Postat 12 April 2009 - 10:27 PM
Vezi postareatyper, la Apr 12 2009, 10:50 PM, a spus:
Cred ca ai dreptate, acum ce sa mai zic :blink: ? O lectie dureroasa.
Am mai citit odata si nu sunt afectat de bug :) scuze. E tricky exprimarea.
Aceasta postare a fost editata de typer: 12 April 2009 - 10:27 PM
#18 Useril este offline   ALLEN
  • Postari: 3004
  • Inregistrat: 11-May 08
Postat 12 April 2009 - 10:49 PM
eu eram cel ce zbura fix cu acelasi tip de statie cu a lui Typer. faza e ca eram cu mansa la maxim pt ca "zburam" contra vantului.
acum stau si ma intreb, daca unul din noi are acel bug... duminica trecuta de ce nu i-a picat modelul, cand Typer de dadea cu Edge-ul, si eu cu Unique, la distanta de cativa metru unul de celalalt?
oricum interesant link-ul de la futaba...
#19 Useril este offline   typer
  • Postari: 440
Postat 12 April 2009 - 10:59 PM
Vezi postareaallen_g30, la Apr 12 2009, 11:49 PM, a spus:
Scuze Allen, nu am bugul, am SN cu 08, cred ca si tu la fel. Oricum e bine de stiut.
Da i-am injurat vreo 10-15 minute pe aia de la futaba http://www.rhcforum....tyle_emoticons/default/biggrin.gif.
Oricum bine ca nu a intrat in noi, a venit proiectil, George nu stia unde sa fuga ca venea spre el direct :blink:.
Aceasta postare a fost editata de typer: 12 April 2009 - 11:01 PM
#20 Useril este offline   Abburo
  • Postari: 1317
Postat 12 April 2009 - 11:01 PM
Vezi postareatyper, la Apr 12 2009, 11:27 PM, a spus:
Am mai citit odata si nu sunt afectat de bug :blink: scuze. E tricky exprimarea.
:) :D grabit esti...
Daca unul e afectat de problema, automat sufera si cel de-al doilea , ambii avand acel ID format doar din zerouri http://www.rhcforum....tyle_emoticons/default/wink.gif.
Cu alte cuvinte si Allen ar fi trebuit sa buseasca modelul la fel de urgent ca si tine!
#21 Useril este offline   typer
  • Postari: 440
Postat 12 April 2009 - 11:06 PM
Vezi postareaAbburo, la Apr 13 2009, 12:01 AM, a spus:
:blink: :) grabit esti...
"We have learned that a very small number of the TM-7 modules, and 6EX and 7C FASST systems were incorrectly coded with a common code number during the manufacturing process."
In mod normal fiecare modul TM are un cod unic, doar ca astia au facut cateva cu cod comun(acelasi cod-daca asta au vrut sa spuna). Ce sa mai zic. Atat "ii duce" mintea. Da omul bani pe o astfel de telecomanda tocmai ca sa nu mai aiba probleme si ...
#22 Useril este offline   ALLEN
  • Postari: 3004
Postat 12 April 2009 - 11:09 PM
Sorin, tocmai asta vroiam sa subliniez. daca aveam vreunul acel bug, amandoi am fi fost afectati. plus ca, ieri, am zburat in tandem cu Morph, care are acelasi tip de statie, FF7. la fel, la distanta de 2-3 metri unul de celalalt. si nu s-o intamplat nimik. la felul in care s-a comportat modelul tau, eu personal cred ca a fost vb de altceva. ai luat acel viraj dinspre hale destul de bine, la o viteza rezonabila, iar cand te-ai apropiat si ai strigat ca nu mai ai comenzi, motorul parea destul de turat. spun asta pt ca stii bine la ce distanta a trecut pe deasupra mea http://www.rhcforum....tyle_emoticons/default/rolleyes.gif .
pacat de model, sincer. si de munca depusa, dar vb ta, a fost o experienta utile si pe viitor vei sti mai bine ce sa faci si ce nu.
#23 Useril este offline   typer
  • Postari: 440
Postat 12 April 2009 - 11:10 PM
:D imi doream si eu o explicatie cat de cat valabila.
Aceasta postare a fost editata de typer: 12 April 2009 - 11:14 PM
#24 Useril este offline   ALLEN
  • Postari: 3004
Postat 12 April 2009 - 11:11 PM
Vezi postareatyper, la Apr 13 2009, 12:06 AM, a spus:
da ma, dar cred ca e f mica sansa ca 2 module identice sa ajunga ca in aceeasi zona.
Aceasta postare a fost editata de allen_g30: 12 April 2009 - 11:11 PM
#25 Useril este offline   Abburo
  • Postari: 1317
Postat 12 April 2009 - 11:15 PM
Nu vreau sa reiau un topic vechi de vreo 2 ani.... insa acel common code e format doar din 0000000000
Se datora unor greseli in scrierea flashurilor, ba chiar ziceau undeva ca daca uiti statia pornita si moare acumulatorul ai sansa sa resetezi acel ID la valoare 000000000.
Faptul ca voi aveti statii mai noi va fereste 99% de acea problema.
#26 Useril este offline   typer
  • Postari: 440
Postat 12 April 2009 - 11:18 PM
Vezi postareaallen_g30, la Apr 13 2009, 12:11 AM, a spus:
oricum nu am bug, dar toate TM cu A7xxxxxxx serial number sau 07xxxxxxx serial number si fara I(inspected) au bugul asta. Deci ...
Aburro, chiar nu stiam ca a fost si topic http://www.rhcforum....tyle_emoticons/default/smile.gif.
Aceasta postare a fost editata de typer: 12 April 2009 - 11:21 PM
#27 Useril este offline   Abburo
  • Postari: 1317
Postat 12 April 2009 - 11:29 PM
http://www.rhc.ro/forumrhc2/index.php?show...6&hl=futaba
Eu am serie cu buba si fara "I"
#28 Useril este offline   morph
  • Postari: 953
  • Inregistrat: 18-May 08
Postat 13 April 2009 - 07:48 AM
Vezi postareaAbburo, la Apr 13 2009, 12:29 AM, a spus:
Vezi ca receiverele mai noi nu se mai asociaza cu statiile care sunt afectate de bug.
#29 Useril este offline   Abburo
  • Postari: 1317
Postat 13 April 2009 - 10:56 AM
Informatia este din canale oficiale? Daca da mi se pare foarte buna.
Eu am doua receptoare asociate: un 616 si un 617.
Daca este cineva care un receptor de generatie mai noua i-as ramane indatorat daca as putea face o proba.
Multam mult ^_^
#30 Useril este offline   morph
  • Postari: 953
Postat 13 April 2009 - 02:56 PM
Am citit pe un forum, helifreak sau rcgroups, nu mai tin minte exact, dar cineva se plangea ca din 4 receivere, doua nu i se mai binduiau la statie, evident, cele care le cumparase ultimele si asa si-a dat seama ca problema venea de la statie careia i se resetase id-ul acela unic. A observat acest lucru cand i s-au de-binduit toate receptoarele si a incercat sa le re-bind-uiasca.
Problema sta in felul urmator:
Primul semn de intrebare ar trebui sa apara daca receptoarele se de-binduiesc de la statie, statia s-a resetat, si-a pierdut GUID-ul. Receptoarele facute in a doua jumatate a anului trecut (nu bag mana in foc) nu se mai binduiesc la o statie resetata.
Ca sa interfereze cu alta statie, trebuie ca si aceea sa fie defecta, cu GUiD-ul resetat. Deci doua statii, una buna, cealalta defecta, ar trebui sa functioneze impreuna fara probleme in teorie.
Statiile afectate de bug se reseteaza daca: s-au aprins-stins intr-un interval mai mic de 5 secunde sau accumulatorii au fost descarcati foarte rau. Chestiile acestea doua se pot preveni foarte usor de catre utilizator.
Sunt prea multi de poate ca sa iti dai seama daca interferentele au fost provocate de o a doua statie.
