Modelism - RHC Forum: indicator tensiune baterie - Modelism - RHC Forum
indicator tensiune baterie voltmetru
#1 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 03:24 PM
voi prezenta o schema simpla pentru confectionarea unui voltmetru pentru a vedea starea bateriei (acumulatorului)
Parts List
R1 = 180k P1 = 20k trimmer multi turn
R2 = 22k U1 = ICL 7107
R3 = 12k LD1,2,3,4 = MAN 6960 common anode led displays
R4 = 1M
R5 = 470k
R6 = 560 Ohm
C1 = 100pF
C2, C6, C7 = 100nF
C3 = 47nF
C4 = 10nF
C5 = 220nF
#2 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 03:25 PM
cablaj
#3 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 03:27 PM
ansamblu
#4 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 03:28 PM
si cablajul efectuat de mine
#5 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 03:29 PM
dupa gaurire
#6 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 03:31 PM
cam atat momentan ca tre sa ma apuc sa lipesc piesele pe el sa vad ce iese
#7 Useril este offline   HESS
  • Postari: 955
  • Inregistrat: 08-October 07
Postat 24 January 2008 - 06:44 PM
mariandmd, la 24 Jan 2008, 15:29, a spus:
dupa gaurire
Stapanul.....cablajelor! :) :) Lucrezi frumos!
#8 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 07:21 PM
din pacate cred ca am ars circuitul
l-am alimentat la 6,5V
#9 Useril este offline   HESS
  • Postari: 955
Postat 24 January 2008 - 07:27 PM
Nu folosesti socluri??? Rau!
#10 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 07:30 PM
#11 Useril este offline   mariandmd
  • Postari: 2161
Postat 24 January 2008 - 07:31 PM
#12 Useril este offline   vasia
  • Postari: 1049
  • Inregistrat: 26-April 04
  • Interests:navomodelism
Postat 25 January 2008 - 01:57 PM
pacat de incident sper sa nu renunti,
spor
#13 Useril este offline   OldMann
  • Postari: 1762
Postat 25 January 2008 - 04:25 PM
mariandmd, la 24 Jan 2008, 19:21, a spus:
cum l-ai alimentat la 6,5V daca el se alimenteaza cu tensiune diferentiala.
schema e putin gresita..... daca te uiti pe cablajul original prezentat de tine, ai sa vezi ca pinii 30,32,35 lui ICL7107, sunt legati impreuna, ceea ce la cablajul facut de tine nu e.
Incearca sa faci alimentare diferentiala de +/-5V si va merge.
Poti sa-ti largesti orizontul http://pdf1.alldatasheet.com/datasheet-pdf...IL/ICL7107.html
Aceasta postare a fost editata de OldMann: 25 January 2008 - 04:36 PM
#14 Useril este offline   ipsihi
Postat 25 January 2008 - 11:28 PM
OldMann, la 25 Jan 2008, 17:25, a spus:
no comment!
#15 Useril este offline   nch
  • Postari: 1121
Postat 26 January 2008 - 02:43 AM
A facut el 3 barcute cap coada in 3 luni si regulatoare cu PIC nu vad de ce nu i-ar iesi http://www.rhcforum....tyle_emoticons/default/tongue.gif
din cate il stiu eu e al dracu de incapatanat si o sa-i iasa :rolleyes:
0745.356.013
Bucuresti/Rahova
#16 Useril este offline   mariandmd
  • Postari: 2161
Postat 26 January 2008 - 08:16 AM
OldMann, la 25 Jan 2008, 16:25, a spus:
la mine este facut cablajul in oglinda
am montat piesele invers fata de montajul original
icl-ul l-am pus pe partea cu circuit iar dip-urile le-am montat pe cealanta parte a cablajului
#17 Useril este offline   mariandmd
  • Postari: 2161
Postat 26 January 2008 - 08:20 AM
ipsihi, la 25 Jan 2008, 23:28, a spus:
no comment!...?????
de ce????? :rolleyes:
#18 Useril este offline   OldMann
  • Postari: 1762
Postat 26 January 2008 - 08:27 AM
de obicei bulinuta patrata de pe cablaj indica pinul 1 al integratului, la tine e invers, indica ultimul pin, ceea ce ma dus in eroare.
Ce e cu tensiunea ce alimentare?
#19 Useril este offline   mariandmd
  • Postari: 2161
Postat 26 January 2008 - 08:33 AM
ma gandesc ca l-am alimentat la 6,5V si cred ca s-a ars circuitul
la inceput a indicat 3 litere de 6
acum indica pe dip1 numarul -1
#20 Useril este offline   OldMann
  • Postari: 1762
Postat 26 January 2008 - 08:37 AM
nu inteleg, +/-6,5V, sau simplu 6,5V?
#21 Useril este offline   iony
  • Postari: 2347
  • Inregistrat: 06-April 07
Postat 26 January 2008 - 08:38 AM
deci toata treaba este sa nu te dai batut dai tot inainte ca va merg atentie la detaliile carora nu le dai importanta mai mereu acolo este o greseala :rolleyes:
#22 Useril este offline   mariandmd
  • Postari: 2161
Postat 26 January 2008 - 08:59 AM
cu +/- 6,5V iar el merge cu +/-5V
#23 Useril este offline   OldMann
  • Postari: 1762
Postat 26 January 2008 - 09:10 AM
mai simplu , si nu trebuia sa-l alimentezi din doua pac-uri de accu faceai schema atasata pentru -5V. O faci pe acelasi cablaj si poti sa-l alimentezi si in 12V...24V.
#24 Useril este offline   mariandmd
  • Postari: 2161
Postat 26 January 2008 - 09:13 AM
saptamana viitoare il rezolv
tre sa ajung sa-mi cumpar inca un icl si o sa-l rezolv
#25 Useril este offline   OldMann
  • Postari: 1762
Postat 26 January 2008 - 09:35 AM
poate te ajuta http://www.adelaida.ro/product_info.php?cP...roducts_id=1948
#26 Useril este offline   Malibu Fish
  • Postari: 180
  • Inregistrat: 22-January 08
Postat 26 January 2008 - 09:06 PM
MAI BAIETZI SPECIALISTI IN ALE ELCTRONICII:
Am si eu o intrebare???
CUM aprind un bec cu un canal de la telecomanda?????
Nu reusesc sa ma prind
Help
Malibu twin
Hammer Aquacraft
Traxxas Nitro4tec
Katana S50 10cc OS61FX
Cessna 182 - EP
#27 Useril este offline   ipsihi
Postat 26 January 2008 - 09:19 PM
...faci un switch rc cu CD 4001 sau CD 4093, scheme gasesti pe net!
#28 Useril este offline   Malibu Fish
  • Postari: 180
Postat 26 January 2008 - 09:35 PM
Sunt varza la electronica
Lamureste-ma ca pe un prost
Pls
Malibu twin
Hammer Aquacraft
Traxxas Nitro4tec
Cessna 182 - EP
#29 Useril este offline   nelu bv
  • Postari: 658
  • Inregistrat: 19-May 07
Postat 03 February 2008 - 02:25 PM
mariandmd, la 26 Jan 2008, 09:13, a spus:
http://www3.towerhobbies.com/cgi-bin/wti00...94&I=LXHDJ2&P=K
Decat sa bei si sa conduci mai bine fumezi si zbori !!!!!!!
#30 Useril este offline   aclaimed
  • Postari: 69
  • Inregistrat: 02-May 06
Postat 08 February 2008 - 01:00 PM
hehehhe stau si citesc si ma amuz ...mai oameni buni ,, baiatul nu le are in ale electronicii. Mai bine al sfatuim sa aprinda un bec cu un servo. Degeaba al trimitem la scheme complicate si prea stiintifice pt el . Probabil ca nici nu stie ce este un NPN sau PNP. Malibu .. iei matalutza una bucata servo, una bucata microintrerupator cu lamela , una bucata plastic pentru a monta piesele astea 2 pe ea . Iti montezi servoul apoi bratul de la micro pe lamela microintrerupatorului . faci cateva probe si vezi si tu in ce pozitie este inchis si deschis. si mai departe legi un bec prin microintrerupatorul cu lamela , iar din radiocomanda iti inchizi si deschizi microul .
Indiferent cu ce se ocupa oamenii de stiinta, ei obtin intotdeauna o arma.
