Modelism - RHC Forum: Advanced flight module pentru Spektrum - Modelism - RHC Forum
#1 Useril este offline   Adrian Dumitru
  • Postari: 49
  • Inregistrat: 06-April 20
  • Interests:zbor fixed wings / avioane electric / gaz
Postat 03 April 2023 - 09:30 AM
De vinzare Booma advanced flight module pentru statie Spektrum,
Smooth flite, like flying on a calm day
Welcome to the world's lightest and most advanced 26 channel Gyro and Power distribution system. SmoothFlite - Giant Scale RC flying just got better.
We have focussed extensively on the user experience being ultra simple-to-use and all reports we have had back from our test team say we have hit the nail on the head. Super simple to use compared to all other well know systems.
Smooth Flite gives you the confidence of dual redundant receivers high current regulated power with 26 fully programmable channels, 3 axis gyro, 3 axis accelerometer, compass and a barometer, 3 optional Sequencers and easy setup with a full colour touch screen interface. The Smooth Flite system allows you to assign as many Gyro outputs as necessary, allowing even the largest of Scale models to have the ease of control that a gyro allows.
Smooth Flite algorithm has been specially designed for RC models so that you can guarantee locked in performance. We use state of the art programming to predict and calculate where your model is headed, giving Smooth Flite an advantage over other Gyros.
FEATURES AND SPECIFICATIONS:
* Redundant Receiver system – works with up to 4 spektrum satellites
* TM1000 telemetry ready
* 26 fully programmable and assignable channels
* Works with single or dual battery configuration.
* Works with all battery chemistries. LiFe. LiPo, Lion, NiMh, NiCD.
* Full Dual Battery Redundancy - If one battery fails the other battery takes full control..
* Vibrant Colour 2.4inch diagonal touch screen with 64k colour
* Screen case dimensions 3.4 x 2.0 x 0.5 inches (86 x 50 x 12)mm
* Smooth Flite dimensions 4.2 x 3.0 x 0.9 inches (107 x 78 x 23)mm
* Smooth Flite weight (108gms) without colour screen.
* Triple regulator design with dual 100A power regulator FETS.
* Multi-match technology.
* 3 axis gyro, accelerometer, compass and a barometer.
* Advanced Radio Proprietry Smooth Flite algorithms.
* Optional sequencer package providing 3 sequencers.
Supports Spektrum Satellite receivers
Smooth Flite Spektrum will operate with up to 4 x SPM9645 or 4 x SPM9745 satellite receivers for enhanced coverage in any model.
Twenty Six fully assignable and programmable outputs
Looking at that next big project and wondering how you’re going to power all those servos, the Smooth Flite system is equipped with 26 fully programmable outputs, all via a single cable connected to your receiver. Each channel is freely assignable to any input and can be reversed and matched to any other channel on the Smooth Flite. Building that next giant scale model Smooth Flite has got it covered.
Easy to Use
Smooth Flite comes with pre-configured channel mapping that matches your Spektrum radio brand so model setup is really simple. Of course for advanced setups all 26 channels can freely assigned to any transmitter channel.
Smart Bus RRS gives you live feedback of both your batteries on your radio. Monitor the voltage and capacity used out of each of your batteries at any time during the flight. Ensure your batteries are ready for the next flight.
The Next standard in servo Matching.
In the RC industry precision is key. How can you expect to be precise when no two servos are identical, giving you varied results no matter how well you mechanically match them. Match your servos across 15 individual points, with 8000 step resolution and you can finally achieve matched perfection on your elevators, flaps, multi-engines and more. Take the hassle out of your new setup and have a model that raises your skills.
Sub-trim and reverse on all outputs
Ever spent hours, mechanically matching servos and never being able to get them just right or had to use a separate channel on your receiver, just to reverse a servo. With our intuitive and simple setup you can easily sub-trim at the centre and end-points of all your outputs on the Smooth Flite. Using Smooth Flite you can individually reverse your servos at a touch of a button. Smooth Flite gives you ultimate power at your fingertips.
Regulated voltage gives you precise, repeatable, results.
It is hard to be the best with a model that changes. With our high powered 220A regulator FETS we remove the change and give you pure constant regulation. As batteries are used their voltage drops, changes in voltage mean changes in speed and power of your servos. Regulating ensures your model is the same time after time.
<br style="font-size: 13px; background-color: rgb(250, 251, 252);">Poate configura toate caracteristicile de zbor ale unui aeromodel, gyro integrat. Impreuna cu modulul se vinde un magnetic switch, status led, trei sateliti Spektrum , consola de configurare, cablu pentru update si doua baterii Life.
Pretul este de 1000 lei.
  • Fisier atasat  1.jpg (66.9K)
  • Fisier atasat  2.jpg (75.61K)
  • Fisier atasat  3.jpg (73.12K)
  • Fisier atasat  4.jpg (75.78K)
  • Fisier atasat  6.jpg (58.18K)
  • Fisier atasat  5.jpg (71.84K)
#2 Useril este offline   Adrian Dumitru
  • Postari: 49
Postat 15 April 2023 - 11:35 AM
Bună ziua. Deoarece constat că nu prezintă nici un interes cu toate că este un accesoriu de mare calitate și importanța pentru un avion performant, am hotărît să îl scot din secțiunea de vânzări și să îl fac cadou unui bun prieten care zboară cu multa mîndrie Spectrum. Sa Aveti o zi minunata și zbor lin!
  • Postari: 3959
  • Inregistrat: 19-August 12
Postat 16 April 2023 - 08:02 PM
Poate pentru ca e un gyro de $15 cu un ubec de $20 care merge doar cu cel mai de... sistem RC din cate exista. Zic si eu. Asta e produs pt sua unde le e greu si sa fiarba apa.
#4 Useril este offline   Adrian Dumitru
  • Postari: 49
Postat 17 April 2023 - 02:59 PM
Vezi postareaCiprian97, la 16 April 2023 - 08:02 PM, a spus:
Daca te referi la Flight controlerul pe care am vrut eu sa il vind, in primul rind este australian. In totyal a costat 700 $. Daca cunoasteti limba engleza sus in primul post am copiat si postat caracteristicile acestui controlor de zbor. Si nu, nu este un produs de slaba calitate. Este bine sa va retineti de a face evaluari atunci cind nu aveti cunostiinte. Multumesc.
