Modelism - RHC Forum: Servo Mini-Micro - Modelism - RHC Forum
Servo Mini-Micro Noi
#1 Useril este offline   Zorba
  • Postari: 285
  • Inregistrat: 14-July 19
Postat 16 March 2021 - 05:20 PM
Vand
Servo
1.Hextronik MG-14 Digital
Specs:
Weight: 14g
Dimension: 22.8x12x31 mm
Voltage: 4.8v / 6v
Speed: 0.13sec/60deg (4.8v) - 0.11sec/60deg (6v)
Torque: 2.2kg.cm (4.8v) - 2.6kg.cm (6v)
Gear Material: Metal
Gear Type: Digital
Motor: Brushless
Bearing: Double ball bearing
Servo case: Middle alloy, upper and lower plastic
Temperature range: 0- 55deg
Dead band width: 1us
servo wire length: 25cm
Servo Plug: JR (Fits JR and Futaba)
6 BUC.
Pret :40 Lei Buc.
2.Power HD 1810 MG Digital
Specs:
Weight: 15.8g
Dimensions: 23 x 12 x 29mm
Torque @ 4.8V: 3.1 kg/cm
Torque @ 6.0V: 3.9 kg/cm
Speed @ 4.8V: 0.16 sec / 60° at no load
Speed @ 6.0V: 0.13 sec / 60° at no load
Gear: Metal gear/Ball bearing
Type: Digital
4 Buc.
Pret : 70 Lei Buc.
3.Micro servo WAVGAT SG90
Weight: 9 grams
No-load speed: 0.12 seconds / 60 degrees (4.8V)
Stall torque of 1.2 - 1.4 kg / cm (4.8V)
Operating temperature: -30 to +60 degrees Celsius
Dead-set: 7 microseconds
Operating voltage: 4.8V-6V
5buc.disponibile
Pret: 15 lei buc.
Tel: 0787 828 507
#2 Useril este offline   Zorba
  • Postari: 285
Postat 30 March 2021 - 12:59 PM
Oferta : 500 lei tot....
#3 Useril este offline   Zorba
  • Postari: 285
Postat 10 April 2021 - 12:54 PM
Ultima oferta
Tot la 450 lei
#4 Useril este offline   Zorba
  • Postari: 285
Postat 28 April 2021 - 04:30 PM
Vezi postareaZorba, la 10 April 2021 - 12:54 PM, a spus:
Ultima oferta
Tot la 450 lei
Valabil....
#5 Useril este offline   Zorba
  • Postari: 285
Postat 17 June 2021 - 12:24 PM
Ultima reducere...
Tot la 400 Lei
Valabil o saptamana ,dupa se retrag.
