Modelism - RHC Forum: Radiocomanda 9x ieftina - Modelism - RHC Forum
#1 Useril este offline   rc.ovidiu
  • Postari: 148
  • Inregistrat: 26-November 15
Postat 25 October 2020 - 12:11 PM
De vanzare radiocomanda Turnigy 9x AFHDS2
Este noua (doar butonata de cateva ori)
Are o problema cu softul - se blocheaza (nu se intampla frecvent dar poate fi deranjant)
Probabil o resoftare ar rezolva problema pt cine se pricepe
Cu modul AFHDS2 si receptor 8 canale
170 RON
Features:
• AFHDS 2A Protocol
• 8 Model Memory
• Multi-channel Frequency Hopping
• Omni-directional gain antenna
• Unique ID recognition system
• Low power consumption
• SBUS/IBUS and CPPM/PWM support
Transmitter Specs:
Number of channels: 9
Model Types: Helicopter, fixed-wing, and glider
Frequency range: 2.408-2.475GHz
Transmitter power: Not more than 20dBm
Number of bands: 135
Bandwidth: 500KHz
2.4GHz protocol: AFHDS 2A
Encoding: GFSK
Channel resolution: 4096
Low voltage alarm: Below 9V
Charging interface: None
Antenna length: 26mm
Weight: 690g
Input power: 12V DC, 8 x “AA” (1.5V)
Display: STN semi-permeable positive lattice VA 73 39mm LCD
Color: Grey
Online Update: N/A
Certification: CE, FCC ID : N4ZRM00300
Receiver Specs (iA8):
Number of channels: 8
Bandwidth: 500KHz
Receiver: -105 dBm
Modulation type: GFSK
Stick resolution: 1024
Input voltage: 4.0~6.5V DC
Weight: 13g
Size: 25 x 8.1 x 44.5mm
Certification: CE, FCC ID : N4ZIA800
Included:
Turnigy 9x 9Ch Transmitter
Turnigy AFHDS 2A module
Turnigy iA8 8-channel receiver
  • Fisier atasat  TGY1.jpeg (205.46K)
  • Fisier atasat  TGY2.jpeg (215.18K)
  • Fisier atasat  TGY3.jpeg (216.78K)
  • Fisier atasat  TGY4.jpeg (165.87K)
#2 Useril este offline   rc.ovidiu
  • Postari: 148
Postat 28 October 2020 - 10:39 PM
Vandut
