Modelism - RHC Forum: Spektrum NX 6 /8 /10 - Modelism - RHC Forum
#1 Useril este offline   ender67
  • Postari: 2315
Postat 16 October 2020 - 06:38 PM
Parca erau si cativa utilizatori de Spek pe aici...sau au primit statiile OpenTX intre timp?
https://www.rcgroups...NX-Transmitters
#2 Useril este offline   ender67
  • Postari: 2315
Postat 16 October 2020 - 06:55 PM
https://www.horizonh...n=&lang=default
310 USD NX6 (poate sa intereseze doar pe aiai cu drone), 370 bundle NX6 cu receptor (misto idee de receptor la 60 de dolari...la pretul asta altii dau statia si vreo 2 receptoare), 350 USD NX8 (aicii incepe sa devina interesant...cred ca aici se asteapta la vanzari masive) si in fine NX10 la 500 USD.
Toate sunt la Pre-order dar NX6 cica va fi disponibil in octombrie (ceea ce imi confirma ca nu se asteptau la vanzari mari si a fost doar un lot mic usor de produs), NX8 disponibil in ianuarie 2021 (aici probabil vor aveam vanzari ceva mai mari...dar mai incolo) si bineinteles NX10 disponibil in noiembrie sa faca un pic de malai in sezonul traditional de vanzari Black friday & Christmas.
Aceasta postare a fost editata de ender67: 16 October 2020 - 06:56 PM
  • Postari: 8341
Postat 17 October 2020 - 10:52 AM
Arata bine/tentant. DX9 - singurul radio Spektrum care era pe radarul meu avea deja o varsta venerabila. Tipul asta zice destul de bine cum sta Spektrum fata de OpenTX:
https://www.rcgroups...67&postcount=33
Originally Posted by krafty
What a bummer. Even multi-protocol £100 opentx transmitters appear to have more features than Spektrum. I am a long time Spektrum flyer with old dx7 and dx8 transmitters and a shed-load of dsm2 and dsmp receivers, but the pull of the latest breed of inexpensive Taranis/Jumper/Radiomaster radios is very strong. I am seriously asking myself why on earth I am considering upgrading to a Spektrum NX, when for little more than pocket money I could give an opentx multi-protocol transmitter a go. I wouldn't even have to give up the valuable Spektrum model match feature. After all if the trial doesn’t work out, it would hardly be a big financial loss. I wonder how many people feel the same as I do.
I know where you're coming from. That's the reason why I bought an X9D+ several years ago instead of a DX8G2 to replace my X9503 and I went all in on FrSky in early 2019 (selling off my DX18G1, which I'd later bought used)
I'm now back primarily on Spektrum.
I lost a lot of trust in FrSky over the ACCESS debacle last year, with the ISRM Upgrade Module authentication fiasco being the last straw. I really like my Horus, but I'm not buying new FrSky hardware.
The Jumper/Radiomaster TX's have a string of QA and design related issues that I'm simply unwilling to deal with. Plus at best vestigial support and questionable legality (No MPM option is EU legal or Canada-legal. Jumper's FCC cert is real, but arguable fraudulently filed as only one RF chip was tested. Radiomaster is FCC legal).
OpenTX is an amazing operating system. I'm quite a fan of it. Not a fan at all of the currently available hardware to run it though.
Yes, Spektrum is more expensive.
Spektrum makes sure their gear is EU, ISED, and FCC legal (and anything required in other regions).
It's a LOT better QC'd than Jumper/Radiomaster (which are the worst transmitters on the market from the perspective of out of box failures or known failure modes due to physical design issues, notably the ribbon cable issue). You can actually get support easily, trading model files is much easier and Horizon publishes downloadable model files on their site.
The NX and iX series have numerous features that none of the OTX radios have (Wifi in particular, OTA radio updates is a world-beater. The iX series add a bunch more capabilities). The OTX radios have some features that Spektrum lacks (notably the ability to use telemetry inputs as control inputs or to run arbitrary scripts which can talk to the aircraft)
Aceasta postare a fost editata de stiganas: 17 October 2020 - 11:43 AM
#4 Useril este offline   mvpricop
  • Postari: 1424
  • Inregistrat: 08-February 06
Postat 17 October 2020 - 03:16 PM
Nu pot sa zic ca sunt vreun mare fan, dar folosesc Spektrum si Macbook (la mana a doua). ;)
Cu sau fara de motor,
Io le zbor pentru popor!
Schaum vor dem Mund,
Und Papier fuer der Fund!
  • Postari: 8341
Postat 17 October 2020 - 05:44 PM
Mai degraba un mare barosan. Sunt ceva bani in statiile alea.
Vezi postareamvpricop, la 17 October 2020 - 03:16 PM, a spus:
#6 Useril este offline   ender67
  • Postari: 2315
Postat 17 October 2020 - 05:50 PM
Nu se vede in poza ..dar probabil intr-un sertar al biroului e gentuta cu Jeti ...
#7 Useril este offline   Horja
  • Postari: 1884
  • Inregistrat: 10-January 08
Postat 17 October 2020 - 07:58 PM
Trebuie sa ma confesez.... am admirat dintotdeauna aspectul phallusian al statiilor spektrum B) :clapping:
Aceasta postare a fost editata de Horja: 17 October 2020 - 07:59 PM
#8 Useril este offline   ender67
  • Postari: 2315
Postat 17 October 2020 - 08:27 PM
Uite de-aia am vandut eu statia Flysky FS-i6 ...am simtit intotdeauna ca "ce zici matale acolo" era prea mica ...
In alta opdine de idei ...folcloru' zice ca nu conteaza lungimea (ci conteaza lungimea de unda) ... un lambda pe 4 (adica vreo 31 mm ) cica ar fi de ajuns ...
Idee: SPek-urile au motoras pentru feedback haptic? Se poate monta in plasticul ala de la antena?
  • Fisier atasat  nx10.jpg (149.15K)
  • Fisier atasat  FSi6.jpg (122.26K)
Aceasta postare a fost editata de ender67: 17 October 2020 - 08:30 PM
  • Postari: 8341
Postat 17 October 2020 - 09:35 PM
Cica toate statiile astea noi, NX, au doua antene la 90 grade pentru diversity (DX9 avea deja asta).
#10 Useril este offline   mvpricop
  • Postari: 1424
Postat 17 October 2020 - 09:52 PM
DX6 a costat cam mult la mana a doua, 2019. Bateria e de la HK si nu are sursa si nici port de incarcare. Trebuie sa deconectezi bateria si sa o incarci direct.
Dx9 a fost 350 Euro cu receptor cu doi sateliti (din Germania, intamplator, 2015). Deja m-a lasat bateria originala si am cumparat de la HK. Este singura statie cu sursa de incarcare.
Softul intre DX6 si DX9 arata la fel. Sunt vizibile numai diferentele date de nr. diferit de canale.
IX12 a fost 1700 lei, adica jumatate din pret, cu un noroc imens. Nu este furata, este inregistrata pe site ca si celelalte. Nu are sursa, ca se incarca pe micro-USB.
Are Android si poti sa vezi filme cu ea, dar nu are si camere fata/spate. Mi-ar fi placut. :)
Airware de Android este alta poveste, dar este acelasi meniu. Problema este cu ecranul, care e relativ mic si degetele merg cam ciudat, mai ales pe margine.
Mi-ar fi placut mult rola consacrata cu Android.
Airware se incarca prin Play Store, ceea ce este enervant.
Statiile noi au ecran color, ceea ce nu-i rau deloc. Ecranul mai mare iarasi e un plus.
Trebuie sa faca si Spektrum ceva fata de chinezi...
Despre emailurile la Spektrum, desi puneam mereu aceeasi intrebare stupida, am primit mereu raspuns prompt.
Drive-ul SD este cam prost si cam pretentios. Cardul trebuie formatat FAT32, cluster size 512 kB. Daca nu e asa, poti bloca statia daca o pornesti cu cardul - DX9. DX6 pare mai tolerant.
Daca nu e cardul formatat corect, nu poti face update de soft: se blocheaza in proces, dar nu se strica statia. :)
Modelele din DX6 si DX9 se copiaza pur si simplu in IX12 si merge.
Conectarea elev-profesor merge intre toate, wireless.
Pana la urma, nimic nu e simplu.
#11 Useril este offline   ender67
  • Postari: 2315
Postat 18 October 2020 - 10:27 AM
Trag concluzia ca pentru cei cu Spek e mai greu cu upgrade-urile (chiar si la mana a doua) ... desi poate ar merita.
Pe de alta parte: intotdeauna am considerat ca Spektrum e o marca "locala" prentru SUA, cu preturile adaptate pentru puterea lor de cumparare. Si ca sunt cumparate inclusiv din patriotism si mandrie locala.
Tot asa cum e posibil sa fie si targetul Multiplex si Graupner. Multiplex de exemplu vinde o gama larga de produse, de la "baukit" de Easystar 3 de 95 de euro (ca vad ca a disparut Panda din oferta lor) la statii de 2700 de euro:
https://www.multiple....rx-9-dr-m-link
Spektrum cu iX20 la 1400 de dolari sunt cam pe la jumatate:
https://www.horizonh.../SPMR20100.html
Jeti trece si el de 2000 EUR cu modelele de varf:
https://www.lindinge...available+items
Ca sa nu mai vorbim de Futaba, ultimul model T32MZ e 2750-3000 EUR sau chiar 5000 EUR varianta Gold (probabil piata potentiala sunt pustii seicilor din Emirate):
Acum varful de lance al statiilor OpenTX de-abia atinge 400 USD (ca se roaga aia de tine: vrei un discount mai bun, da-ne un mesaj):
https://www.horusrc....grey-color.html
si in partea de jos pe la 90 USD ai niste statii cu care iti faci treaba decent:
https://www.banggood...ur_warehouse=CN
Ca sa nu mai vorbim de ieftinaturile FlySky entry-levelde 40 USD dar cu care s-au testat cu drone legaturi la 2.3 km parca (fara modificari):
Intre 90 USD si 5000 EUR e loc pentru toata lumea, si nu afirm nici ca poti sa faci cu statia de 90 de dolari ce faci cu aia de 5000 de euro dar nici ca statiile mai scumpe merita automat pretul.
Personal am considerat ca mai mult de 1000 lei / 200 EUR nu prea merita (mai ales la abilitatile mele) si bineinteles am tendinta sa favorizez software open source deci opent tx (la mine e deformatie profesionala).
Ceea ce m-a pus pe ganduri putin a fost urmatoarea postare:
Got my Radioking TX18S today. I have a Spekrum DX9 and a Jeti DS-12 Carbon Edition to compare with.
The case feels great, and the rubber grips are awesome. The TX18S is as comfortable to hold as my Spektrum DX9, and both of those radios are more comfortable to hold than my Jeti DS-12. The TX18S "frosted" plastic casing feels almost like a soft-touch plastic, it feels really quite good on the skin.
si comentariul urmator:
It is an excellent radio for the money. Probably the most important comparison is with radios in the same price category and not Spectrum and especially not Jeti. I did not have any issues with the scroll wheel. The speaker is excellent and one can really take advantage of that with Open TX.
I personally feel the Spectrum radios are over priced junk (I purchased one a few weeks ago and sent it back immediately) and the Jeti is above my pay grade
si raspunsul:
Yes, I agree, a *lot* of radio for the $110. Obviously not fair to compare to a $400 and a $700 radio, but alas, it is impossible not to compare when I have them all sitting next to each other.
Foarte interesant ca proprietarul de Jeti si DX9 a simtit nevoia sa cumpere si o ieftinatura de 100 de dolari. E drept ca tipul e din Norvegia deci sa zice ca "ar avea cu ce" si il doare in bascheti de faptul ca statia nu are (inca) certificare FCC si nici macar o chestie CE pe cutie (si daca ar fi aia ar fi sigla de "China Export" si nu certificarea europeana).
Si sunt 3 statii cu "filozofii" diferite: Jeti sa zicem ca are un hardware de calitate dar iti dau software cu taraita si pe banuti grei (optionale), de Spek nu stiu ce sa zic, sa zicem ca software-ul e OK si iti dau "hardware" cu taraita prin limitarea artificiala a numarului de canale (nu stiu cum mai vand astia statii cu 6 canale in 2020 la preturi umflate)...iar la OpenTX cam toate statiile au cam acelasi capabilitati dpdv software / firmware si platesti intr-un fel pentru calitatea hardware-ului.
Iar ceea ce s-a intamplat in ultimi 1-2 ani (spargerea "monopolului" FrSky pentru OpenTX si aparitia clonelor de X10 echipate cu MPM) cred ca e la fel de importanta ca semnificatie cu aparitia statie X9D la vremea respectiva.
Pentru ca multi vor avea tendinta sa cumpere statiile astea de 100 de dolari...si vor veni din directii diferite: si din partea celor care ar fi vrut sa dea 40-50 de dolari pe o ieftinatura Flysky/Turnigy (si o sa zica "lasa ca pentru 90 de dolari merita sa iau o statie cu ecran color si de care toata lumea zice ca merita".)..fie cei ca tipul cu DX9 si Jeti DC-12 (care probabil zic "m-am fript si cu aia de 400 de dolari, nu am fost multumit nici de aia 700 ca mai cereau bani, sa vad daca imi pot face treaba cu asta de 100").
Pentru ca la urma urmei...mai mult de 2 (hai sa zicem maxim 3) statii nu ai nevoie: statia principala, aiai de back-up si eventual una mai portabila petru calatorii.
De fapt de aia am deschis topicul asta cu staiile NX, as vrea sa aud opinia unor colegi care au si Spektrum: avand in vedere oferta de pe piata considerati in viitor un upgrade la statii NX sau mai bine incercati o statie care costa cat 1-2 receptoare Spektrum?
PS stiu ca e cam offtopic...ar fi fost mai mult din categoria aia cu ce a adus anul trecut si ce va urma in anii viitori
Aceasta postare a fost editata de ender67: 18 October 2020 - 10:32 AM
  • Postari: 8341
Postat 18 October 2020 - 12:04 PM
Gresesti masiv.
Ai nevoie de o singura statie, intotdeauna o singura statie. Daca faci upgrade la statie (fie una mai buna/noua fie schimbi sistemul) aia veche dispare.
Vezi postareaender67, la 18 October 2020 - 10:27 AM, a spus:
Postat 18 October 2020 - 04:14 PM
Vezi postareastiganas, la 18 October 2020 - 12:04 PM, a spus:
Gresesti masiv.
Aici sunt de acord cu Stiganas. Am avut de fiecare data o singura statie.
Prima a fost Futaba 7C in 72Mhz. Aveam receptoare Berg, niste mici bijuterii.
A doua, Aurora 9. Hitec a fost pionierul telemetriei si a ecranului tactil.
A treia, Aurora 9X. Am schimbat Aurora 9 pentru ca Aurora 9X avea doua procesoare. Sincer nu am vazut diferente. Am schimbat-o cand Hitec a incetat sa mai produca statii.
A patra a fost Graupner mz 18 Hott. Mi s-a lipit de suflet. Imi plange inima si acum. Am schimbat-o cand Graupner a inchis pravalia.
A cincea este Spektrum iX 12.
Aurora o folosesc si acum cu modelele care au fost echipate cu receptoare Hitec.
Modelele noi le fac cu receptoare Spektrum.
#14 Useril este offline   SORIN CAIUS
  • Postari: 2103
  • Inregistrat: 02-November 05
Postat 18 October 2020 - 06:17 PM
Salut baieti,
poate aveti dreptate dar eu am mai multe statii .Am 4 old timere, 2 Robbe Mars pe 35 mhz, 2 Robbe Mars Rex 35 mhz , toate arata ca noi , foarte putin folosite sau deloc, am la ele 10 receptoare, si quarturi. De asemena am servo originale Robbe NOI si ca noi. E o placere sa ma joc cu ele.Una o folosesc pentru un model old timer, urmeaza si celelalte.
Mai am X9D upgradata cu Hall, care e statia de zi cu zi , pe care am majoritatea modleleor si la care nu voi renunta prea usor pentru ca e exceptionala (parerea mea).
Pe langa X9D, sta si QX7S, pe care o folosesc doar in interior in hala de la firma, care e mare , nu a iesit din casa si de care sunt foarte multumit.
Si maine sau maxim poimaine vine TX18S sa vedem ce stie si aia.
Nu mai spun de statia de la Phantom P3 Pro si statii de la chinezarii care, functioneaza toate.
Mie mi le plac toate si am grija de ele, ma bucur si cand le vad si le sterg de praf, darminte cand ma joc cu ele.
Bafta Ciao Sorin
Aceasta postare a fost editata de SORIN CAIUS: 18 October 2020 - 06:20 PM
#15 Useril este offline   stiganas
  • Postari: 8341
Postat 18 October 2020 - 06:45 PM
Si aici este si raspunsul. Pentru mine conteaza mai mult receptoarele decat statia. Statia e una singura, modele am vreo 50.
Spektrum este printre putinii (din cei care conteaza) care nu a schimbat de N ori protocolul, nu a abandonat receptoarele vechi.
2005 - DSM - DX6/AR6000 - primul sistem 2.4 Ghz inlocuit in
2006 - DSM2 - DX7 si DX6i + statii mai rasarite JR si
2011 - DSMX - DX8, DX9 - telemetrie, etc.
Am cumparat prima statie Spektrum DX6i in 2007 (dupa ce ajunsesem sa am ciorba de statii in FM) cu 4 receptoare la promotie - receptoarele merg si azi (mai putin unul care s-a busit), am trecut la JR9303 (DSM2) si JR11X (DSMX) si asta e tot. Daca ar fi sa cumpar alta statie Spektrum, o cumpar din USA ca sa fie compatibile cu DSM2. Din pacate am un receptor DSM AR6000 din 2005 si asta nu mai e suportat si din pacate cred ca nici modulul 4in1 din OpenTX nu il suporta.
Dan a ramas cu receptoare Hitec si Graupner orfane.
Futaba a trecut prin destule protocoale, FrSky la fel si sunt magari, Graupner, Multiplex, Jeti nu stiu ce viitor au. Hitec si JR sunt out. Asa ca pentru mine viitorul e Spektrum sau OpenTX de aia am si luat un RadioKing sa vad cum e OpenTX. Si NU TREBUIE SA BUSEASCA MODELE.
Vezi postareadan_mitea, la 18 October 2020 - 04:14 PM, a spus:
#16 Useril este offline   SORIN CAIUS
  • Postari: 2103
Postat 18 October 2020 - 07:13 PM
Stefan,
discutabil , daca ai salvat softul, poti rescrie softul, pe receptoarele noi pe care le cumperi, in cazul Fr Sky.
Io mi-am salvat in mai multe locuri softurile de la receptoarele pe care le folosesc, cu FR SKY , varianta ACCST scrisa in 2018 pe X9D si QX7S e si ea salvata, asa ca sper ca in urmatorii ani sa nu mai am probleme majore.
La ce poate face varianta de soft din 2018, cred ca e suficient pentru urmatorii 10 ani pentru mine si cred ca mai cumpar ceva receptoare si ies binisor la pensie cu ele.
Statiile pe care le am le pastrez ,nu le vand,(oricum nu as lua pe ele bani ca sa merite, cateva sute de Euro nu conteaza , le tin de colectie) si le voi putea folosi cu receptoarele aferente
Bafta Ciao Sorin
#17 Useril este offline   stiganas
  • Postari: 8341
Postat 18 October 2020 - 07:24 PM
Cu statiile de colectie o inteleg foarte bine. Nici eu nu le-as da.
La frsky recunosc ca nu ma pricep, nu am urmarit dar am vazut ca sunt diverse serii si cand apar tabele de compatibilitati deja nu imi place.
E ca la Nikon vs. Canon. Orice obiectiv Canon EF din 1989 incoace merge cu orice aparat Canon. La Nikon ai nevoie de un tabel de compatibilitati.
  • Postari: 8341
Postat 11 February 2021 - 08:38 PM
Urmaresc topicul NX pe rcgroups (sunt tentat caci nu stiu cat ma mai tine JR11X) si nu imi place ce citesc.
Daca ar fi fost vorba de un Radiomaster/Jumper lumea i-ar fi calcat in picioare - asa fiind Spektrum sunt foarte intelegatori.
Bug-uri de software (statia scoate diverse fluieraturi aiurea), copierea modelelor din statiile anterioare este defectuoasa (fara trimuri), gimbal de trotle merge naspa (trebuie modat cu banda de teflon), unele receptoare DSM2 nu se binduiesc, la unu i s-a oprit din senim, soft varza (am mai spus-o). Bine ca e iarna altfel cine stie cate modele buseau pana acum.
#19 Useril este offline   ender67
  • Postari: 2315
Postat 11 February 2021 - 11:30 PM
Nu exista software fara bug-uri. Asta poti sa o treci la chestiile sigure: moartea, taxele...si bug-urile. Orice chestie noua pe care o introduci in software ('feature") poate sa introduca bug-uri.
De aceea la software exista variante "alpha" (cu noi chestii), "beta" (nu se mai introduc chestii noi ci incep sa se vaneze bug-uri, testare pe un grup mai aventuros dornic de senzatii tari) si "release candidate" (bune pentru tot poporul de testat, nu se mai asteapta sa se gaseasca noi bug-uri, daca intr-un timp de nu apar se trece la ...) ..."release".
Ceea ce e misto la open source (OpenTX si MPM) e ca procesul e public si deschis. Si n-au nici o treaba, nici o presiune comerciala, "e gata cand e gata". Si nu se porneste de la 0, exista o anumita continuitate.
De aia chinezii au ajuns la cicluri de lansare cam de 6 luni (sau chiar mai putin). Pe 31 decembrie 2019 Hobby Porter / RadioMaster au anuntat TX16S (doar niste randari grafice), prin primavara au inceput precomenzile, la inceputul verii am avut statia in mina.
Dupa ce a trecut zapaceala cu TX16s si T18 pe la inceputul toamnei 2020 au zis "hai ca trebuie si niste statii mai mici si mai ieftine". Pe la inceputul lui noiembrie au aparut anunturile pentru RadioMaster T12 si Jumper T-lite...la sfarsitul lui decembrie se livra deja T12 si in ianuarie T-lite. Deja T12 este suportat in 2.3.11 cred si T-lite in "nighties". Astia au ajuns la cicluri de lansare de la "hai sa facem o statie " la "primele statii livrate" de 3-4 luni. Si in timpul asta se ocupa si de matritele de carcase si de electronica si de software (e drept ca aici e mai usor, le zic alora de la OpenTX "vezi ca fata de Jumper T12 nu mai am deloc potentiometre si am doar 4 switch-uri, in rest e la fel").
Pe de alta parte astia mari au tendinta sa arunce totul peste bord din cand in cand si sa o ia de la 0. Si nu iese treaba ca lumea. Vezi cazul de la Spektrum NX. Vezi cazul Tandem de la FrSky, a fost anuntata grabit ca X11 in aprilie 2019 parca (sub presiunea T16) si de fapt a ramas moarta in cotet si a renascut ca X20 anuntata la teste in septembrie 2020...dar de atunci in 5 luni nu a fost certificata si nici la vanzare. Pentru ca au renuntat la OpentX si vor ceva nou (Ethos). (in schimb ieftinaturile RadioMaster si Jumper au avut timp in astea 3 luni sa faca si certificare FCC).
Cum ziceam, bug-uri sunt peste tot..dar parca mai putine la "ieftinaturile" astea care au cod solid OpenTX si MPM in spate. Si parca ai alte asteptari de la o statie de 300-500 dolari fata de una de 50-100 dolari. Paradoxal e ca la aia ieftina s-ar putea sa ai mai putine probleme legate de software.
#20 Useril este offline   ender67
  • Postari: 2315
Postat 12 February 2021 - 12:04 AM
Vezi postareastiganas, la 11 February 2021 - 08:38 PM, a spus:
Eu zic sa mai ai putintica rabdare. NX6 e 320 EUR la Lindinger (dar nu e pe stoc), 380 EUR varianta cu receptor, NX8 e tot 380 EUR (tot nu e pe stoc), NX10 e pe stoc dar la 540 EUR.
Daca incepi sa te descurci usor-usor in OpenTX (mai cu wizard, mai cu modele gata facute, mai cu modele copiate intre ele si modificate in Companion) iti mai iei un RadioMaster TX16S sau un Jumoer T18 (ca sa ai si 900 MHz intern) si de rest o gramada de receptoare. Sau motor si servo-uri. 120 EUR fata de 320 / 380 / 540 EUR (asa cum te stiu 380 sau chiar 540 EUR, una cu 6 canale iese din discutie).
Avantajul la statiile astea ieftine e ca se gasesc piese de schimb de poti sa le faci din bucati...si nu te costa scump. ceva gen 15 dolari un ecran sau 55 de dolari placa de baza ...sau carcasa fata la vreo 10 dolari. Si daca ai doua statii pe linag faptul ca ai un back-up cu modulul asta multiprotocol se mai poate face o smecherie: se poate face o clonare la binduirea receptorului. Adica poti sa lucrezi cand cu o statie cand cu alta la acelasi receptor, fara sa mai faci bind. Statia de rezerva perfecta.
Stiu ca te-ai hotarat cu greu sa cumperi prima statie OpenTX dar eu sper ca pe termen lung sa iti placa. Pentru ca in mod sigur valoarea unei statii nu sta in pret.
