Spec:
KV(RPM/V): 980
Lipo cells: 2-3s
Max Watts(W): 165
Max. current(10s): 15 amps
No Load Current: 0.5 amp
Intemal Resistance: 0.145 ohm
Number of Poles: 14
Shaft Size: 5mm
Dimensions(Dia.xL): 28 x 29 mm
Bolt Holes Spacing: 16 & 19mm
Bolt thread: M3
Connector: 3.5mm Bullet Type Connector
Weight: 58g
4x turnigy Multistar 4822-570Kv 450RON toate
KV(RPM/V): 570
Lipo cells: 4s
Max Surge Watts(W): 310
Working current: 15 amps
Max.current(10s): 21 amps
No Load Current: 0.65 amp
Intemal Resistance: 0.092 ohm
Number of Poles: 22
Dimensions(Dia.xL): 48 x 25 mm
Shaft: 6 mm
Prop: 12 x 3 - 14 x 5
Weight: 98 g
4x Turnigy Multistar 4225-390Kv 400RON toate
KV(RPM/V): 390
Lipo cells: 6s
Max Surge Watts(W): 330
Working current: 11 amps
Max.current(10s): 15 amps
No Load Current: 0.2 amps
Intemal Resistance: 0.24 ohm
Number of Poles: 16
Dimensions(Dia.xL): 42 x 24.5 mm
Shaft: 3 mm
Prop: 12 x 3 - 12 x 6
Weight: 86g
Pot sa le dau personal in Bucuresti doar la Mall Vitan.
Se pot trimite si in tara cu curier rapid. (plata avans revolut sau IBAN +15RON)
Daca e cineva interesat, va rog contact privat.
Number of downloads: 79 -
Number of downloads: 77 -
Aceasta postare a fost editata de alexvid: 02 August 2020 - 01:21 PM
