Modelism - RHC Forum: DVR pentru FPV (drone si alte jucarii zburatoare) - Modelism - RHC Forum
#1 Useril este offline   recdrone
  • Postari: 168
  • Inregistrat: 05-November 14
Postat 20 July 2020 - 06:17 PM
1. Black Box Micro D1M
Protective metal case;
Auto-start on power ON;
Time-stamp can be added;
Selectable clip size (1, 5, 10 or 15 minutes);
PAL/NTSC video standards;
HD (1280X720), D1(720X480) and VGA(640X480) recording formats;
5 ~ 15V power input.
in cutie cu accessorii originale
pret: 130 lei + transport
2.FXT DVR cu baterie incorporata si conexiune WIFI
720×576 (PAL) or 720×480 (NTSC) with 60fps recording;
H.264 video coding;
1/3/5/10 M video sequences;
Loop recording;
Wide range of input voltage (7-28V);
Removable belt clip.
pret 200 lei + transport
3. HMD VR Mini Digital Video Recorder
Power input: DC 5V
The output video format: PAL / NTSC selectable
Video output format (Video Output Size): VGA (640 x 480PX) D1 (720X480) HD (1280X480).
Optical frequency (Light frequency): 50HZ / 60HZ
Compression Format: MJPEG
Video frame rate: 30 frames
Maximum support TF card: 32G
Size: 41mm * 31mm * 9mm
Net weight: 16g
cu cablu confectionat de mine
pret 70lei + transport
cost transport prin curier aprox 30 lei
Mai multe detalii pe google
#2 Useril este offline   recdrone
  • Postari: 168
Postat 10 August 2020 - 06:59 AM
Up!
#3 Useril este offline   recdrone
  • Postari: 168
Postat 04 January 2021 - 10:05 AM
Up!
