Modelism - RHC Forum: Servo MG - Modelism - RHC Forum
Servo MG Noi
#1 Useril este offline   Zorba
  • Postari: 285
  • Inregistrat: 14-July 19
Postat 04 July 2020 - 02:14 PM
Servo
1.Hextronik MG-14 Digital
Specs:
Weight: 14g
Dimension: 22.8x12x31 mm
Voltage: 4.8v / 6v
Speed: 0.13sec/60deg (4.8v) - 0.11sec/60deg (6v)
Torque: 2.2kg.cm (4.8v) - 2.6kg.cm (6v)
Gear Material: Metal
Gear Type: Digital
Motor: Brushless
Bearing: Double ball bearing
Servo case: Middle alloy, upper and lower plastic
Temperature range: 0- 55deg
Dead band width: 1us
servo wire length: 25cm
Servo Plug: JR (Fits JR and Futaba)
6 BUC.
Pret :60 Lei Buc.
2.Power HD 1810 MG Digital
Specs:
Weight: 15.8g
Dimensions: 23 x 12 x 29mm
Torque @ 4.8V: 3.1 kg/cm
Torque @ 6.0V: 3.9 kg/cm
Speed @ 4.8V: 0.16 sec / 60° at no load
Speed @ 6.0V: 0.13 sec / 60° at no load
Gear: Metal gear/Ball bearing
Type: Digital
4 Buc.
Pret : 100 Lei Buc.
Tel. 0787 828 507
  • Fisier atasat  78216.jpg (31.03K)
  • Fisier atasat  8303.jpg (28.36K)
#2 Useril este offline   Zorba
  • Postari: 285
Postat 11 July 2020 - 06:54 AM
Reducere pret
1.50 lei buc.
2.80-lei buc.
Tot la 600 lei.
Valabil o saptamana ,dupa se retrag.
