Modelism - RHC Forum: Vand componente quad 3-5inch ESC, FC, frame, motoare, elici - Modelism - RHC Forum
Vand componente quad 3-5inch ESC, FC, frame, motoare, elici ESC ORI32 4in1, Omnibus F4 Nano V6, Emax RS1306B, Frame 3inch
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 05 May 2020 - 12:08 PM
-Original Airbot ORI32 4in1 Blheli_32 25A 2-4S DSHOT1200 ESC 20x20mm, cu telemetrie, manual, cablu 8pin si XT30, cu radiator si senzor curent pe fiecare ESC - 180lei
-Original Airbot Omnibus F4 NANO V6 OSD 5V/2A 8V/1A BEC LC Filter 2-6S 20x20mm, cu Baro si 5xUART, cu manual - 120lei
-Motoare Emax RS1306B 4000KV stare buna 4buc + 1buc nou - 200lei(5buc)
-Frame Iflight IH3 142mm 3inch 3mm carbon, suporta dual stack 20x20mm, greutate 37g - 100lei
-Elici Emax Avan 3024 3inch 10buc - 20lei
Tel: 0749 121 132
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 15 May 2020 - 08:06 AM
-Original Airbot Omnibus F4 NANO V6 OSD BEC 5V/2A 8V/1A LC Filter 2-6S 20x20mm, cu Baro si 5xUART, cu manual - 115lei
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 22 May 2020 - 01:08 PM
-Original Airbot ORI32 4in1 Blheli_32 25A 2-4S DSHOT1200 ESC 20x20mm, cu telemetrie, manual, cablu 8pin si XT30, cu radiator si senzor curent pe fiecare ESC - 170lei
-Original Airbot Omnibus F4 NANO V6 OSD BEC 5V/2A 8V/1A LC Filter 2-6S 20x20mm, cu Baro si 5xUART, cu manual - 110lei
Aceasta postare a fost editata de andrewbt: 22 May 2020 - 01:08 PM
Andrei
#4 Useril este offline   andrewbt
  • Postari: 1014
Postat 15 June 2020 - 07:39 AM
Andrei
