Pret: 300 RON
Tel: 0770-059.669
Vine cu softul modificat si aduce urmatoarele imbunatari fata de cel original:
- 14 canale fata de 6 initial (foarte util pentru inav/betaflight)
- transmite RSSI pe un canal separat fara a modifica firmware-ul RX-ului
- are timer pentru timp de zbor
- ecranul principal este reorganizat pentru a incapea mai mutla informatie
- permite modificarea switch-ului B din 2 in 3 pozitii
- permite modificarea switch-ului C in potentiometru
- permite adaugarea unui switch E suplimentar
Features:
• Entry level 2.4GHz radio with telemetry capability
• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches
• Easy to use Programming & Navigation Buttons
• Supports Heli/Standard Wing/Elevon/V-Tail
• 20 Model Memory
• 8 Character Model Name
• Trainer and charging ports
• 4 Stick Mode Selectable
• Optional telemetry receivers and sensors available separately
Basic Programm Functions:
Dual Rates, Sub Trim, Travel Adjust, Channel Reverse, Swash Mix, Gyro Sensitivity, Throttle Curve, Pitch Curve, Throttle Hold, Model Name
Turnigy TGY-i6 Transmitter Specs:
Frequency: 2.4ghz ISM Frequency Range
Modulation: GFSK
Spread Spectrum Mode: AFHDS 2A and AFHDS
Band: 142
Number of Frequency Channels: 20
Output Power: <=20dbm
Working Current: <=100mA
Working Voltage: 1.5v x 4 AA
Dimensions: 174x89x190mm
Weight: 392g
Resolution: 1024 bit
Stick Mode: Mode 2 (Throttle Left)
Aceasta postare a fost editata de Adrian Co: 17 May 2020 - 07:36 PM
