Modelism - RHC Forum: Servo Blue Bird BLS-H50B - Modelism - RHC Forum
#1 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
  • Inregistrat: 31-May 12
Postat 01 May 2020 - 09:28 PM
Servoul este ca nou, mai exact factory refurbished. Adica dupa 5 folosiri l-am ars, probabil din cauza mea, l-am alimentat la limita celor 8,5V dintr-un step down nededicat si este posibil sa fi depasit limita. Drept pentru care am cerut garantie fabricantului, dar oamenii nu au fost de acord decat daca il trimit inapoi la ei. Doar nu era sa arunc 84$, asa ca am dat 25$ postei romane pentru transport. Dupa ce mi-a fost returnat, nu l-am mai folosit, pentru imi luasem deja un Hitec. In concluzie, servo-ul este practic nou. Pret 350 lei, transport inclus.
Specification:
Torque At 6.0V: 44.7 kg-cm / 620.8 oz-in
Torque At 7.4V: 53.1 kg-cm / 737.6 oz-in
Torque At 8.4V: 57.5 kg-cm / 798.7 oz-in
Speed At 6.0V: 0.12 sec / 60°
Speed At 7.4V: 0.10 sec / 60°
Speed At 8.4V: 0.09 sec / 60°
Operating Voltage Range: 6.0V ~ 8.5V ( 5 ~ 6 Cell Ni-MH or 2S Li-Poly / 2S Li-Fe )
Control System: Digital Controller / AD 12-Bits Resolution ( 4096 Steps )
Dead Bend Width:0.001ms (1us)
Ball Bearing: 6 pcs Stainless Steel
Gears Type: All Steel Alloy Metal Helical Gears
Motor Type: High Efficiency Japan Brushless Motor
Horn / Gear Spline: 25 Teeth (Same as Futaba)
Dimension (mm): 40.5 x 21 x 38.5 mm / 1.59 x 0.83 x 1.52 inch
Weight (gram): 83.0 ± 1 grams / 2.93 oz
Axial Yeti XL
Losi LST XXL
Imagine postata
#2 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 10 June 2020 - 07:48 AM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#3 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 25 August 2020 - 09:59 PM
Valabil
Axial Yeti XL
Losi LST XXL
Imagine postata
#4 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 03 October 2020 - 05:54 PM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#5 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 24 October 2020 - 10:32 AM
Sus cu el
Axial Yeti XL
Losi LST XXL
Imagine postata
#6 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 01 December 2020 - 12:08 AM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#7 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 21 March 2021 - 01:58 PM
Up. Eventual schimb cu 2xEDF 70mm @4S (doar cu date exacte despre tractiune/amperaj si relativ noi) si diferenta.
Axial Yeti XL
Losi LST XXL
Imagine postata
#8 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 06 June 2021 - 09:09 PM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#9 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 30 June 2021 - 06:23 PM
Vezi postareaTzicul, la 01 May 2020 - 09:28 PM, a spus:
Specification:
UP
Axial Yeti XL
Losi LST XXL
Imagine postata
#10 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 15 September 2021 - 10:19 PM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#11 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 25 February 2022 - 01:41 PM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#12 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 07 January 2023 - 08:31 AM
Up
Axial Yeti XL
Losi LST XXL
Imagine postata
#13 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 15 April 2023 - 04:54 PM
Up
Specification:
Axial Yeti XL
Losi LST XXL
Imagine postata
#14 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2113
Postat 08 May 2023 - 03:50 PM
UP!
Specification:
Axial Yeti XL
Losi LST XXL
Imagine postata
