Modelism - RHC Forum: Vand LiPo 3S 11.1v 5200mAh - Modelism - RHC Forum
Vand LiPo 3S 11.1v 5200mAh Multistar LiPo 3S 11.1v 5200mAh 10C
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 23 March 2020 - 02:53 PM
Vand LiPo Multistar 3S 5200mAh, sub 10 incarcari ca nou, stare buna fara lovituri, la cutie, acumulator special foarte usor 330g perfect pentru drone long range sau alte aplicatii.
Features:
• Ultra high capacity LiPoly batteries designed specifically for multi-rotor use
• Similar size/weight as batteries of much lower capacity, making these a direct drop-in upgrade for most multi-rotor aircraft
• Provides increased flight times of up to 20% or more when compared to standard LiPoly batteries of the same weight
• Ideal for use with aerial video and FPV multi-rotor aircract
Specs:
Minimum Capacity: 5200mAh
Configuration: 3S1P / 11.1V / 3Cell
Constant Discharge: 10C
Peak Discharge (10sec): 20C
Pack Weight: 331g
Pack Size: 142 x 49 x 22mm
Charge Plug: JST-XH
Discharge Plug: XT60
Pret: 100lei
Tel: 0749 121 132
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 01 April 2020 - 01:29 PM
vandut
Andrei
