Modelism - RHC Forum: Drona 200mm racing FPV - Modelism - RHC Forum
Drona 200mm racing FPV Quad JJPRO P200
#1 Useril este offline   ViorelH
  • Postari: 61
  • Inregistrat: 26-October 15
Postat 21 April 2020 - 02:35 PM
Vand urmatorul Quad zburat de 2 ori, stare f buna , bonus miniOSD, bateria originala este nefolosita.Fisier atasat  20200421_092956.jpg (105.98K)
Number of downloads: 52Fisier atasat  20200421_092956.jpg (105.98K)
Number of downloads: 52Fisier atasat  20200421_093016.jpg (100.35K)
Number of downloads: 80Fisier atasat  20200421_093904.jpg (110.36K)
Specification
General
Brand JJPRO
Model P200
Quantity 1 Piece
Specification
Battery
3S 11.1v 1500mAh 30C
XT60 Plug
Weight:113g
Motor
Brands: Emax
Model: RS2205
KV:2300
MAX Thrust:1024G
Length: 31.7MM
NO.OF Cell:3-4S
Diameter: 27.9MM
Framework: 12N14P
Shaft:M5
Propeller:5-6 inch
Weight: 30G
ESC
Brand:Emax
Model: Lightning 20A
Continuous Current:20A
Instantaneous Current(10S):30A
BEC: No
Input Voltage: 3-4S
MCU: F396
Weight: 5.5G
Size(without plug): 24.5x12.5x5mm
Power Output: 50Ohm
RF Impedance: 27-28dBm
Operating Voltage: 7V-24V
Audio carrier: 6.5MHz
Camera
Resolution: 800TVL
Operating Voltage: 7-12V
Image Sensor: 1/3 CMOS
Power consumption: 30mA 12
Lens: 2.2mm
Min.illumination: 0.1Lux/F1.2
Electronic Shutter Speed: 1/50(1/60)~1/100000 sec
Angle: 120°diagonal FOV, 80°horizontal FOV
Signal System: NTSC/PAL(default PAL)
Video Output:1.2Vp-p
External Signal Control Black & White Shift: Support
Filter Switch Drive: Support
Flight controller Emax Skyline32 Acro
Product Specifications: 35x35x5mm
Weight: 4.5g
Dimensions & Weight (Main Product)
Dimension Wheelbase: 200mm
Weight: 134g
Main board: 3.5mm
Take off Weight: 351g
Weight(with box) 1.8KG
Package Contents
1 x JJPRO P200 Frame Kit
1 x Skyline32 Acro Flight Controller
4 x RS2205 2300kv Motor
4 x Lightning 20A ESC
1 x 3S 11.1V 1300mAh 30C Battery
1 x 800TVL Camera
7 x 5045 Propeller
4 x Red Motor Base
1 x Power Connector
1 x Camera Mount
1 x Bracket for Gopro
1 x Antenna
1 x Charger
1 x Manual
Pret 750 lei, tel 0724595441, doar mesaje whatsapp sau SMS va rog!
