Modelism - RHC Forum: Vand camera FPV cu inregistrare Runcam Split - Modelism - RHC Forum
Vand camera FPV cu inregistrare Runcam Split Runcam Split FPV 1080p 60fps HD WiFi
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 05 July 2019 - 10:14 AM
Vand Runcam Split V1, functioneaza fara probleme, are corp metalic, modul Wifi, cu lentila M12mm clara, cabluri, acesorii, manual, la cutie; perfecta pentru drone 3-5inch usoare sau avioane, FPV si inregistrare HD integrata, vine cu ultimul soft care ofera multe setari la imagine. Suporta control PWM sau port UART din Betaflight, iesire audio+video(PAL/NTSC), FOV reglabil, nu pierde inregistrarea la oprire.
Parameters:
FOV Angle of Field- FPV FOV 130° / Recording FOV 165°(Adjustable)
Video Resolution- 1080@60fps / 1080@30fps / 720@60fps
Video Files- MOV
Image Resolution- 2 Megapixels
TV Output- NTSC (720*480) / PAL (720*576) Switchable
Real-Time Audio Output- Yes
Interface- Micro USB / UART
Max Micro SD Card Supported- 64G(need Class 6 or above, recommend Class 10/UHS-I/UHS-II)
WiFi Module- Support (Removable)
Mount- PCB 30x30mm / Lens Module 19mm
Power Input- DC 5V
Working Current- 650mA @5V
Weight- 21g
Pret: 200lei
Tel: 0749 121 132
Andrei
