Vand incarcatorul din poza. Este utilizat dar functioneaza si arata perfect.
Specs: https://www.banggood...ur_warehouse=CN
Ultra Power UP100AC Touch charger can be used worldwide with its auto switching power supply, compatible with 100 - 240V. It can also be powered by DC power, allowing it to be used out in the field when a wall outlet is not available. It has a high 100W max output! The charger can also be used as a power supply to power other devices, up to 120W from the DC port! It's a multi-chemistry charger so it can properly charge Li-Po, Li-Hv, Li-Ion, Li-Fe, NiMH, Ni-Cd and Pb ( lead acid ) batteries. It has a built in balancer for Lithium type batteries. It includes temperature sensor port and PC link port. As an added bonus, the charger has a 5V 2.1A USB port built-into it to power and recharge your cell phone, tablet, etc.
Description:
Brand Name: Ultra Power
Item Name: UP100AC Touch Balance Charger
Input voltage: AC 100~240V,DC 11.0-18.0V
Discharge power: Max.10W
Charge current: 0.1-10.0A
Discharge current: 0.1-5.0A
LiIo/LiPo/LiFe/LiHv cell count:1~6 series
NiCd/NiMH battery cell count: 1 - 15cells
Pb battery voltage: 2V~20V (1-10cells)
Weight:0.75KG
Dimension: 135x95x61mm
Features:
Convenience:
The charger is quite compact with only 135 x 95 x 61mm, 0.44kg. So it can be stored in your pit bag or box quite easily! The charger also features Li-Po balance charge, Li-Po fast charge, Li-Po storage, and Li-Po discharge modes.
Power Supply:
The charger can be used to power other DC devices such as chargers, lathes, lights, etc. It puts out a whopping 120W of power! Simply plug the charger into the wall and use the DC port on the right side of the charger to power your device.
Reliability:
Ultra Power is known for their great reliability, we use the best internal components and circuitry available to create a long lasting products.
Lithium Battery Meter:
Check the voltage of a lithium battery's cells when plugged into the balance port. The screen will provide a read out of each cell's voltage, the total pack voltage, as well as the highest and lowest cells.
Battery Memory:
You can program and store up to 10 different types of battery settings. Then simply load the program to start charging using your stored battery settings.
Package included:
1x Ultra Power UP100AC Touch Charger
Pret: 200 lei.
Tel: 0744694027, sms, whatsapp sau pm.
https://i.postimg.cc/Xrq3rqNq/charger.jpg
Incarcator LiPo Ultra Power UP100AC AC DC Touch 100W 200 lei
