Modelism - RHC Forum: Vand motoare Emax RS2306 si RS1106 - Modelism - RHC Forum
Vand motoare Emax RS2306 si RS1106 Emax RS2306 2400KV 4S 5', Emax RS1106 6000KV 2-3S 2-3'
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 16 January 2019 - 05:26 PM
Vand 5buc(4+unul nou) motoare Emax RS2306 2400KV Black Edition, putin folosite, in stare foarte buna, fara lovituri sau probleme la rulmenti, motoare puternice si rezistente, la cutie =>320lei(5buc)
Description:
The RS2306 was designed to set a new standard of power and response for pilots seeking the ultimate in flight performance. With nearly twice the level of thrust of the original Red Bottom, the new RS2306 sets the bar even higher by pushing 2kg of thrust with 5045x3 propeller on 5S or 6045x3 on 4S.
Latest design language used in RS2205-S have been carried over to the RS2306.
Lighter bell, hollowed steel shaft, bigger bearings, lower profile, and kept the overall diameter just 0.4mm wider than RS2205-S!
Specs:
Brand name: Emax
Item name: RS2306 2400KV motor
Color: Black
KV: 2400
Framework: 12N14P
No. of cells: 3-4S
Propeller: 5 inch
Diameter: 28.3MM
Length: 30.1MM
Prop adapter shaft thread: M5
Max.thrust: 1552g
Weight: 33.84g
=>Vand 5buc(4+unul nou) motoare Emax RS1106 6000KV, perfecte pentru quad mici de 2-3inch pe 2-3S, putin folosite, in stare buna, fara lovituri sau probleme, motoare puternice si rezistente, am si elici de 2inch la nevoie, la cutie =>200lei(5buc)
Specification:
Brand name: EMAX
Item model: RS1106
KV: 6000KV 2-3S
Framework: 9N12P
Weight: 7g
Max.thrust: 265g
Propeller: 2''-3''
Features:
-Most powerful micro motors for 2'' to 3'' propellers
-RS exclusive ''Cooling'' design on a micro sized motor
-Prop bolt pattern for Emax 2345 M2 x 9mm and M2 x 5mm Propellers
-High Quality NSK bearings for long lasting smoothness
-Strong N52SH Magnets
-Factory Balanced Precision CNC Motor Bells
Tel: 0749 121 132
Aceasta postare a fost editata de andrewbt: 16 January 2019 - 05:27 PM
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 28 January 2019 - 10:35 AM
UP, transport curier inclus.
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 05 February 2019 - 11:06 AM
->Vand 5buc(4+unul nou) motoare Emax RS2306 2400KV, putin folosite, in stare foarte buna, fara lovituri sau probleme la rulmenti, motoare puternice si rezistente, la cutie =>300lei(5buc)
->Vand 5buc(4+unul nou) motoare Emax RS1106 6000KV, perfecte pentru quad mici de 2-3inch pe 2-3S, putin folosite, in stare foarte buna, fara lovituri sau probleme, motoare puternice si rezistente, la cutie =>200lei(5buc)
->Vand 4buc motoare Emax RS2205 2300KV, putin folosite, in stare foarte buna, fara lovituri sau probleme la rulmenti, motoare puternice si rezistente =>150lei(4buc)
Andrei
#4 Useril este offline   andrewbt
  • Postari: 1014
Postat 12 February 2019 - 08:57 AM
->Vand 5buc(4+unul nou) motoare Emax RS2306 2400KV, putin folosite, in stare foarte buna, fara lovituri sau probleme la rulmenti, motoare puternice si rezistente, la cutie =>260lei(5buc)
->Vand 5buc(4+unul nou) motoare Emax RS1106 6000KV, perfecte pentru quad mici de 2-3inch pe 2-3S, putin folosite, in stare foarte buna, fara lovituri sau probleme, motoare puternice si rezistente, la cutie =>180lei(5buc)
Aceasta postare a fost editata de andrewbt: 12 February 2019 - 08:58 AM
Andrei
#5 Useril este offline   andrewbt
  • Postari: 1014
Postat 19 February 2019 - 09:16 AM
UP
Andrei
#6 Useril este offline   andrewbt
  • Postari: 1014
Postat 26 February 2019 - 03:48 PM
->Vand 5buc(4+unul nou) motoare Emax RS2306 2400KV, putin folosite, in stare foarte buna, fara lovituri sau probleme la rulmenti, motoare puternice si rezistente, la cutie =>55lei/buc
->Vand 5buc(4+unul nou) motoare Emax RS1106 6000KV, perfecte pentru quad mici de 2-3inch pe 2-3S, putin folosite, in stare foarte buna, fara lovituri sau probleme, motoare puternice si rezistente, la cutie =>40lei/buc
->Vand 4buc motoare Emax RS2205 2300KV, putin folosite, in stare foarte buna, fara lovituri sau probleme la rulmenti, motoare puternice si rezistente =>35lei/buc
Andrei
#7 Useril este offline   andrewbt
  • Postari: 1014
Postat 11 March 2019 - 09:55 AM
up
Andrei
#8 Useril este offline   andrewbt
  • Postari: 1014
Postat 18 March 2019 - 11:13 AM
up
Andrei
#9 Useril este offline   andrewbt
  • Postari: 1014
Postat 26 March 2019 - 10:27 AM
up
Andrei
#10 Useril este offline   andrewbt
  • Postari: 1014
Postat 03 April 2019 - 01:57 PM
->Vand 5buc(4+unul nou) motoare Emax RS1106 6000KV, perfecte pentru quad mici de 2-3inch pe 2-3S, in stare foarte buna, fara lovituri sau probleme, motoare puternice si rezistente =>36lei/buc
Andrei
#11 Useril este offline   andrewbt
  • Postari: 1014
Postat 15 April 2019 - 12:44 PM
up
Andrei
