Modelism - RHC Forum: Incarcatoare baterii LIPO LIFE LIHV LION NIMH NICD PB - Modelism - RHC Forum
#1 Useril este offline   HUHA
  • Postari: 16
  • Inregistrat: 19-December 08
  • Interests:Airsoft
Postat 10 October 2018 - 09:36 PM
Salut
Vand mai multe modele de incarcatoare pentru acumulatori :
Incarcator iSDT T6 Lite 25Amperi 600W LIPO LION PB LIFE la 400 lei
Features:
• Easy controls allow for fast programming
• Cooling system using high-speed ball bearing fans
• Complete OT, OC, OV, OL and reverse polarity protection
• Anti-spark function
• Fully supports BattGo, the latest in smart battery
Specs:
Input: DC8-32V/0-30A
Output Voltage: 0-30V
Charge Current: 0.1-25.0A
Discharge Current: 0.1-5.0A
Max Charge Capacity: 600W
Max Discharge Capacity: 20W
Balancing Current: 1.5A/cell
Balance Cells: 2-6S
Supported Batt. Types: LiFe/Lilon/LiPo/LiHv 1-6S, NiMH/Cd1-21S, Pb 3-12S
USB: 5V/2.1A
Display: 2.4" 320x240 IPS LCD
Operating Temperature: 0-40°C
Storage Temperature: -20-60°C
Dimensions: 100x120x58mm
Weight: 305g
Languages: English, German, French, Spanish, Japanese, Traditional Chinese, Simplified Chinese
Incarcator Imax B6AC V2 Original 220V LIPO LIFE LION LIHV la 230 lei
Specificatii tehnice :
• PC connectivity
• Microprocessor controlled
• Delta-peak sensitivity
• Individual cell balancing
• Li-ion, LiPo and LiFe capable
• Ni-Cd and NiMH capable
• Large range of charge currents and automatic charge current limit
• Store function allows safe storage current
• Time limit function
• Input voltage monitoring (Protects car batteries at the field)
• Data storage (5 pack memory)
• Battery break in and cycling.
• Terminal voltage adjustment for heavy duty batteries
Specs:
AC Input Voltage: 100 ~ 240v or 12V DC input
Max Charge: 50W
Max Discharge 5W
Charge Current Range: 0.1 ~ 6.0A
Discharge Current Range: 0.1 ~ 1.0A
Ni-MH / NiCd Cells: 1 ~ 15
Li-ion / LiPoly Cells: 1 ~ 6
Pb Battery Voltage: 2 ~ 20v
Weight: 632g
Dimensions: 135 x 144 x 36mm
Package Includes:
1 x IMAX B6AC V2 Charger
1 x DC Jack plug to crocodile clips
1 x male T connector charge lead to 4mm banana plugs
1 x XT60 charge lead
1 x JST charge lead
1 x Crocodile clip charge lead
1 x Futaba style charge lead
1 x Mains power lead (EU type)
Incarcator LIPO Turnigy UP610 200W 10A LIFE LION LIHV PB NIMH la 210 lei
Features:
• Advanced synchronous DC power conversion technology
• High efficiency rating (90%)
• Wheel Scroll Button
• 2.4" 320x240 IPS LCD color screen
• Update Software via USB to computer
Specs:
Input Voltage: DC 9-32V
Charging Current: 0.1-10.0A
Discharge Current: 0.1-3.0A
Max Charge Power: 200W
Max Discharge Power: 8W
Balance Current: 500mA/cell
Balance Cells: 2~6S
Support Battery Types: Life/Lilon/LiPo/LiHv (1-6S); NiMH/Cd (1-16S); Pb (1-125)
Display Type: 2.4 "320x240 IPS LCD
Use Temperature: 0-40°C
Dimensions: 87x57x41mm
Weight: 110g
Incarcator Turnigy Accucel-6 80W 10A CHARGER LiHV/LIFE/LIPO/NICD/NIMH la 180 lei
Features:
• LiHV, Li-ion, LiPoly and LiFe capable
• Delta-peak sensitivity (NiMH/NiCd)
• Lead Acid capable
• Terminal Voltage Control (TVC)
• Lipo Battery Meter
• Battery Internal Resistance Meter
• Store function, allows safe storage current
• Temerature Cut-off (20-80 degree Celcius/68-176 Fahrenheit)
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 10 packs in memory)
• Battery break in and cycling. (1-5 cycles)
Specs:
Input Voltage: 11~18v
Circuit Power: Max Charge: 80W / Max Discharge: 10W
Charge Current Range: .1~10.0A
Balance Cells: 2-6 cells
NiMH/NiCd Cells: 1~15
LiHVLiIon/LiPoly Cells: 1~6
Pb battery Voltage: 2~20v
Weight: 270g
Incarcator Turnigy Accucel S60 60W 6A 220V LIPO LIFE LION NICD NIMH PB la 170 lei
Specificatii:
Tensiune de intrare: 100~240 V
Circuit de putere: max incarcare: 60W / max descarcare: 10W
gama de curent de incarcare: 0.1 ~ 6.0A
celule Ni-MH/NiCd: 6 ~ 8
celulele Li-ion/Poly/Life/Lihv: 1 ~ 4
tensiunea acumulatorului de plumb (auto): 6 ~ 12 V
greutate: 321g
Display Type: 2x16 LCD Display Backlight Blue
Case Material: Plastic
Controls: Four Buttons
Case Size: 112x100x51mm
PC Communications: USB Port for PC Control & Firmware Upgrade
External Port: 2-4S Balance Socket-XH, Temperature Probe Socket, Battery Socket, Micro USB Port for PC.
Delta Peak Detection for NiMH/NiCd: 3-15mV/cell / Default: 4mV/cell
Battery Cutoff Temperature: 20°C/68°F - 80°C/176°F (adjustable)
Charge Voltage: NiMH/NiCd: Delta peak detection
LiPo: 4.18-4.25V/cell
LiHV:4.25-4.35V/cell
LiFe: 3.58-3.7V/cell
LiIon: 4.08-4.2V/cell
Balance Current: 200mA/cell
Reading Voltage Range: 0.1-26.1V/cell
Battery Types/Cells:
LiPo/LiHV/LiFe/LiIon: 2-4cells
NiMH/NiCd: 6-8cells
Pb: 3-6cells
Battery Capacity Range:
NiMH/NiCd: 100-50000mAh
LiPo/LiHV/LiFe/LiIon: 100-50000mAh
Pb: 100-50000mAh
Charge Current: 0.1A-6.0A
Safety Timer: 1-120minutes off
Charge Wattage: 60W
Discharge Current: 0.1A-2.0A
Discharge Cut-off Voltage:
NiMH/NiCd: 0.1-1.1V/cell
LiPo: 3.0-3.3V/cell LiHV: 3.1-3.4V/Cell
LiFe: 2.6-2.9V/cell LiIon: 2.9—3.2V/cell
Pb: 1.8V/cell
Discharge Wattage: 10W
Balance Cells: 2-4 cells
Memory: 10 different charge/discharge profiles
Charge Method: CC/CV for lithium types and lead (Pb) batteries, Delta-peak Sensitivity for NiMH/NiCd.
Incarcator Turnigy Accucel-6 50W 6A CHARGER LiHV/LIFE/LIPO/NICD/NIMH la 165 lei
Caracteristici:
controlat de microprocesor;
sensibilitate de varf Delta (NiMH / NiCd);
echilibrare pe celule individuale la acumulatori Li-Ion, LiPo, LiFe, Lihv;
compatibil Li-Ion, LiPo, LiFe, Lihv;
compatibil Ni-Cd si NiMH;
gama larga de curenti de incarcare;
Masurarea rezistentei interne a acumulatorului
functie de stocare, permite stocarea în conditii de siguranta a acumulatorului;
functie pentru limita de timp;
monitorizare tensiune de intrare (protejeaza bateriile auto);
stocare a datelor (stocheaza de pâna la 6 pachete de memorie);
Afisare voltaj pentru fiecare celula in parte
Specificatii:
Tensiune de intrare: 11 ~ 18V
Circuit de putere: max incarcare: 50W / max descarcare: 5W
celule Ni-MH/NiCd: 1 ~ 15
celulele Li-ion/Poly/Life/Lihv: 1 ~ 6
tensiunea acumulatorului de plumb (auto): 2 ~ 20V
greutate: 240g
Sursa de alimentare nu este inclusa.
Incarcator IMAX B6 original 50W 5A 1-6 Celule LIPO/LIFE/LION NICD/NIMH la 160 lei
Caracteristici:
compatibil Plumb
gama larga de curenti de incarcare 0.1A ~ 5.0 A
stocare a datelor (stocheaza de pâna la 5 pachete de memorie);
Afisare voltaj pentru fiecare celula LIPO/LIFE/LION in parte in timpul incarcarii.
Specificatii:
gama de curent de incarcare: 0.1 ~ 5.0A
gama de curent de descarcare: 0.1 ~ 1.0A
celulele Li-ion/Poly/Life: 1 ~ 6
greutate: 277gr
Dimensiuni: 133x87x33mm
Incarcator verificator DC-4S 30w acumulatori LIPO 2~4 celule 2S 3S 4S la 65 lei
Sturdy alloy case
LED Display showing overall and individual cell voltage
1000m/A~1500m/A balance charge output
9v~16v (30w) input
Power lead supplied
Compact size ideal for field box
Dimensions: 80mm x 50mm x 21mm
Weight: 71g (without lead)
Suitable for JST-XH balance plugs
Incarcator lipo hobbyking B3AC 2s -3s 220V la 50 lei
Features:
• Smart charging protection
• 2S & 3S Compatible
• Charges through the balance lead
• Easy to use, safe and reliable
• Includes power lead with Croc Clips
Specs:
Input Voltage: 220V
Output Voltage: 8.4~12.6V DC
Output Current: 800mA (Max)
Dimensions: 95x55x32mm
Charging plug: JST-XH
Weight: 95g
Multumesc
#2 Useril este offline   HUHA
  • Postari: 16
  • Interests:Airsoft
Postat 12 November 2018 - 08:16 PM
valabil
