Modelism - RHC Forum: Acumulatori LIPO 2S 3S 4S - Modelism - RHC Forum
Acumulatori LIPO 2S 3S 4S diferite capacitati si voltaj
#1 Useril este offline   HUHA
  • Postari: 14
  • Inregistrat: 19-December 08
  • Interests:Airsoft
Postat 10 October 2018 - 09:12 PM
Salut.
Vand mai multe modele de acumulatori LIPO 2s 3s 4s :
2S / 7.4 Volti
Acumulator LIPO ZIPPY 8000mAh 2S1P 30C 7.4v la pretul de 175 lei
Spec.
Capacity: 8000mAh
Voltage: 2S1P / 2 Cell / 7.2v
Discharge: 30C Constant / 40C Burst
Weight: 415g (including wire, plug & case)
Dimensions: 170x67x17mm
Balance Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector
Baterie LIPO ZIPPY 6000mah 2S 7.4v 35C Hardcase in carcasa de plastic la 150 lei
Spec:
Capacity: 6000mAh
Voltage: 2S2P / 2Cell / 7.4v
Discharge: 35C Constant/45C Burst
Charge Rate: 1C
Weight: 317g (including wire, plug & case)
Dimensions: 138x46x25mm
Discharge Plug: 4mm Bullet Connector
Baterie lipo ZIPPY Compact 5000mAh 2S 25C la 120 lei
Spec.
Capacity: 5000mAh
Voltage: 2S1P / 2 Cell / 7.4V
Discharge: 25C Constant / 35C Burst
Weight: 241g (including wire, plug & case)
Dimensions: 154x17x45mm
Discharge Plug: HXT4mm
Baterie LIPO ZIPPY Compact 4000mAh 2S 7.4v 25C la 95 lei
Spec.
Capacity: 4000mAh
Weight: 200g (including wire, plug & case)
Dimensions: 145x15x44mm
Acumulatori baterie LIPO ZIPPY Flightmax 2200mAh 2S1P 7.4V 20C la 60 lei
Capacitate 2200 mAh
Voltaj 2S1P / 2 Celule / 7.4v
Rata de descarcare 20C Constant / 25-30C Varf
Greutate 133 gr
Dimensiuni 104x34x17mm
Mufa de incarcare/balans JST-XH
Mufa de descarcare/ conectare la consumator XT60
Acumulator baterie LIPO 7,4v 2s 1800 mah Airsoft nano-tech la 60 lei
Turnigy nano-tech 1800mah 2S 20~40C Lipo AIRSOFT
Capacity: 1800mAh
Voltage: 2S1P / 2S Cell / 7.4V
Discharge: 20C Constant / 40C Burst
Weight: 100g (including wire, plug & case)
Dimensions: 103x9x34mm
Discharge Plug: Mini-Tamiya (Mini Molex)
Turnigy nano-tech 300mah 2S 35~70C Lipo Pack 7.4 Volti la 40 lei
Spec.
Capacity: 300mAh
Discharge: 35C Constant / 70C Burst
Weight: 17g (including plug & case)
Dimensions: 44 x 12 x 17mm
Discharge Plug: JST
Mai am si alte modele 2S care le puteti gasii la aceasta adresa
Linkul meu pe OLX
3S / 11.1 Volti
Acumulator ZIPPY Flightmax 8000mAh 3S 30C Lipo 11.1 volti la 250 lei
Spec.
Capacity: 8000mAh
Voltage: 3S1P / 3 Cell / 11.1v
Weight: 644g (including wire, plug & case)
Dimensions: 169x69x27mm
Discharge plug: XT90
Acumulator LIPO 4000mAh 3S 12C 11.1v la 120 lei
Spec.
Minimum Capacity: 4000mAh
Configuration: 3S2P / 11.1V / 3Cell
Constant Discharge: 12C
Peak Discharge (10sec): 24C
Pack Weight: 281g
Pack Size: 108 x 39 x 35mm
Charge Plug: JST-XH
Discharge Plug: XT60
Linkul meuBaterie Turnigy 3000mAh 3S 20C Lipo 11.1 Volti la 100 lei
Spec.
Minimum Capacity: 3000mAh
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 253g
Pack Size: 147x 46x 18
Charge Plug: JST-XH
Discharge Plug: HXT-4mm
Acumulator Baterie Turnigy 2650mAh 3S 20C Lipo Pack la 90 lei
Spec.
Minimum Capacity: 2650mAh
Pack Weight: 180g
Pack Size: 136 x 43 x 17mm
Charge Plug: JST-XH
Discharge Plug: Female XT60
Baterie LIPO Turnigy 2200mAh 3S 11.1v 25C la 65 lei
Spec.
Minimum Capacity: 2200mAh
Constant Discharge: 25C
Peak Discharge (10sec): 35C
Pack Weight: 188g
Pack Size: 105 x 33 x 24mm
Charge Plug: JST-XH
Discharge plug: XT60
Acumulator Turnigy nano-tech 1800mah 3S 20~40C Lipo AIRSOFT Pack 11.1 la 70 lei
Spec.
Capacity: 1800mAh
Voltage: 3S1P / 3S Cell / 11.1V
Weight: 148g (including wire, plug & case)
Dimensions: 105x20x35mm
Turnigy nano-tech 1500mAh 3S 20-40C Lipo AIRSOFT Pack 11.1 volti la 70 lei
Spec.
Capacity: 1500mAh
Weight: 116g (including wire, plug & case)
Dimensions: 98x31x20mm
Mai am si alte modele 3S care le puteti gasii la aceasta adresa
Linkul meu pe OLX
4S / 14.8 Volti
Baterie Lipo ZIPPY Flightmax 8000mAh 4S1P 30C Acumulator 14.8V la 340 lei
Spec.
Capacity: 8000mAh
Voltage: 4S1P / 4 Cell / 14.8v
Weight: 740g (including wire, plug & case)
Dimensions: 168x69x32mm
Balance Plug: JST-XHP
Acumulator LIPO Turnigy 5000mAh 4S 25C 14.8V la 200 lei
Spec.
Minimum Capacity: 5000mAh
Configuration: 4S1P / 14.8v / 4Cell
Pack Weight: 490g
Pack Size: 143 x 50 x 33mm
Charge Plug: JST-XH
Discharge plug: XT-90
Acumulator LIPO 4s 14.8V 5200mah 10C la 180 lei
Specs:
Minimum Capacity: 5200mAh
Configuration: 4S1P / 14.8V / 4Cell
Constant Discharge: 10C
Peak Discharge (10sec): 20C
Pack Weight: 433g
Pack Size: 142 x 49 x 29mm
Charge Plug: JST-XH
Acumulator LIPO ZIPPY 4000mAh 4S1P 20C la 155 lei
Spec.
Capacity: 4000mAh
Discharge: 20C Constant / 30C Burst
Weight: 397g (including wire, plug & shrink wrap)
Dimensions: 146x51x27mm
Discharge Plug: 4mm Bullet-Connector
Acumulator lipo Turnigy 3000mAh 4S 20C 14.8V la 120 lei
Spec.
Pack Weight: 278 gr
Pack Size: 136x 44 x 24mm
Charge Plug: JST-XH
Discharge Plug: XT-60
Transportul prin urgent/cargus 18.83 ron sau fan curier 25 ron.
Preturile sunt pentru colete pana intr-un kilogram cu ramburs si destinatarul daca nu este in aria de acoperire a curierului , creste pretul transportului prin curier.
Prin curier se poate cere si verificare colet la livrare.
Multumesc
