Modelism - RHC Forum: Vand motoare Emax RS1306 4000KV 3' - Modelism - RHC Forum
Vand motoare Emax RS1306 4000KV 3' Emax RS1306 4000KV Race Spec Motor CW/CCW
#1 Useril este offline   andrewbt
  • Postari: 882
Postat 10 August 2018 - 09:56 AM
Vand 5 motoare Emax RS1306 4000KV(2CW +3CCW), perfecte pentru drone mici de 3' care incep sa fie la moda si sub 250g (doar 12.7g/motor), 4buc in stare buna si unul nou, vin cu surube si piulite, am si elici sau ESC pentru ele.
Features:
• Up to 177 watts of power with 3" prop and 4s battery
• Cooling design reduces motor temperature by up to 30%
• Highest grade N52 neodymium magnets
• Genuine Japanese NMB bearings
• Dynamically balanced in the factory.
• 12.5mm extended prop shaft allows virtually any prop with 5mm hole.
• High purity copper windings
Specs:
Configuration: 9N12P
Kv: 4000rpm/V
Input voltage: 3S-4S (11.1 - 14.8V)
Motor Height: 15.5mm
Motor Diameter: 18mm
Prop Adapter Shaft Thread: M5
Stator Diameter: 14mm
Shaft Diameter: 2mm
Weight: Approx. 12.7g
Motor Direction: CW/CCW
Pret:200lei
Tel: 0749 121 132
Aceasta postare a fost editata de andrewbt: 10 August 2018 - 10:01 AM
Andrei
#2 Useril este offline   Robin671
  • Postari: 131
  • Inregistrat: 24-March 15
  • Interests:Aeromodele,Electronica,Mecanica,Fotografie...
Postat 10 August 2018 - 08:20 PM
Ai PM..
#3 Useril este offline   andrewbt
  • Postari: 882
Postat 19 August 2018 - 09:42 PM
UP
Andrei
#4 Useril este offline   andrewbt
  • Postari: 882
Postat 24 August 2018 - 02:30 PM
vandut
Andrei
