Modelism - RHC Forum: De vinzare : Aeromodel acrobat electric STAUDACHER de la PROTECH – - Modelism - RHC Forum
De vinzare : Aeromodel acrobat electric STAUDACHER de la PROTECH – Componente pentru aero electrice : motoare brushless , servo analogi
#1 Useril este offline   fokker
  • Postari: 591
  • Inregistrat: 12-June 08
Postat 21 June 2018 - 11:44 AM
Aeromodel acrobat STAUDACHER S300 de la firma PROTECH Belgia constructie clasica deosebita : balsa , placaj , folie ORACOVER - anvergura : 1100 mm ; lungime fuselaj : 930 mm ; Echipat cu 4 servo HK angrenaj metalic / zburat doar de citeva ori pt probe . Necesita motor 120 - 150 W Kw 1000 elice 8” – 9”, ESC 30A + accumulator 2200 mAh 3 celule - pret 350 ron .
Motoare brushless , servo analog , ESC brushless cu bec
1 – servo HK 15178 – 2 buc - nefolosite ( ambalate ) - 20 ron / buc
2– servo Art Tech – 9 gr – 2 buc - nefolosite ( ambalate ) - 15 ron / buc
3 - servo HK 928 BB cu rulment – 2 buc - nefolosite ( la cutie ) - 30 ron / buc
4 - servo ROBE XS4 – 2 buc - folosite - 15 ron / buc
5 – servo TURNIGY SG 9 - 1 buc nefolosit - 25 ron /buc
6 - ESC HK 30 A bec - 1 buc nefolosit ( ambalat ) - 45 ron
7 - ESC HK 20 A bec - 1 buc nefolosit ( ambalat ) - 40 ron
8 – servo Tower pro – 8gr - 1 buc folosit 15 ron
9 – servo Hitec HS 55 - 1 buc nefolosit ( la cutie ) 40 ron
10 – motor Tower pro 2410 – 08 - 1 buc folosit - 25 ron
11 – motor TURNIGY SK 2822 - 1200 kw - 1 buc nefolosit ( la cutie ) - 40 ron
12 – motor Emax POWER - CF 2822 - elice 9” – 10” - 1 buc nefolosit - 40 ron
Acumulatori incarcati cam de 10 ori pentru probe si pastrati la tensiune de stocare :
13 – Nano tech - 850 mAh ; 3 celule - 25-50 rata descarcare - 1 buc - 30 lei
14 – Nano tech - 950 mAh ; 2 celule - 25-50 rata descarcare - 2 buc - 25 lei / buc
15 – Nano tech 2200 mAh ; 2 celule - 35 – 70 rata descarcare ( merge si la airsoft ) - 40 lei
16 – Nano tech 1600 mAh ; 3 celule - 25-50 rata descarcare - 45 lei
17 – Ray Pelikan 1100 mAh ; 3 celule 25 rata de descarcare - 35 lei
Trimit si prin Posta romana ; Rog comenzi peste 50 ron .
#2 Useril este offline   RA3OR
  • Postari: 51
  • Inregistrat: 12-June 04
  • Interests:Aerobatics
Postat 21 June 2018 - 01:07 PM
ai mesaj privat
Structure: Edge540 v3 'Hamilton', Ju87B2 Stuka, Laser 73', Extra 260(x2), Calmato Alpha, 3D-Red, 3D-Orange, SigRascal, Ugly Stick
Foam: FT-Bushwacker, FT-3D, Scout MX-2, ParkMaster Pro, Swift 3D, Miss BJ Electric, Bixler-2, SuperKinetic, FT-MightyMiniArrow, HK Yak-52
#3 Useril este offline   stelu82
  • Postari: 1038
  • Inregistrat: 06-January 12
Postat 21 June 2018 - 07:21 PM
salut hai si cu un nr de tel
#4 Useril este offline   stelu82
  • Postari: 1038
Postat 25 June 2018 - 01:29 PM
aveti P.M.
#5 Useril este offline   fokker
  • Postari: 591
Postat 03 July 2018 - 08:52 AM
Up
Modelul scade la 330 ron
#6 Useril este offline   fokker
  • Postari: 591
Postat 11 July 2018 - 01:53 PM
Up
Modelul 330 ron
Componente au mai ramas urmatoarele cu multe reduceri :
2– servo Art Tech – 9 gr – 2 buc - nefolosite ( ambalate ) - reduse de la 30 la 25 ron amindoua
3 - servo HK 928 BB cu rulment – 2 buc - nefolosite ( la cutie ) - 30 ron / buc / 50 daca se cumpara amindoua
4 - servo ROBE XS4 – 2 buc - folosite - reduse de la 30 la 25 ron amindoua
5 – servo TURNIGY SG 9 - 1 buc nefolosit - redus de la 25 la 20 ron
9 – servo Hitec HS 55 - 1 buc nefolosit ( la cutie ) redus dela 40 la 35 ron
10 – motor Tower pro 2410 – 08 - 1 buc folosit - / redus dela 25 la 20 ron
11 – motor TURNIGY SK 2822 - 1200 kw - 1 buc nefolosit ( la cutie ) - redus de la 40 la 35 ron
12 – motor Emax POWER - CF 2822 - elice 9” – 10” - 1 buc nefolosit - redus de la 40 la 35 ron
Acumulator
16 – Nano tech 1600 mAh ; 3 celule - 25-50 rata descarcare - redus de la 45 la 40 ron
Restul sa au dat .
#7 Useril este offline   fokker
  • Postari: 591
Postat 19 July 2018 - 02:52 PM
UP
Modelul 320 ron
Celelalte component cu reducere
2– servo Art Tech – 9 gr – 1 buc - nefolosite ( ambalate ) - reduse 10 ron
6 - ESC HK 30 A bec - 1 buc nefolosit ( ambalat ) - 45 ron redus la 40 ron
7 - ESC HK 20 A bec - 1 buc nefolosit ( ambalat ) - 40 ron redus la 35 ron
10 – motor Tower pro 2410 – 08 - 1 buc folosit - / redus dela 25 la 20 ron --- VINDUT
se adauga - servo 12 g angrenaje metalice "made TAIWAN " - 40 ron
#8 Useril este offline   fokker
  • Postari: 591
Postat 28 July 2018 - 09:54 AM
UP
Au mai ramas
2– servo Art Tech – 9 gr – 1 buc - nefolosit( ambalat ) - redus 10 ron
4 - servo ROBE XS4 – 2 buc - folosite - reduse de la 30 la 25 ron amindoua - rezervat
9 – servo Hitec HS 55 - 1 buc nefolosit ( la cutie ) redus dela 40 la 35 ron - rezervat
se adauga - servo 12 g angrenaje metalice "made in TAIWAN " - 40 ron
- 2 x accumulator Li po - RHINO - 610 mAh rata de descarcare 20C - 50 ron amindoi
#9 Useril este offline   fokker
  • Postari: 591
Postat 06 August 2018 - 12:09 PM
UP
Modelul 310 ron
Au mai ramas
#10 Useril este offline   fokker
  • Postari: 591
Postat 23 August 2018 - 07:34 PM
UP
#11 Useril este offline   fokker
  • Postari: 591
Postat 07 September 2018 - 11:16 AM
UP
Modelul se reduce la 300 lei .
#12 Useril este offline   fokker
  • Postari: 591
Postat 30 September 2018 - 07:06 PM
UP
#13 Useril este offline   fokker
  • Postari: 591
Postat 13 October 2018 - 06:16 PM
UP
