Modelism - RHC Forum: Calculatoare - Modelism - RHC Forum
Calculatoare
#1 Useril este offline   mishu_g
  • Postari: 535
  • Inregistrat: 22-November 06
Postat 13 February 2018 - 06:22 PM
1. Calculator ideal pentru aplicatii gen mediacenter, NAS, gateway etc.
Carcasa este din aluminiu cu sistem de racire pasiv total silentioasa.
Aspect interior impecabil, exteriorul are cateva zgarieturi fine cum se vede si in fotografia cu partea de sus.
Unitatea optica este fara tray.
Placa de baza miniITX
Sursa externa de 19V
Procesor Core 2 Duo P8700
4 GB RAM
HDD 320 GB
Conector intern LVDS
Caracteristici placa de baza:
Model KTGM45
Processor Intel® Core™2 Quad mobile & Intel® Core™2 Duo mobile support incl. T9400
Chipset Intel® GM45 + ICH9M-E Embedded Chipset
Front Side Bus 667/800/1067 MHz
Bus 5x PCI (KTGM45/ATXE), 2x PCI (KTGM45/Flex), 1x PCI (KTGM45/mITX)
1x PCI-Express 16x/SDVO for external graphics card or ADD2 cards
1x PCI-Express 4x in 16x slot (KTGM45/ATXE & KTGM45/Flex)
DRAM 2x DIMM-240 for up to 8 GB DDR3
Graphics Intel® GMA 4500 MHD graphics
On board CRT, on board Dual Channel LVDS, PCI-Express x 16/SDVO, SVideo(TV) (optional)
Resolution Up to: CRT 2048x1536, LVDS 1920x1080
Graphic Interfaces CRT output and SDVO digital output for DVI, LVDS & HDMI
HDD 4x SATA150/SATA300 w. RAID 0/1 support 1x ATA100 (2.54 mm connector)
Compact Flash Compact Flash Type I + II (only Mini-ITX version)
IEEE1394 2x IEEE1394 (1x Internal and 1x External) (only Mini-ITX version)
Parallel/Serial Port Parallel Port via internal connector, 4x RS232C serial ports with FIFO
USB 12x port USB 2.0 (8x internal and 4x external)
Ethernet 3 x Intel® Gigabit Ethernet, one with Intel® AMT 4.0 support
Keyboard/Mouse Standard PS/2 mouse and keyboard (internal connection available)
Sound 7.1 channel HD audio
Pret: 500 lei + transport Fancurier
  • Imagine atasata: 20180212_222027.jpg
  • Imagine atasata: 20180207_161237.jpg
  • Imagine atasata: 20180207_160605.jpg
#2 Useril este offline   mishu_g
  • Postari: 535
Postat 13 February 2018 - 06:24 PM
2. Calculator I3 4150
8 GB RAM
Placa video NVIDIA GeForce GT 240
Cititor carduri
Nu are hard disk
Carcasa este foarte solida, are cateva zgarieturi
Caracteristici (generate cu Sisoft Sandra)
"< Computer Overview ">
< Computer >
Model: OEM
Serial Number: To Be Filled By O.E.M.
Chassis: Desktop
Mainboard: ASRock H81M-HDS
Serial Number: M80-44031902901
BIOS: AMI (OEM) P1.60 12/06/2013
Intel vPro: 9.00.30.1482
Total Memory: 8GB DIMM DDR3
< Processors >
Processor: Intel® Core™ i3-4150 CPU 3.50GHz (2C
4T 3.5GHz, 3.5GHz IMC, 2x 256kB L2, 3MB L3)
Socket/Slot: FC LGA1150
< Chipset >
Memory Controller: ASRock Core (Haswell) DRAM Controller 100MHz,
2x 4GB DIMM DDR3 1.33GHz 128-bit
< Memory Module(s) >
Memory Module: Crucial CT51264BA160BC16F 4GB DIMM DDR3 PC3-
12800U DDR3-1600 (11-11-11-29 5-40-13-6)
< Video System >
Video Adapter: NVIDIA GeForce GT 240 (64SP SM4.1 1.34GHz,
512MB DDR2 3.4GHz 128-bit, PCIe 2.00 x16)
< Graphics Processor >
Compute Shader Processor: NVIDIA GeForce GT 240 (64SP 1.34GHz, 512MB
DDR2 3.4GHz 128-bit)
< Storage Devices >
Generic USB SD Reader (USB2): N/A (D:)
Generic USB CF Reader (USB2): N/A (F:)
Generic USB xD/SM Reader (USB2:N/A (G:)
Generic USB MS Reader (USB2): N/A (H:)
TSSTcorp CDDVDW SH-S223Q (SATA:N/A (E:)
< Logical Storage Devices >
Removable Drive (D:): N/A Generic USB SD Reader (USB2)
Removable Drive (F:): N/A Generic USB CF Reader (USB2)
Removable Drive (G:): N/A Generic USB xD/SM Reader (USB2)
Removable Drive (H:): N/A Generic USB MS Reader (USB2)
Optical Drive (E:): N/A TSSTcorp CDDVDW SH-S223Q (SATA150, DVD+-
RW, CD-RW)
< Peripherals >
LPC Hub Controller 1: ASRock Lynx Point LPC Controller
Audio Device: ASRock Lynx Point HD Audio Controller
Audio Codec: Realtek Semi Realtek 662 High Definition
Audio
Audio Device: MSI High Definition Audio Controller
Audio Codec: nVidia 000D
Serial Port(s): 1
Parallel Port(s): 1
Disk Controller: ASRock Lynx Point 6-Port SATA AHCI Controller
USB Controller 1: ASRock Lynx Point USB xHCI Host Controller
USB Controller 2: ASRock Lynx Point USB Enhanced Host
Controller #2
USB Controller 3: ASRoc
  • Imagine atasata: 20180213_083526.jpg
  • Imagine atasata: 20180208_154745.jpg
  • Imagine atasata: 20180208_154200.jpg
Aceasta postare a fost editata de mishu_g: 13 February 2018 - 06:27 PM
#3 Useril este offline   mishu_g
  • Postari: 535
Postat 19 February 2018 - 11:13 PM
Pozitia 2 -> vandut !!!
#4 Useril este offline   mishu_g
  • Postari: 535
Postat 22 July 2018 - 05:17 PM
Pozitia 1 vandut
3. HP 8200 Elite SFF
Intel I5 2500
4 GB RAM
Nu au HDD
Disponibile 4 buc
Pret 350 lei + transport Fancurier
  • Imagine atasata: 20180722_173016.jpg
  • Imagine atasata: 20180722_174129.jpg
  • Imagine atasata: 20180722_174241.jpg
  • Imagine atasata: 20180722_174322.jpg
