Modelism - RHC Forum: Tamiya Nitro X - TGM03 RTR 1:8 - Modelism - RHC Forum
Tamiya Nitro X - TGM03 RTR 1:8 TNX 3,0
#1 Useril este offline   Ervin
  • Postari: 311
  • Inregistrat: 06-October 08
Postat 12 January 2018 - 03:37 PM
Video 1
Video 2
Fisier atasat  Forum1.jpg (198.36K)
Fisier atasat  Forum2.jpg (213.27K)
Pret 1350 lei
Extra 260 1.8m electric 6s 5000mAh
QAV X-210 FPV Racer
EasyGlider 4 FPV
#2 Userul este online   Diesel
  • Diesel
  • Postari: 2795
  • Inregistrat: 29-December 05
  • Interests:www.mrtclub.ro
Postat 14 January 2018 - 07:59 PM
O descriere completa si corecta a modelului ar ajuta foarte mult. Citeste si regulamentul forumului... bafta la vanzare! Daca nu va conformati ma vad nevoit sa aplic regulamentul.
Club Sportiv
Motosport Racing Team
#3 Useril este offline   Ervin
  • Postari: 311
Postat 16 January 2018 - 04:10 PM
Description:
100% pure fun!!
Nothing quite compares to the feeling of squeezing the trigger, seeing the chassis drop back onto its rear tires at impact of acceleration, and seeing the entire TNX propel forward with that resonating high-tone engine buzz as she works her way up to her top speed of 60km/h. Having complete control of this baby as she rockets around a circuit or your neighborhood is the ultimate in R/C thrills.
Explosive acceleration, extreme top-speeds and unbeatable running performance all packed into a fully assembled glow engine chassis! The TNX is Tamiya's new and ultimate ready-to-run nitro monster truck. Featuring an awesome power-to-weight ratio the TNX is powered by a high-performance 3.0cc FS-18SR engine developed with the collaboration of O.S. engines. The TGM-03 chassis features a new compact 2-speed transmission designed to ensure consistent shifting and a lightweight double wishbone suspension employing a total of 8 oil dampers for sharp handling and excellent stability. The TNX will out accelerate, out corner and out run just about any truck in its class.
Ultra tough chassis
The TNX features an ultra tough chassis featuring a duraluminum power train deck, a reinforced resin frame, shaft driven 4WD drive train and heavy-duty double wishbone suspension, all the elements necessary for a long lasting durable chassis ready to take-on all types of terrain.
The total weight is dramatically reduced to put the TNX in the same weight category as most 1/10 monster trucks without sacrificing durability. Lightweight suspension components reduce unsprung weight for sharp handling and stability.
The TNX features a new forward only transmission with a pin-type 2-speed for solid and consistent shifting. Ultra strong hardened steel drive shafts and joint cups deliver power to the differentials.
High-powered FS-18SR Engine
Developed in collaboration with O.S. Engines, the R/C engine specialists, the TNX is fitted with a finely tuned high-performance FS-18SR engine loaded with the highest quality glow-engine parts, guaranteeing consistent performance at the highest level. The highly efficient TGM-03 chassis 2-speed transmission ensures all that power is efficiently transferred to speed and running performance.
QAV X-210 FPV Racer
EasyGlider 4 FPV
#4 Useril este offline   Ervin
  • Postari: 311
Postat 16 January 2018 - 04:26 PM
Se vinde cu telecomnda originala, dau un pinion spur de rezerva si aprox 2L de nitro, demarorul are celule de Li-Fe A123, toate piesele sunt originale. Nu pare sa aiba uzura motorul, are compresie buna si merge bine.
Aceasta postare a fost editata de Ervin: 16 January 2018 - 04:30 PM
QAV X-210 FPV Racer
EasyGlider 4 FPV
#5 Useril este offline   Ervin
  • Postari: 311
Postat 27 January 2018 - 09:42 AM
up
QAV X-210 FPV Racer
EasyGlider 4 FPV
#6 Useril este offline   Ervin
  • Postari: 311
Postat 24 March 2018 - 01:15 AM
1200 lei
QAV X-210 FPV Racer
EasyGlider 4 FPV
#7 Useril este offline   Ervin
  • Postari: 311
Postat 23 May 2018 - 10:12 PM
up
QAV X-210 FPV Racer
EasyGlider 4 FPV
