Modelism - RHC Forum: Incarcator Turnigy Accucel-6 80W 10A Balancer/Charger LiHV - Modelism - RHC Forum
#1 Useril este offline   nomad
  • Postari: 651
  • Inregistrat: 24-April 10
Postat 27 November 2017 - 09:30 PM
Se vinde incarcator Turnigy Accucel-6 80W 10A folosit de cateva ori, in stare buna de functionare,cat si estetica.
Caracteristici tehnice:
• Microprocessor controlled
• Individual cell balancing
• LiHV, Li-ion, LiPoly and LiFe capable
• Ni-Cd and NiMH capable
• Delta-peak sensitivity (NiMH/NiCd)
• Lead Acid capable
• Large range of charge currents
• Terminal Voltage Control (TVC)
• Lipo Battery Meter
• Battery Internal Resistance Meter
• Store function, allows safe storage current
• Time limit function
• Temerature Cut-off (20-80 degree Celcius/68-176 Fahrenheit)
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 10 packs in memory)
• Battery break in and cycling. (1-5 cycles)
Specs:
Input Voltage: 11~18v
Circuit Power: Max Charge: 80W / Max Discharge: 10W
Charge Current Range: .1~10.0A
Balance Cells: 2-6 cells
NiMH/NiCd Cells: 1~15
LiHVLiIon/LiPoly Cells: 1~6
Pb battery Voltage: 2~20v
Weight: 270g
Pret:100ron + taxe transport
Poza atasata are doar caracter informativ.Am sa revin cu foto reale.
Aceasta postare a fost editata de nomad: 27 November 2017 - 09:35 PM
#2 Useril este offline   nomad
  • Postari: 651
Postat 12 December 2017 - 08:41 PM
Up
#3 Useril este offline   Kiosku
  • Postari: 1
  • Inregistrat: 08-July 08
Postat 16 December 2017 - 11:09 AM
Salut. Mai este valabil?
#4 Useril este offline   nomad
  • Postari: 651
Postat 17 December 2017 - 09:04 AM
Anuntul este valabil.
