GSU (Display and Programmer)
LED I/O board
Miniature fuel pump
Electronic starting gas valve
Electronic Fuel valve
Fuel tubing, tubing connector set, filters, and cable set
Starting gas tank
Turbine mounting clamp, RamTec compatible
Detailed instruction manual
Thrust: 13 LB @ 165,000 RPM
Weight: 1.87 LB, incl. starter
Diameter: 3.25 inches
RPM Range: 50,000 - 165,000
Exhaust gas temp.: 580°C -690°C
Fuel consumption: 8 oz per/min at full power
Fuel: Jet A1, 1-K kerosene
Lubrication: approximately 5% synthetic turbine oil in the fuel
Turbina noua, in cutie! Pret: 2000 Euro.
Contact: 0744558028
2014-06-17 12.53.41 (Custom).jpg (128.87K)
Number of downloads: 643 -
2014-06-17 12.52.27 (Custom).jpg (152.65K)
Number of downloads: 673 -
2014-06-17 12.53.01 (Custom).jpg (112.96K)
Aceasta postare a fost editata de vic: 09 July 2014 - 03:49 PM
