Modelism - RHC Forum: Proiect Barca Plantat - Modelism - RHC Forum
#1 Useril este offline   MihaiP
  • Postari: 3
  • Inregistrat: 06-April 11
Postat 23 February 2017 - 08:39 PM
Salutare si bine v-am gasit .
Anul acesta prin luna ianuarie am pornit un proiect de constructie a unei barcute de plantat pe care doresc sa il finalizez pana in vara.
Mentionez inca de la inceput ca sunt incepator in ale navomodelismului si posibil sa pun intrebari stupide....dar sper sa le gasesc raspunsul cu ajutorul vostru.
Pentru inceput am achizitionat coca iar acum as vrea sa dau comanda de servo , de pe siteul aliexpress.
Va cer si voua parerea care si ar fi mai bun.
1. MG946R mg946 RC Servo Gear Servo 55g Torque 13Kg ---- Pretul undeva pe la 20 lei.
https://www.aliexpre...9999.279.jq17RG
Dimension: 41mm x 20mm x 43mm.
Stall torque: 10.5kg/cm(4.8V),13kg/cm(6V).
Operating voltage: 4.8-7.2V.
Operating speed: 0.20sec/60degree(4.8v); 0.17sec/60degree(6.0v).
Temperature range: 0 c-55 c
Gear Type: All Metal Gears.
Dead band width: 5us.
Power Supply: Through External Adapter.
Connector Wire Length: 300mm.
Weight: Approx 55g .
Package weight:Approx 66g/unit
2. PDI-6221MG 20KG Large Torque Digital Coreless Servo -Pret 60 lei
https://www.aliexpre...9999.264.xIgXRb
Dead band: 2s
Working frequence: 1520s / 330hz
Operating Speed (4.8V): 0.18 sec/60
Operating Speed (6V): 0.16 sec/60
Stall Torque (4.8V): 17.25 kg.cm (239.55oz/in)
Stall Torque (6V): 20.32 kg-cm (281.89 oz/in)
Dimensions: 40.5X20.2X38mm /1.59 X0.80X49 in
Weight: 62g (2.18oz)
Connector Wire Length: JR 265 mm (10.43in)
Bearing: 2BB
3. The 1501MG is a metal-geared analog servo from Power HD that delivers extra-high torque normally associated with much more expensive or larger servos. This servo is a replacement for --and upgrade over--the original HD-2550A servo. Servo horns and associated hardware are included.
Key specs at 6 V: 0.14 sec/60°, 240 oz-in (17 kg-cm), 60 g.
https://www.aliexpre...c3-9ebda8dbb85a
Analog Servo--HD-1501MG
Function of Performance:
Weight:60g(less connector)
Dimension:40.7x20.5x39.5mm
Supply voltage:4.5~6.0V
Stall Torque:17kg.cm
Operating Speed:0.14sec/60°(no load running)
Storage Temperature :-20C~55C
Dead band width:≤4us
Pret - 60 lei
Va multumesc !
  • Postari: 3539
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 23 February 2017 - 09:54 PM
Oricare din variantele 2si 3 ,ce coca ai luat?
Barcute intinse!
#3 Useril este offline   MihaiP
  • Postari: 3
Postat 24 February 2017 - 03:17 PM
salutare din nou
modelul de coca este acesta. multumesc pentru raspuns
o sa aleg cred modelul 2.
#4 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2399
  • Inregistrat: 01-December 08
Postat 25 February 2017 - 05:20 PM
eu zic sa alegi modelul 1 ca la verde ti o mananca capra !!!
facebook
0721 241 744 VODAFONE
0762 028 013 COSMOTE
#5 Useril este offline   MihaiP
  • Postari: 3
Postat 25 February 2017 - 05:43 PM
Vezi postareastelian, la 25 February 2017 - 05:20 PM, a spus:
Lasa capra la pascut ..gusturile nu se discuta :good:
#6 Useril este offline   ansman
  • Postari: 544
  • Inregistrat: 07-December 08
  • Interests:modelism
Postat 21 April 2018 - 03:18 PM
Eu zic ca cea galbena o mai vezi pe apa in orice moment al zilei. Cea verde cu negru nu prea garantez.
