Modelism - RHC Forum: Motoare aero - Modelism - RHC Forum
Motoare aero
#1 Useril este offline   Rower
  • Postari: 394
  • Inregistrat: 13-February 11
Postat 22 July 2012 - 05:15 PM
1. Motor AXI 2826/10 = 330 RON
AXI 2826/10
Specificatii:
Numar celule: 3-5 LiPo sau 10-16 NiMH
KV: 920 rot/V
Eficienta maxima: 84%
Consum curent ptr. eficienta maxima: 20-30 A (>78%)
Curent maxim: 42 A / 60 s
Curent de mers in gol @ 10 V: 1.7 A
Rezistenta interna: 42 mohm
Dimeniuni: 35 mm x 54 mm
Diametru ax: 5 mm
Masa (cu cabluri): 181 g
Exemple de aplicatie
Model tip acrobat, 2600 g: 4 celule LiPo, elice 11"x8", regulator 40A
Model 3D, 1300/1500 g: 3/4 celule LiPo, elice 14"x7" / 12"x7", regulator 40A
Planor, 3000 g: 4 celule LiPo, elice 13"x6", regulator 40A
2. Motor Turnigy 3648/600kV (nou, nefolosit, cu conectori) = 95 RON
TGY 3648/600
Dimension: 51mm x 37mm, 70mm (with shaft)
Weight: 136g (kv600)
Diameter of shaft: 5mm
Length of front shaft: 19.1mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance:
Voltage: 2-3S
Max current: 35~50A
Prop: 12x8~14x10
Thrust: 1820~2400g
Power: 800W
For 1800~2500g model airplane.
3. Motor NTM Prop Drive 3536/1400 kV =50 RON
NTM 3536/1400kV
Specs:
Model: NTM Prop Drive 35-36A 1400
Kv: 1400rpm/v
Turns: 7
Max current: 55A
Max Power: 550W
Shaft: 4mm
Weight: 117g
ESC: 60A
Cell count: 3s~4s Lipoly
Bolt holes: 18.9mm & 25mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Suggested Prop: 8x4 ~ 11x5.5
Prop Tests:
8x4 - 14.8v - 621W - 42A
8x4 - 11.1v - 277W - 25A
9x6 - 11.1v - 432W - 39A
10x5 - 11.1v -510W - 46A
11x5.5 - 11.1v - 543w - 49A
4. Motor brushed (cu perii) seria 400 (nou, nefolosit, demontat de la inceput de pe aripa Slinger) = 30 RON
#2 Useril este offline   ViorelX
  • Postari: 536
  • Inregistrat: 06-October 09
  • Interests:modelism, electronica, mecanica
Postat 24 July 2013 - 10:13 AM
Mai exista Motor Turnigy 3648/600kV?
#3 Useril este offline   as2008
  • Postari: 713
  • Inregistrat: 04-May 10
Postat 20 September 2017 - 03:34 PM
Vezi postareaViorelX, la 24 July 2013 - 10:13 AM, a spus:
buna ziua , punctul 3 , mai este valabil?
#4 Useril este offline   ViorelX
  • Postari: 536
Postat 20 September 2017 - 03:49 PM
Vreau neaparat 2!!!
#5 Useril este offline   ATYZZZ
  • Postari: 392
  • Inregistrat: 07-September 07
  • Interests:Rc aero auto si cnc.
Postat 20 September 2017 - 10:52 PM
Tu vrei neaparat raspuns la un anunt din 2012?
Uita de el.
